M21 stuck in gear - Chevelle Tech
 5Likes
  • 1 Post By Sauce454
  • 3 Post By Sauce454
  • 1 Post By HKalin
post #1 of 9 (permalink) Old Jul 11th, 19, 11:46 AM Thread Starter
M21 stuck in gear
Any quick fixes or do have to transmission specialist. Also can I access linkage from inside of car.by the way car is a1970 chevelle ss454
Sauce454 is offline
post #2 of 9 (permalink) Old Jul 11th, 19, 11:57 AM
Re: M21 stuck in gear
Typically occurs when gate adjustment is improper. Happened to me twice in my years of owning the Chevelle. If I have the problem right, ensure there is no load on the transmission. Chock it, and get underneath and physically pull the errant lever into its neutral position. Will see one pointing forward or backwards, and the other perpendicular to the ground( its neutral) The non-perp one is one you have to yank back into into neutral ( straight up/down).
The cause, if I have diagnosis correct, is rods that are not the right length. Undo the shift rods from shifter, place pin in neutral gate hole and then dial in the length of the rods, while the shift levers are all in their neutral place.
Welcome to TC BTW!
post #3 of 9 (permalink) Old Jul 11th, 19, 12:16 PM
Al
Pull the linkage off the trans and try to put both levers in the center position. A lot of the time this is caused by linkage bind which can be repaired by adjusting the shifter, replacing the shifter bushings and shifter locks with Hurst type spring locks that keep the shifter in the bore against the bushing.
https://www.youtube.com/watch?time_c...&v=yaQwPQTenMg
post #4 of 9 (permalink) Old Jul 12th, 19, 6:09 AM Thread Starter
Dutch Max & 427L88 thanks your knowledge was very helpful. She's all ready to go. Supposed to have a beautiful weekend here in southeast Pennsylvania I will enjoy it thanks to you guys. I'll be cruising.
427L88 likes this.
Sauce454 is offline
post #5 of 9 (permalink) Old Jul 12th, 19, 6:09 AM
I agree with Al and Gene. Problem probably isn't the transmission, it's in the linkage adjustment or the shifter.
buenymayor is offline
post #6 of 9 (permalink) Old Jul 12th, 19, 6:15 AM Thread Starter
You are correct it needed some adjusting well a lot of adjustment good to go now
427L88, buenymayor and Pioneer4x4 like this.
Sauce454 is offline
post #7 of 9 (permalink) Old Jul 12th, 19, 7:13 AM
We all learned this the hard way! Happy Trails Sauce!
post #8 of 9 (permalink) Old Jul 12th, 19, 7:47 AM
Hank
My 70 Nova used to do that once in awhile. What would happen is that one of the shifter plates that bolted up to the transmission would come loose and jam the shifter up.
427L88 likes this.
HKalin is offline
post #9 of 9 (permalink) Old Jul 12th, 19, 8:00 AM
I learned, also the hard way, never to RED Loctite on those bolts, I still use blue Loctite on all shifter bolts.
