Change in power after Transmission and rear changes - Chevelle Tech
 10Likes
post #1 of 32 (permalink) Old Jul 1st, 19, 7:30 AM Thread Starter
I am noticing that after the change from TH350 to 2004-r with 3.08 I used to be able to spin the tires from rolling position and start, changed the transmission and unable to spin the tires, changed rear to 12 bolt 4.33 from 10 Bolt 3.08 still unable to spin tires unless I power brake it and not from rolling position, I feel slip at times in transmission which was rebuilt last year and sat in garage until 2 months ago
Bradco is online now
post #2 of 32 (permalink) Old Jul 1st, 19, 11:27 AM
Geoff
Re: Change in power after Transmission and rear changes
What torque converter?
Geoff1200 is offline
post #3 of 32 (permalink) Old Jul 1st, 19, 12:34 PM
Mr Bill
That does not make sense. If you could spin the tires with the 3.08 gears you should easily be able to with the 4.33's Plus the 200 has a slightly lower first gear ratio. Are you absolutely certain the rear is 4.33 ??
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
post #4 of 32 (permalink) Old Jul 1st, 19, 12:36 PM Thread Starter
I am going to Transmission place today and ask that
post #5 of 32 (permalink) Old Jul 1st, 19, 12:38 PM Thread Starter
it is a 3 series carrier with a 4 series 4.33 with spacer , I Called Richmond when I got it and gave them the numbers on the gear and they told me it was 4.33 I asked are you sure and they said yes
post #6 of 32 (permalink) Old Jul 1st, 19, 1:37 PM Thread Starter
just came from transmission garage, he is checking and will call me later, this started after changing to the 2004-r even with the 3.08
post #7 of 32 (permalink) Old Jul 1st, 19, 2:15 PM
Levon
Maybe the transmission is not going into low gear? Did you change the shifter detents to accommodate the new transmission?
Alan F and Kirk's67SS like this.
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is online now
post #8 of 32 (permalink) Old Jul 3rd, 19, 11:16 AM Thread Starter
do you mean from the column shift rod for the th350 to 2004-r? I Installed a new lokar Shifter rod kit, also took it to the Transmission place that rebuilt the tranny, and they test drove and supposedly checked that before I changed the rear.
post #9 of 32 (permalink) Old Jul 3rd, 19, 12:24 PM
Mr Bill
Brad,
When you drive the car how many times does it shift ?
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is offline
post #10 of 32 (permalink) Old Jul 3rd, 19, 1:36 PM Thread Starter
From stop I think I feel 3, but will take it out after work today and verify. I do feel it drop down around 35 to 40 I have lock up solenoid external with 12 volts, Also I see floor shifters with d with circle around it then d the first one is where I should be correct. I have column shifter
post #11 of 32 (permalink) Old Jul 3rd, 19, 6:17 PM Thread Starter
Brad,
Yes from stop it changes 3 times on the street last change close to 40mph
post #12 of 32 (permalink) Old Jul 3rd, 19, 8:53 PM
Mr Bill
That sounds like it is using all four gears so it is going into first. No idea, does not make sense. Do you have a tach ? If so what rpm at 50 mph ? What size rear tires ?
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is offline
post #13 of 32 (permalink) Old Jul 3rd, 19, 9:17 PM Thread Starter
The 3rd change meant at 40. Have 28” tires not sure my rpm tach is right as around 60 I am less than 2000 rpm and have 4.33 gears
post #14 of 32 (permalink) Old Jul 3rd, 19, 9:21 PM
What stall speed is the converter?
Maybe the th350 had a higher stall converter which would let you get the engine into the power band when you romped on it, and the 2004r may have a lower (stock?) converter which won't wind up into your power band until you are well under way?
1972 Chevelle, 454, 2004r, 4.10
lucifershammer is online now
post #15 of 32 (permalink) Old Jul 3rd, 19, 10:24 PM
Mr Bill
The 3rd change meant at 40. Have 28Ē tires not sure my rpm tach is right as around 60 I am less than 2000 rpm and have 4.33 gears
That is pretty close. I came up with almost 2100 rpm at 60 with your 4.33 gear and a 28" tire.
Is there any chance that something else got moved while doing the trans ? Distributor maybe and timing changed ? Another maybe stupid question but are you getting wide open throttle on the carb when you push the pedal to the floor ?
I cant think of anything else.
LeoP and lucifershammer like this.
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is offline
