Urethane UCA mount bushings for 12 bolt - Chevelle Tech
 2Likes
  • 2 Post By 1966_L78
post #1 of 14 (permalink) Old Jun 28th, 19, 1:08 PM Thread Starter
I can't seem to find a part number from Energy Suspension, or Prothane on getting these bushings. I did see UMI has a pair for $40 bucks, but I am trying to see if I can find something locally. I don't care too much about the brand, but does anyone have a part number?
Youtube Channel.
Instagram:
Twitter:
-SS454- is online now
post #2 of 14 (permalink) Old Jun 28th, 19, 1:20 PM
OLIVER
Re: Urethane UCA mount bushings for 12 bolt
I changed all the body mounts to energy suspension and looked for them , did the search came up with nothing , so i bought the UMI
Oliver
Milano , ITALY
468 Vortecpro 585 HP back to street cruiser
M20 4 speed - 3.31
Prosystems 1000
BEST ET 11.62 (with 4.10)
BEST MPH 121
BEST 60 FT 1.64
4000 lbs street car
1969 El Camino Street Strip
467 Vortecpro Tunnel ram 730+ hp TH400
BEST ET 10.67 @ 127 1.56 60FT
oliver69 is offline
post #3 of 14 (permalink) Old Jun 28th, 19, 1:49 PM
Marcus
I think energy suspension only sell then as a set of eight or four.
The set of four is part nr 3.3169(R or B for the colour you want)
https://www.energysuspensionparts.co..._chevelle_1970
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is online now
post #4 of 14 (permalink) Old Jun 28th, 19, 2:08 PM
Are you sure you want the urethane bushings in the rearend?
The Upper arms and bushings NEED to flex for the rearend to travel/articulate through its normal motion, and really stiff bushings in that location will limit that, putting the stress on the frame cross-member or the upper arms. The extra stiffness actually increases the overall "spring rate" because the arms will act like a torsion bar. I ended up swapping back to quality rubber at both ends of the upper arms (urethane everywhere else), and handling and comfort improved... My next project will be arms with spherical joints at both ends...
Malibu ss 64 and hydro462 like this.
TC #1366
Sold
Sold
1966_L78 is offline
post #5 of 14 (permalink) Old Jun 28th, 19, 3:15 PM
If you want freedom of movement and no binding, then you should install either the UMI Roto-joints in the differential housing or the Currie Johnny Joints.
65-88 GM A/G-Body Roto-Joint Rear End Housing Bushings [2999] - $159.99 : UMI Performance, Inc.
https://www.currieenterprises.com/CE-9112A
My Chevelle w/ open headers:
WakkoWarner is offline
post #6 of 14 (permalink) Old Jun 29th, 19, 2:58 PM Thread Starter
I have johnny joints in the UCA's on the frame side.
Youtube Channel.
Instagram:
Twitter:
post #7 of 14 (permalink) Old Jun 30th, 19, 3:00 AM
Marcus
I did the same.
post #8 of 14 (permalink) Old Jun 30th, 19, 4:23 AM Thread Starter
wouldn't having spherical bushings on all ends of the UCA allow the rear axle to shift left/right?
Youtube Channel.
Instagram:
Twitter:
post #9 of 14 (permalink) Old Jun 30th, 19, 10:00 AM
Not at all. Sphericals are one of the first things I do when I buy an old car. If not sphericals then keep them rubber..
I would do rubber in the two center bushings and sphericals on the rest. I recommend SC&C Stage three for the front with the superior Howe .5 and .9 ball joints and Sphoon Del Sphere rear control arms. I did a lot of research and found these two set ups to be one of the best for the money.. Lee for steering box..
hydro462 is offline
post #10 of 14 (permalink) Old Jul 13th, 19, 2:33 AM Thread Starter
I found 2 3021B bushings in a box of goodies that came with the car. Since poly doesn't break down, I should be good to use it. That is if I could get it to press in the housing. Even putting it in the freezer for days it didn't want to go in. I am using a C clamp
Anyone got a trick to it?
Youtube Channel.
Instagram:
Twitter:
post #11 of 14 (permalink) Old Jul 13th, 19, 7:03 PM
Jason
ball joint press cups with threaded rod and washers.
I’d rethink the poly mine shattered in about 3,000 miles. I switched to spherical bearings at all 4 points. Man what a difference. Some say they have a louder road noise but I say their exhaust isn’t loud enough 🙂 spherical or rubber is the only way to go.
Jasons 69 Chevelle is offline
post #12 of 14 (permalink) Old Jul 13th, 19, 8:09 PM Thread Starter
Apparently spherical bushings don't come wide enough for the Moser ears.
Youtube Channel.
Instagram:
Twitter:
post #13 of 14 (permalink) Old Jul 13th, 19, 8:22 PM
Jason
Not much you can do then. Rubber would be your best choice then. Unless you cut the ears down to the thickness needed.
post #14 of 14 (permalink) Old Jul 14th, 19, 12:20 PM
Global West Suspension makes a set specially for the Moser rears. PN: SP-47M.
any4xx is offline
