rear end ratio - Chevelle Tech
 9Likes
  • 1 Post By Malibu ss 64
  • 1 Post By bracketchev1221
  • 4 Post By 1966Chev
  • 2 Post By ZEN357
  • 1 Post By dozerhand
post #1 of 12 (permalink) Old Jun 26th, 19, 6:51 PM Thread Starter
rear end ratio
I have a 72 El Camino with a 454 (500 hp with a decent cam) and a Th400 built by ATI. I have a 2800 stall and 12 bolt posi 3.73 gears in the rear end. I have MT 28/12 x 15 rear tires. I currently am hitting 3,000 rpms at 65 mph.
I am considering changing the rear end gears to a more user friendly ratio of either 3.31 or 3.42. The car is never raced.
I am hoping to drop the rpm range to a more comfortable range of 2500 to 2700 range. Also hopefully help my MPG.
Any thoughts???
The Bullet is offline
post #2 of 12 (permalink) Old Jun 26th, 19, 7:06 PM
I have a 3.31 in my 12 bolt with with stock wide ovals that are not quite 27 tall. I cruise at 70 mph at 3000 rpm. That is until I’m done with my 5 speed install. You should get a little more speed at that rpm with your taller tires. But to be honest, with my 402 big block with 420hp and 500tq your mileage may not improve much since I currently get about 13 without my foot in it most of the time. Drone will be better though.
Nerfherder396 is offline
post #3 of 12 (permalink) Old Jun 26th, 19, 8:04 PM
Re: rear end ratio
Not enough ratio change to notice the difference. My 2 cents.
edspdog is offline
post #4 of 12 (permalink) Old Jun 26th, 19, 9:55 PM
Hank
Re: rear end ratio
I have 3:55's with 28" tall tires and run 2600 rpm's at 60.
HKalin is online now
post #5 of 12 (permalink) Old Jun 26th, 19, 10:42 PM
Vince
Re: rear end ratio
Any thoughts???
3.31 axle will have you turning 2582rpm at 65mph, with no converter slip...
using this link: Wallace Racing - Calculate RPM for given MPH, Rear Gear Ratio and Trans Gear Ratio
VinceS427bb is offline
post #6 of 12 (permalink) Old Jun 27th, 19, 3:17 AM
Marcus
Re: rear end ratio
I went from 3.73 to 3.31 and is was enough difference for me to make it more liveable on the highway.
VinceS427bb likes this.
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is offline
post #7 of 12 (permalink) Old Jun 27th, 19, 6:59 AM
Re: rear end ratio
go to 3.31 if you want a noticeable difference. 3.42 won't be.
Ray
bracketchev1221 is offline
post #8 of 12 (permalink) Old Jun 27th, 19, 7:58 AM
Re: rear end ratio
If you never race maybe a 3.08 is the ticket? You have enough engine to handle it.
1966Chev is offline
post #9 of 12 (permalink) Old Jun 27th, 19, 8:47 AM
Re: rear end ratio
Any thoughts???
If you are just driving it around town and not racing it, then I would honestly consider 3.08's for the gas mileage.
Kirk's67SS and Frank69 like this.
ZEN357 is offline
post #10 of 12 (permalink) Old Jun 27th, 19, 1:08 PM
David
Re: rear end ratio
I'm going with 3.08s, this Doug Nash has a deep enough first gear to still give good off the line acceleration.
Later, dozer
the heckler likes this.
"Look Stock and carry a Big Block"
Raube Wan
dozerhand is offline
post #11 of 12 (permalink) Old Jun 28th, 19, 11:35 AM
Send a message via Yahoo to ElCameeeno
Re: rear end ratio
I went from 3.73 to 3.08. Made the car much more enjoyable to drive even with a 2.20 low M22. There was a performance trade off however, but in my case it was worth it.
Jon
TC Gold Member #08
'71 SS454/M22 El Camino
'68 Chevelle/M22
'72 6 cylinder El Camino
ElCameeeno is offline
post #12 of 12 (permalink) Old Jul 1st, 19, 7:21 AM
Re: rear end ratio
I have 3.08's in daily driver and get good gas mileage and the acceleration is not bad as well.
ZEN357 is offline
