4L60E or 80E problem - Chevelle Tech
  • 1 Post By paul bell
post #1 of 7 (permalink) Old May 26th, 19, 10:14 AM Thread Starter
rick
I have a 2005 chevy express 2500 4.8 litre with 1 of these trans but not sure which, it's got 150K mi. and acting odd leaving red lights & stop signs some times the van will act like it's not in gear when I give it gas then it feels like I had it in neutral revved it a little and dropped it in gear, fluid is full but does have a burnt smell and getting dark in color, will this need a total rebuild ? it's also my DD work van, tia, rick.
shovelrick is online now
post #2 of 7 (permalink) Old May 26th, 19, 2:24 PM
Re: 4L60E or 80E problem
I'd drop the pan and see what's in there as far as shedding clutch material off the disks.
The web has pictures of the shapes of various trans pans to indicate whether it's a 4L60E or a 4L80E.
Does it throw any OBD II codes? I'd have to think with that much slippage, it would throw a code or two for slippage.
Could be a pump problem that takes some revved up rpm to get the torque converter to engage. A pressure gauge would be good here.
B52bombardier1 is offline
post #3 of 7 (permalink) Old May 26th, 19, 2:37 PM
Being a 2500, it should be a 4L80E (that is what Rockauto shows). If it needs to be rebuilt, I would just purchase one from an Autonation dealer. They come with a 3 year, 100,000 mile warranty. If anything goes wrong, the dealer fixes it.
If you know someone with an account at one of those dealerships, you can get it a little cheaper. The prices I am seeing are around $2,600, with a $700 core charge. Buying it local would save you the core charge (you would just take yours out and have it with you when you purchase the new one). You will need your transmission code - apparently there are two different ones.
https://www.chevroletpartsdirect.com...QtOGwtdjgtZ2Fz
https://www.gmpartsonline.net/auto-p...nsmission-scat
My Chevelle w/ open headers:
WakkoWarner is online now
post #4 of 7 (permalink) Old May 26th, 19, 2:48 PM
Terry
It sounds similar to a problem i had, ended up being the 1-2 shift solenoid. Terry
68-13427 is offline
post #5 of 7 (permalink) Old May 26th, 19, 5:18 PM Thread Starter
rick
I guess I'm taking it to a local trans shop that has a good rep, I bought a trans jack last year (or year before?) but now with a bad neck I can't work on pulling/installing just didn't want to hear $3,000+ if it's a simple repair & fluid/filter
post #6 of 7 (permalink) Old May 30th, 19, 7:31 PM
I fixed a chevy 1500 recently that did the rev/jerk thing. It was low on fluid. Your burned fluid is a pretty bad sign even if it is low.
'71 chevelle, 468, TH400, 12 bolt posi w/3.08's, drinks a lot of 87 octane.
v8440 is offline
post #7 of 7 (permalink) Old May 30th, 19, 8:13 PM
ACDelco and Rock Auto show as either 4L60e OR the 4L80E being used.
As you're having problems with it, I'd say you have the 4L60E because the 4L80E should NEVER have issues behind a 4.8-unless you've been doing neutral drops.
I'd suggest you do a filter change and replace whatever fluid comes out with fresh. Make sure you clean the pan and magnets real good, at 150K miles, they'll be covered.
Any foaming of the coolant in the radiator? The transmission cooler inside the radiator is prone to leaking and coolant in the transmission fluid is fatal to any automatic transmission. I always suggest eliminating the stock cooler and go external. If you overheat the engine it then heats the transmission-which is also fatal for it.
I had a 1999 GMC Savana 1500 with the 305 engine and the 4L60E transmission. It was rebuilt FIVE TIMES in 100,000 miles. This transmission should never be used in any truck application, regardless of engine.
Kirk's67SS likes this.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
Battery drain problem Dcairns560 Troubleshooting 23 Dec 13th, 18 1:38 AM
HELP!!!1972 chevelle a/c- heater control problem berneemc Electrical & Wiring 14 Jun 2nd, 15 10:22 AM
Crossmember bolt in not straight across...a problem? Gossamer454 Transmission & Driveline 4 Apr 4th, 15 5:01 AM
frustrating 68 starting problem 68454SS Electrical & Wiring 9 Oct 25th, 14 11:20 PM
temp gauge problem farmboy66 Electrical & Wiring 1 Apr 7th, 13 10:01 PM
