Driveshaft length questions - Chevelle Tech
post #1 of 6 (permalink) Old May 22nd, 19, 2:19 AM Thread Starter
Garret
Good evening,
I just got my big block 72 Chevelle running (full rebuild). It’s a 454 and I’m running a Mikes Transmission Ultimate 400. I currently have a factory 10 bolt under the car. It will eventually have a Moser or Currie 12 bolt. My question is this:
Is the driveshaft the same length for using either the 10 or 12 with the 400 transmission? Or, are they way different?
I’d like to get a custom driveshaft made but I don’t want to use the distance between the trans and the 10 bolt if the 12 will be different.
If they are different, anyone have a cheap 10 bolt to 400 shaft in So Cal I could obtain.
Thanks for the help,
Cheers!!
Also I have some engine video porn if you want to see it. I don’t know how to upload the video
Retnuh22 is offline
post #2 of 6 (permalink) Old May 22nd, 19, 7:14 AM
Marcus
Re: Driveshaft length questions
They should be same lenght between 10 bolt and 12 bolt.
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is offline
post #3 of 6 (permalink) Old May 22nd, 19, 9:06 AM
Also keep in mind what pinion flange U-Joint your 10-bolt has. It may have a GM 3R, 1330 or 1310 style u-joints in the rear of the drive shaft. A Moser or Currie 12-bolt should be configured the same if you want to use the same driveshaft. Many folks opt to upgrade to 1350 U-joints, myself included.
USAF Retired (1968-1988)
David Bates is offline
post #4 of 6 (permalink) Old May 22nd, 19, 10:09 AM Thread Starter
Garret
I think I’d upgrade to a 1350 pinion u-joint flange for the 10-bolt so a custom driveshaft would fit and have the ends I want when the new rear end is completed.
That will make the transition much easier. It will allow me to get a custom made driveshaft to make the car roll and drive so I can get it onto a trailer much easier while the 12-bolt is being built.
Retnuh22 is offline
post #5 of 6 (permalink) Old May 22nd, 19, 10:09 AM Thread Starter
Garret
Thanks for the information!!
Retnuh22 is offline
post #6 of 6 (permalink) Old May 23rd, 19, 4:36 PM
The 3-R drivelines were only on the 454s ( LS-5s & LS-6s ) in 1970. They continued with the 3 R drivelines in the 71/72 454s. Not sure about the 3-R drivelines past 1972-454s. ( the 454s used the GM-9210 pinion flange)
Robinls5 is online now
This Thread is more than 441 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Proper driveshaft length mmanship Transmission & Driveline 9 Jan 31st, 19 8:10 AM
69 Driveshaft length SS427Rick Transmission & Driveline 2 Feb 28th, 16 10:35 AM
If interested in 66-7 driveshaft stripe colors, take a look. Jim_66SS Restoration Corner 4 Oct 5th, 14 2:57 PM
!968 Gto Driveshaft 4 speed driveshaft length jfoley Transmission & Driveline 0 Sep 20th, 12 12:26 PM
driveshaft length John71 1999 -- 3 Dec 17th, 98 3:09 PM
