12 bolt from hades - Page 2 - Chevelle Tech
 18Likes
post #16 of 42 (permalink) Old May 16th, 19, 8:11 AM
Greg.
Re: 12 bolt from hades
Beth if I lived closer you could have my old 67 12 Bolt
Malibu ss 64 and pannetron like this.
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.561
1/8 = 7.411 et / 90.18 mph
1/4 = ??.??? et / ??? mph
Kirk's67SS is offline
post #17 of 42 (permalink) Old May 16th, 19, 12:18 PM
Greg
I was thinking the shock mounts were in he wrong place at least compared to my 69, look a the 67 above then look at Beth's pics.
https://
href="http://s146.photobucket.com/albums/r241/gregs_photo/" target="_blank">http://s146.photobucket.com/albums/r241/gregs_photo/
2cool is offline
post #18 of 42 (permalink) Old May 16th, 19, 12:25 PM
Greg
Casting numbers found to be the most prevalent in Chevelle 12-bolt rear ends:
1965 Chevelle 3859140N
1966 Chevelle 3875745N
1967 Chevelle 3894939NF
68-69 Chevelle 3917124NF
1969 Chevelle 3959038NF
70-72 Chevelle 3969278NF
As always, there will most likely be some rumor of overlap in numbers but unless you have a build sheet/Protect-O-Plate and can verify the stamped codes as original, who knows? It should also be noted that the 1965 12-bolt is the only one with the diagonal bracing on the center section casting.
Note: Thanks to David Bates for the above information!
According to an old article, Inside '64 -- '72 A-Bodies, (Car Craft Magazine), 1967 was a transition year in that A-body cars might have a 1964-66 style rear end, a 1968-72 rear end (which is wider, and commonly available), or a "hybrid" rear end, which will have the 60.5-inch width, but with the early spring mounting pad and trailing arm brackets. Several late 1966 rear ends with casting number 3875745, one dated L 8 6 (December 8, 1966), have been found in early 1967 Chevelles and retain the retention plates to secure the rear springs.
https://www.chevellestuff.net/tech/rear_end_widths.htm
https://
2cool is offline
post #19 of 42 (permalink) Old May 16th, 19, 12:48 PM
Marcus
The shock mount on beths is not in oem location somebody has moved them. Regardless of year they should look as on Gregs.
Kirk's67SS likes this.
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is online now
post #20 of 42 (permalink) Old May 16th, 19, 1:47 PM Thread Starter
Beth
I'm pretty sure the 66-67 shock mounts are only 1" away from the backing plate while 68-72 are about 3" away.
I think Saltherring is correct; the coil spring mounts are all that need to be fixed on the 69 rear end I have.
But I could be wrong LOL
67 Chevelle convertible, 138 vin, original 4 speed, bucket seats, 12 bolt, Marina Blue with black interior
nashville beth is offline
post #21 of 42 (permalink) Old May 16th, 19, 1:49 PM Thread Starter
Beth
You installed a S60 , correct ? They are the ticket for drag racing for sure.
post #22 of 42 (permalink) Old May 16th, 19, 2:01 PM Thread Starter
Beth
The difference is only 1”, looks like it needs a total rebuild if you have a reputable shop around let them shorten it and go with ”ford style” ends.
The question I am struggling with is this : will using a later model rear end de-value the car ?
Is saving $300 now short-sighted ?
The car is going to be a driver for sure with a 489 and 6 speed T56. But everything to the eye will appear stock. That's why I'm not considering a Moser or S60 rear.
post #23 of 42 (permalink) Old May 16th, 19, 2:30 PM
Marcus
The only difference is that the axle tube is 0.5” longer on each side outside the brackets all brackets are located same but on later houses theres 0.5” extra clearance to the backning plate.
The shock mount on your 12 bolt is moved and not in oem location. Oem they are a reinforcement if the lca bracket, so it can be vise to put it back where it belongs.
Since its not a nr matching car I think the value wont be affected much if all with a later rear as long as you fix the spring mounts and have it rebuilt. If only a driver you can save money and reuse your current ends and go with c-clip axles.
If you want the narrow version othervise just use 68-72 axles and leave it. Theres info telling that 67 used narrow housings with flat 65-66 spring mount and 68-72 wider housings with 68-72 spring mounts+ a narrow hybrid version with 68-72 spring mounts. I cant verify if true or not?
post #24 of 42 (permalink) Old May 16th, 19, 2:33 PM
Marcus
Compare Gregs with this eBay listing of a68-72 12 bolt and you will see how they look unmolested.
https://www.ebay.com/itm/Original-19....c100930.m5375
post #25 of 42 (permalink) Old May 16th, 19, 3:26 PM Thread Starter
Beth
Yeah, I don't know where those brackets came from on my current 69-70 rearend.
Strange indeed.
post #26 of 42 (permalink) Old May 16th, 19, 3:35 PM
Freddie
I wouldn't worry about devaluing the car if you are installing a T56. Having the wrong rear end in it isn't going to matter.
big gear head is offline
post #27 of 42 (permalink) Old May 16th, 19, 6:03 PM
Ole
I was not correct, Beth. I just did what I should have done before posting and that is go to the shop and measure the '69 rear that I have on the shelf. The inboard edge of the shock mount is approximately 1 3/4" from the inside surface of the axle flange. Sorry for the confusion.
Saltherring is offline
post #28 of 42 (permalink) Old May 16th, 19, 6:24 PM Thread Starter
Beth
10-4 , no problem.
That S60 sure does look tempting - $2900 with the true trac center
https://www.strangeengineering.net/p...g-mounts.html/
post #29 of 42 (permalink) Old May 16th, 19, 6:48 PM
Ole
10-4 , no problem.
Yes, that does look nice. My '69 had a '67 rear in it when I bought it. The rear had a near new Eaton posi carrier with near new 3.73 gears, Strange Axles and C-clip eliminators. I sold it last fall for $2,000 minus brakes, as the buyer was going with discs on the rear of the '65 wagon he was installing it in.
Before removing/selling the '67 rear, I purchased a '69 3.55:1 rear that had been changed out to 4.88:1, by using a ring gear spacer. I replaced those gears with 3.73:1 and that is what I am presently running in the '69.
Given the cost for parts, (housing, gear set, carrier, pinion yoke, axles, small parts, etc.) professional set-up, axle tube straightening and what ever else you might need, it might be the right choice to buy the Strange set-up.
post #30 of 42 (permalink) Old May 16th, 19, 8:15 PM Thread Starter
Beth
Yes, it does seem no matter which direction we choose, the cost of a good setup is around $3000.
At least the Strange would be bulletproof. My T56 is going to be the weak link.
The What's What about Bolt Patterns Discount Tire Discount Tire 0 Jan 21st, 19 12:27 PM
12 bolt build Options....?? sidehiller_5 Transmission & Driveline 6 Oct 7th, 15 4:59 PM
Moser 12 bolt housing or 9" with 12 bolt drop in GsxrDave Transmission & Driveline 5 Sep 13th, 15 8:28 PM
1967 Chevelle 12 bolt axle perches? Jsanford1974 Transmission & Driveline 3 Aug 10th, 15 11:13 PM
Rod bolt strength, what do we REALLY NEED? 540 RAT Performance 25 Mar 3rd, 13 9:55 PM
