Driveline vibration - Chevelle Tech
post #1 of 8 (permalink) Old May 6th, 19, 1:42 PM Thread Starter
gary
Driveline vibration
I had a thread two years ago about a driveshaft vibration. It was suggested that a 3.5 D driveshaft would fix the jump rope vibration. I had made a new shaft made & it did fix that vibration. I also got some UMI rear upper adjustable arms.
The 350 engine & 200R4 trans are 4* down, the carb pad on intake is at 0*. There is no room to lower front or raise rear so 4*is what it is. The driveshaft is at 0*, the pinion is now at 3* up. Spicer says 3* is max for a u joint & to limit rpm if it is more than that. The operating angles are 4* & 3*.
I have some more work to do on the car & will report back after the road test. Any comments on the angles?
post #2 of 8 (permalink) Old May 6th, 19, 2:15 PM
Re: Driveline vibration
Hi Gary -
I don't have any words of wisdom, but I'm following this thread as I have the same engine/tranny combo as you and have purchased (not yet installed) the UMI adjustable rear uppers as well.
Did you purposely set the pinion 1* less than the engine/trans to account for the rear-end torque? I still have the factory DS, but it was balanced recently which eliminated most of the vibration I was getting. I'm only noticing a slight vibration now at higher speeds - hoping getting the adjustable rears installed will take care of that.
jim
Jim's69Ragtop is offline
post #3 of 8 (permalink) Old May 6th, 19, 5:40 PM Thread Starter
gary
I read on spicers page that 3* is the max they want, I thought it might be better to only have one joint at 4*. I will experiment with angles. My car has 4.11 rear gears so at 75 mph the shaft is turning 3500+- rpm. OD gets the engine down to 2500+- rpm.
I feel a drone above 3500 DS rpm that Im trying to reduce.
post #4 of 8 (permalink) Old May 6th, 19, 6:59 PM
Watching results and too as in couple weeks I will have same setup 350/200r4 but 4.33 rear
Bradco is offline
post #5 of 8 (permalink) Old May 15th, 19, 9:21 PM Thread Starter
gary
Originally Posted by Jim's69Ragtop View Post
Hi Gary -
jim
I have been looking at driveshaft angles & Detroit Speed recommends 1-2* less angle on pinion vs engine.
post #6 of 8 (permalink) Old May 15th, 19, 9:31 PM
I may be wrong - but, won't you lower the driveshaft at the rear end if you lower the pinion yoke, which will reduce the angle coming out of the trans?
If I read it right, you have the pinion angled up right now. Lowering it should decrease the angles at both the tail shaft and the pinion yoke.
lucifershammer is online now
post #7 of 8 (permalink) Old May 16th, 19, 12:43 AM Thread Starter
gary
I have had the pinion 3-4* up at the front of it. (This is called pinion down on Spicer as they look at the rise or fall from the front to back). I have also tried 1* up.
Yes if lowering pinion the angle at trans is less. I have been researching this for a year or so. Havent learned anything to pass on yet. Part of the problem is the 4.11 rear gear. The DS is spinning at 3500-4000 rpm at 75 mph. Thats the speed limit on I-10 in AZ.
I hope UMI. can help, we will see tomorrow.
post #8 of 8 (permalink) Old May 16th, 19, 7:31 AM
Ah, ok, so right now your pinion yoke is aimed down, not up (you were using Spicer's "up" terminology?)
This Thread is more than 423 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
driveline vibration? chevelle 917 Transmission & Driveline 10 May 18th, 17 12:06 PM
Help with a vibration problem - clutch?? novadude Transmission & Driveline 8 Jun 1st, 15 7:15 AM
Driveline Vibration Jonkatie426 Transmission & Driveline 10 Nov 15th, 14 1:35 PM
1970 Chevelle Driveline Vibration 70 Chevelleman Transmission & Driveline 13 Jun 4th, 14 9:56 PM
Vibration Issue After Trip To The Track. timvantol Performance 19 Dec 25th, 12 12:24 PM
