Clutch recommendation - Chevelle Tech
 7Likes
post #1 of 21 (permalink) Old Apr 22nd, 19, 3:48 PM Thread Starter
Hi all! As I am getting nearer to ordering the transmission/clutch I am wanting some feedback on the clutch that SST has recommended for my set up. They are wanting to use a single ceramic sprung hub disk. I am wanting something that is easy to drive and has decent street manners. The clutch is rated to hold up to 650lbs of torque, which is roughly 50 more than I currently make. I don't want to spend 1200 on a clutch so their's might be a good compromise.
What are your thoughts?
Car is 3680lbs and has 3.73s in the back with a 489 making roughly 630hp with 600lbs of torque.
tacomatrd is offline
post #2 of 21 (permalink) Old Apr 22nd, 19, 5:07 PM
Ole
Re: Clutch recommendation
Hey, Tacoma. About an hour and 15 north of you I'm running an 11-inch Centerforce Dual Friction bolted to a Hays SFI billet wheel. But you're pumping out about 130 more HP than me.
Saltherring is offline
post #3 of 21 (permalink) Old Apr 22nd, 19, 6:30 PM Thread Starter
Probably a little more than an hour! That sad from my truck, I am down in California.
How do you like the clutch? Silver sport said it would be fine and wouldn't notice a difference between the ceramic and organic if set up right
post #4 of 21 (permalink) Old Apr 23rd, 19, 1:16 AM
Ole
Yeah, now I remember. You're not from Tacoma, you drive one.
This is the second CF DF I've run. The first was a 10.5" setup behind a hot little 327 in a '65 SS Malibu. The present one is an 11 incher behind an upgraded L78 396 in a '69 SS Chevelle. I raced the '65 a bit but the '69 hasn't been down the track yet. Both clutches have hooked up well and operate smoothly with what I would call moderate foot pedal pressure. Never had slicks on either, however, but both have been 3.73 gears with C/R Muncie transmissions.
mrpaticular likes this.
post #5 of 21 (permalink) Old Apr 23rd, 19, 1:17 AM Thread Starter
Are you using hydraulic or mechanical?
post #6 of 21 (permalink) Old Apr 23rd, 19, 1:19 AM
Ole
All stock mechanical linkage.
post #7 of 21 (permalink) Old Apr 23rd, 19, 1:29 AM Thread Starter
How is the 11 inch on the street? Is it grabby?
post #8 of 21 (permalink) Old Apr 23rd, 19, 1:48 AM
Ole
Not at all in my opinion. Most of my driving is paved back roads and clutch operation is smooth and precise, but the present car will burn off a fair chunk of rubber with a 7 grand 1-2 hard (non-power) shift.
I should possibly amend the "moderate" pedal pressure remark at bit, as I have very strong legs and what is moderate to me might seem a bit heavy to other folks.
post #9 of 21 (permalink) Old Apr 23rd, 19, 6:45 AM
I just ordered a new disc for my Centerforce DF. Rated for 620 ft lbs, so my new 600 pounder should let it live a year or two. Never had issue with CF DF. 20 years running. But I am putting another 100+ ft lbs on it now.
post #10 of 21 (permalink) Old Apr 23rd, 19, 2:02 PM
Ben
I just put the CF DF in my 68. Itís an 11Ē behind 454 thatís built up a little with a muncie, all mechanical stock style linkage. I think the pedal feel is super light! Way lighter than I was expecting. Iím still trying to break it in (motor and clutch) and going easy, but it seems to be holding excellent; tires are breaking loose before the clutch slips. Iím definitely happy with my choice.
No car yet; currently looking for 66-69 project/driver.
skreddy is offline
post #11 of 21 (permalink) Old Apr 23rd, 19, 3:09 PM
I ran CF DF in my 69 behind big and small blocks. Never any issue. Pedal pressure is easy for driving with mechanical linkage. Grabbed like glue at the drag strip adjusted for the street.
427L88 likes this.
mrpaticular is offline
post #12 of 21 (permalink) Old Apr 23rd, 19, 4:32 PM
I would still consider twin disc if I were you. Though I'd seriously consider mechanical linkage if using stock linkage.
The McLeod RST can absolutely handle the power, the RXT will handle more abuse without overheating. Either of those clutches are noisy.
Maybe there's something from Hayes, RAM, Centerforce, or Monster that have dampening springs which will make the clutch much quieter.
Or go all in and get a Mantec clutch for $$$$.
-SS454- is online now
post #13 of 21 (permalink) Old Apr 24th, 19, 2:41 PM
What I REALLY covet is a Long Shifter....... had one mounted to the Richmond 5 I ran for a while. loved it vs the Hurst. Maybe the reason I opted to replace the CF DF disc and run my old clutch.
rodent4 likes this.
post #14 of 21 (permalink) Old Apr 24th, 19, 3:54 PM
They are a nice shifter, and well worth the extra few bucks
rodent4 is offline
post #15 of 21 (permalink) Old Apr 24th, 19, 5:14 PM
jerry
Not sure Long makes linkage and mounting plate variants to fit all the popular apps. I'm next to certain they don't adapt to a factory '68-'72 chevelle tunnel.
I personally have no gripes when it comes to a well prepped hurst shifter.
cheveslakr is online now
Electric Fan for a 396 bbc roberto70chevelle Heating & Cooling 35 Jul 1st, 15 6:31 AM
Radiator/fan decision 72 468/400chevelle Heating & Cooling 14 Mar 30th, 15 2:30 PM
Clutch Chatter alhewitt Transmission & Driveline 15 Feb 2nd, 15 12:15 PM
Cooling issues Boneshaker8 Heating & Cooling 19 Nov 1st, 14 11:55 PM
