Moser 12 bolt - order it shortened or no? - Chevelle Tech
 5Likes
  • 1 Post By SEJ66
  • 1 Post By Malibu ss 64
  • 1 Post By SSJohn
  • 2 Post By big gear head
post #1 of 11 (permalink) Old Apr 13th, 19, 6:10 PM Thread Starter
Send a message via AIM to SEJ66
Having a Moser 12 bolt built for my 66 Chevelle. Should I take 1" off both sides just to reduce needed back space or not? The car will see no track time but I am building for more of a pro touring type of setup.
Also any thoughts on keeping the front and rear wheel size the same for tire rotation needs? The car won't be driven much so I'm thinking that is not needed.
72LS3Z27 likes this.
SEJ66 is offline
post #2 of 11 (permalink) Old Apr 13th, 19, 6:20 PM
Marcus
Re: Moser 12 bolt - order it shortened or no?
If you like deeper wheels with more backspace like me. YES!
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is offline
post #3 of 11 (permalink) Old Apr 13th, 19, 6:34 PM
Have you figured out how much room you will have before you run into issues with the shock mounts and inner fenders?
Steve R is offline
post #4 of 11 (permalink) Old Apr 13th, 19, 7:29 PM Thread Starter
Yes, with the Moser diff no problem with the shock mounts. I called Moser and asked them. Inner fender should be fine, just have to measure for correct back space and my wheel won't be too wide.
SEJ66 is offline
post #5 of 11 (permalink) Old Apr 13th, 19, 11:10 PM
Clint
Just be prepared to pay more, for custom wheels w/less offset, with a narrower rear.
Clint Hooper
Sold
Sold
Clint44 is offline
post #6 of 11 (permalink) Old Apr 14th, 19, 1:00 PM
I had Moser shorten the tubes on my 12 bolt to accommodate my 15x10s with 4 b/s. Also had the big ford ends installed. No problems with shock mounts, wheels/tires are centered in the wheel wells.
SEJ66 likes this.
SSJohn is offline
post #7 of 11 (permalink) Old Apr 14th, 19, 7:59 PM Thread Starter
Dot you recall how much you had it shortened? 10" wide plenty for what I'm looking for.
Thanks John
SEJ66 is offline
post #8 of 11 (permalink) Old Apr 14th, 19, 9:30 PM
Thanks John
According to Moser, the diff is a bit offset for a bodies, it was a different length for each side. I don't remember how much, that was about four years ago. If you call them they will tell you how much can be taken off of each end.
SSJohn is offline
post #9 of 11 (permalink) Old Apr 15th, 19, 8:46 AM
Freddie
All Chevy car rear ends have the pinion offset 1/2 inch to the right. Axles are the same length on both sides. The same amount is taken off of both sides when narrowing.
Malibu ss 64 and SEJ66 like this.
big gear head is offline
post #10 of 11 (permalink) Old Apr 15th, 19, 1:18 PM
This should be cast in stone so that others don't fall victim to misconceptions.
zookpr is offline
post #11 of 11 (permalink) Old Apr 15th, 19, 1:58 PM
Just relaying what Moser told me, maybe they dont know the real answer. I never measured when I received the rear end, but it did fit perfectly.
SSJohn is offline
Moser 12 bolt same dimensions as GM 12 bolt? -SS454- Transmission & Driveline 8 Apr 6th, 18 8:41 PM
Bolt in axle Question - 8.5" 10 bolt rear mjblum Transmission & Driveline 3 Jun 13th, 17 8:23 PM
Moser 12 bolt and Hotchkis Suspension Upgrade: Need Opinions btole79 Brakes, Suspension & Steering 17 Nov 24th, 16 10:32 PM
Moser 12 bolt in. - questions Bullcrappy Transmission & Driveline 5 Sep 14th, 16 1:45 AM
Safety Issue Warning Moser 12 Bolt Muscle Pak USMC_Spike Performance 25 Oct 6th, 15 11:11 PM
