73-77 Chevelle 10 bolt - Chevelle Tech
  • 1 Post By M.Maner
post #1 of 7 (permalink) Old Apr 2nd, 19, 10:06 AM Thread Starter
I believe that some or possibly all of the suspension mounting locations changed after the 72 models, what I would like to find out is if anyone might know if the upper control arm mounts on the rearend housing changed at this time? Any help would be appreciated.
M.Maner is offline
post #2 of 7 (permalink) Old Apr 2nd, 19, 11:27 AM
Freddie
Re: 73-77 Chevelle 10 bolt
Yes, the eyes on top of the housing are in different locations and the angle of the eyes is different.
big gear head is offline
post #3 of 7 (permalink) Old Apr 2nd, 19, 3:00 PM
I agree, because I have BOTH body styles (76 Cutlass, 68-70 Chevelles), and I have discovered something that few people are aware of.
For the 73-77 A-bodies there WAS 12bolt rear available. I have found a VERY, VERY few of these 73-77 style 12bolt rears on SOME, repeat, SOME El Caminos and Cutlass wagons------------and maybe some Pontiacs(?????).
The down side of these mid-70s 12bot rears is that the gear ratios were VERY LIMITED, such as 2.73-3.08!!! AND, AND, AND they were available with an Eaton posi. I have one of these 12bolts (from a 76 Cutlass wagon). The 76 12bolt that I have is a 2.73 NON-posi, BUUUUUUUUUUT, one of my boys came across a Pont 2-series posi unit that I plan to install into the 76 12bolt rear.
From what little information that I have acquired about these mid-70s 12bolts is that the 73-76 versions had 31spline axles/axle gears and the 77 versions had 28splines.
These mid-70s rears are often over looked BECAUSE the differential cover has only 10 bolt holes and 2 big notches, thus, it seems most people think they are a 10bolt rear. NOT!
Oh ya, and the mid-70s Eaton posi unit is bigger and more robust than the 65-72 style Eaton posi units.
Here is what the cover of one of these mid-70s 12bolt rears looks like. This type of rearend has the typical fill plug on the side of the cast iron case, BUUUUUUUUUUUT, I discovered that SOME of these rears have a cover with a fill plug as below. In my book, that's a plus.
Here is a comparison of a 65-72 style 2-series (NON-posi) 12bolt differential and a mid-70s 12bolt Eaton 2-series posi (right) differential. As can be seen, the mid-70s posi is noticeably bigger than the 65-72 style. Also, the mid-70s ring gears used larger, LEFT hand thread bolts.
Soooooooooooo, if you should locate one of these mid-70s 12bolt posi rears, they would be an excellent rear to have------------------if you can live with the limited, much higher gear ratios.
Tom Parsons
TC# 474
#3 FOREVER!!!!!
DZAUTO is offline
post #4 of 7 (permalink) Old Apr 2nd, 19, 7:51 PM
Looks like an 8.5" 10-bolt especially where you mention the 7/16" left-hand thread ring gear bolts. Does it have bolt-in axles like this one?
USAF Retired (1968-1988)
David Bates is offline
post #5 of 7 (permalink) Old Apr 2nd, 19, 7:54 PM
SFD
It is, also called the GM corporate 8.5.
SFD is offline
post #6 of 7 (permalink) Old Apr 5th, 19, 9:32 AM Thread Starter
Freddie, I really appreciate the help.
big gear head likes this.
M.Maner is offline
post #7 of 7 (permalink) Old Apr 6th, 19, 12:22 AM
Cam
Cameron Milne
Those rear ends Tom (DZAUTO) is speaking of were used on all A-body wagons (Chevelle, LeMans, Cutlass & Century). The corporate 8.75" 10-bolt. They can be found under many a Cutlass, the rare Grand Prix 455 and oddly enough, not the El Camino (even an LS4 M21). I think the center section may have been originally used on sixties Big Pontiacs through '70, then the big motored 1971-76 B-body barges & wagons.
There was a time when each GM division used their own engines & differentials.
"The more you know,
TC Gold #120
Cam is offline
12 bolt out of 69 chevelle Twebb50 What's it worth? 15 Apr 1st, 17 10:37 PM
1966 Chevelle 12 bolt posi for $800 on CL 64tempestwagon Brakes, Suspension & Steering 1 Mar 17th, 16 2:43 AM
Informational Post / Convert 10 to 12 bolt rear upper control arm SS70ElCaminoOwner Brakes, Suspension & Steering 3 Mar 6th, 15 3:08 PM
Rod bolt strength, what do we REALLY NEED? 540 RAT Performance 25 Mar 3rd, 13 10:55 PM
