TKO 600 Installed - Chevelle Tech
 8Likes
post #1 of 16 (permalink) Old Mar 6th, 19, 3:36 PM Thread Starter
Pat
TKO 600 Installed
Picked up my 70 yesterday after having the TKO 600 from Silver Sport installed. Went in very easy with just a very minor modification around the shifter hole. NO tunnel mods needed. Only got to pull it up and off the trailer and drive it into the garage but the hydraulic clutch sure feels nice!.
Now just need spring to get here so I can road test it.
Pats70ss is offline
post #2 of 16 (permalink) Old Mar 6th, 19, 4:20 PM
Re: TKO 600 Installed
I have a TKO 600 in my 70 also, I absolutely love it and I think you will be real happy with yours. I've got the one with the close ratios and with 3.73 gears in the rear it's a good. combination.
V1rotate is offline
post #3 of 16 (permalink) Old Mar 6th, 19, 5:41 PM
Al
Cool. When the weather improves, come over and give me a test ride. I'd love to check it out. I'll settle for a video.
Pats70ss likes this.
DUTCH MAX HEADWORK is offline
post #4 of 16 (permalink) Old Mar 6th, 19, 11:42 PM
I just had a TKO 600 installed, with hydraulic clutch, in December. The weather needs to warm up some more so I can drive the $#it out of the car. Cmon spring, dammit!
Restomodded 1970 Chevelle SS
Dkar26 is offline
post #5 of 16 (permalink) Old Mar 7th, 19, 6:02 AM Thread Starter
Pat
Hey Al,
I do hope to do more highway driving this year but Cali may be a bit of a stretch!
Pats70ss is offline
post #6 of 16 (permalink) Old Mar 7th, 19, 8:48 AM
Was you 70 an original 4 speed car or an automatic? Thanks.
Nerfherder396 is offline
post #7 of 16 (permalink) Old Mar 7th, 19, 9:15 AM Thread Starter
Pat
4 speed.
Pats70ss is offline
post #8 of 16 (permalink) Old Mar 7th, 19, 11:53 AM
Todd
Any mods to the cross member or holes in the frame to move it forward or back?
91c1500sleeper is offline
post #9 of 16 (permalink) Old Mar 7th, 19, 1:03 PM Thread Starter
Pat
They made some minor mods to the crossmember to get everything to fit up properly. Said they basically just modified the perch where the trans bolts to the crossmember.
Pats70ss is offline
post #10 of 16 (permalink) Old Mar 7th, 19, 1:44 PM
Todd
Great thanks for the info. I'm in the process of building my 65'. I too went with the TKO 600 with the upgrades. I'm probably overbuilding the car but I'd rather pay a lil now than more later. I'm going to be fabing my crossmember.
post #11 of 16 (permalink) Old Mar 7th, 19, 1:52 PM
Todd
post #12 of 16 (permalink) Old Mar 8th, 19, 7:05 PM
p40
butch
did u have to change the drive shaft or front yoke ?
p40 is offline
post #13 of 16 (permalink) Old Mar 9th, 19, 7:56 PM Thread Starter
Pat
New driveshaft came with the transmission
Pats70ss is offline
post #14 of 16 (permalink) Old Mar 16th, 19, 9:13 PM
Iíve been considering going to the TK 600 as well. I spoke with the guy at Silver Sports Transmission about this. My concern was the need to modify the tunnel for proper clearance. He told me that most 70 Chevelles need some modifications due to body mount bushings collapsing over time, thus lowering the body onto the frame. Also, it seems almost mandatory to go to a hydraulic clutch release vs mechanical stock.
My other option is the Gear Vendor overdrive unit to reduce highway revs. Itís about the same cost, give or take $200. My Muncie M20 is in good shape other than 1 to 2 sticky shifts. Still kicking this around so I really enjoyed reading of your experiences. It sure seems all of you are thrilled with the TK. Apparently some of you had it done at Silver Sports. I didnít know they also installed them.
MELBOURNE, Florida
Melb-Mike is offline
post #15 of 16 (permalink) Old Mar 16th, 19, 11:58 PM
Justin
Originally Posted by Melb-Mike View Post
I’ve been considering going to the TK 600 as well. I spoke with the guy at Silver Sports Transmission about this. My concern was the need to modify the tunnel for proper clearance. He told me that most 70 Chevelles need some modifications due to body mount bushings collapsing over time, thus lowering the body onto the frame. Also, it seems almost mandatory to go to a hydraulic clutch release vs mechanical stock.
My other option is the Gear Vendor overdrive unit to reduce highway revs. It’s about the same cost, give or take $200. My Muncie M20 is in good shape other than 1 to 2 sticky shifts. Still kicking this around so I really enjoyed reading of your experiences. It sure seems all of you are thrilled with the TK. Apparently some of you had it done at Silver Sports. I didn’t know they also installed them.
MELBOURNE, Florida
The McLeod 5 speed is a good alternative
JF74chevelle is online now
TKO Shift Handle Adjustment rkd Transmission & Driveline 0 Jun 7th, 15 1:15 PM
any tko 600 holiday specials [email protected] Transmission & Driveline 0 Dec 8th, 13 11:22 AM
Best clutch kit Tremec TKO 600 650HP jketron Transmission & Driveline 3 May 28th, 13 11:49 PM
TKO 600 in a 66 chevelle skb.885 Transmission & Driveline 11 Dec 31st, 12 6:45 PM
best gear for TKO 600 blown496 Transmission & Driveline 7 Dec 5th, 12 6:53 AM
