Fab it or buy one? - Chevelle Tech
  • 1 Post By Pioneer4x4
post #1 of 9 (permalink) Old Mar 3rd, 19, 10:09 AM Thread Starter
Todd
Fab it or buy one?
So I need to take care of the trans crossmember on my build. I'm still debating weather to buy a crossmember or fab one up. Who has fab'd their own? I used Hellwig's boxing kit on the frame so the stock crossmember bolt holes are covered and no longer available. I do have the supplied weld on brackets for the crossmember to bolt to. Do I just find a stock crossmember and cut it to size or get some different steel material and fab my own? Also want to know if when the engine and trans are sitting in the frame do they need to be level or 3* down angle?
91c1500sleeper is offline
post #2 of 9 (permalink) Old Mar 6th, 19, 2:46 AM
Re: Fab it or buy one?
3* down in back.
build your own. Take note of the size, shape and vertical positioning of the trans mount tab. The crossmember of a Chevelle sits on top of the lower frame rail.
post #3 of 9 (permalink) Old Mar 6th, 19, 7:33 AM Thread Starter
Todd
Originally Posted by Tom Mobley View Post
3* down in back.
Thanks for the response. So from what I have read and talked with some knowledgeable people the motor sits on the mounts in it's normal position near level with the frame. The transmission attached lies with the motor near level. The Hellwig kit supplied the mounting plates that need to be welded to give the same mounting orientation as stock. I will cut some metal here at work today and fab the crossmember when I get the motor and trans back in the frame. Once the 3rd member and axles show up I will get the rear suspension installed back in the frame and turn the pinion up 3*.
My other confliction is measuring the driveshaft. If the car needs to be built and sitting on the tires under it's own weight how does one measure if ya can't get under the car? It's stance is gonna be 2" lower in the front and 3-4" in the back. Can't I just leave the body off and have a 200+ pound human sit on each corner and then measure it?
post #4 of 9 (permalink) Old Mar 6th, 19, 8:43 AM
Originally Posted by 91c1500sleeper View Post
...If the car needs to be built and sitting on the tires under it's own weight how does one measure if ya can't get under the car? It's stance is gonna be 2" lower in the front and 3-4" in the back. Can't I just leave the body off and have a 200+ pound human sit on each corner and then measure it?
Put is on ramps/blocks. I use ramps way more than I use a jack. My driveway is sloped, so I put the ramps downhill, so it is easier to get on them, and if there is a problem, it will roll "uphill". I can do everything with normal ramps that doesn't require removing wheels.
Mine look like this, I got them at Montgomery Ward in early 1980s... (if you get any, get removable ramp ones)
91c1500sleeper likes this.
Pioneer4x4 is offline
post #5 of 9 (permalink) Old Mar 8th, 19, 7:27 AM Thread Starter
Todd
3* down in back.
One more thing to clear up before I make the cross member. The pad that the transmount sits on is it level with the bottom lip of the frame? If not is there anyone that can give me a measurement from the bottom lip to the mounting pad on the cross member?
post #6 of 9 (permalink) Old Mar 21st, 19, 8:17 AM Thread Starter
Todd
So I have the 3rd member and axles installed in the 9 inch housing. I don't know if it's just my eyes or is the yoke a few inches over to the passenger side of where the tailshaft will sit? If there is an offset from the tailshaft to the rear end yoke is the U-joint going to make it be satisfied and run right? I have no experience running a 9 inch in a chevy or even a ford. I searched for the answer to no avail.
post #7 of 9 (permalink) Old Mar 21st, 19, 8:33 AM
Lemon's Headers makes a very nice crossmember for our cars. They come raw, I had mine powdercoated. Lemons Headers Online :: A Closer Look
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #8 of 9 (permalink) Old Mar 21st, 19, 3:22 PM Thread Starter
Todd
He sells them for $260. Can you tell if the trans mount pad is level with the frame mounting pads? I'm trying to find out if there is a difference in the two.
post #9 of 9 (permalink) Old Mar 21st, 19, 7:54 PM
Todd, I honestly wouldn't be able to take a measurement like that.
Knowing that Dan Lemon does stellar and dead on balls accurate work, I'd say it's safe to assume the mounting pad for the transmission mount is exactly where it belongs.
How may I help you?
1999 Trans Am-500hp
This Thread is more than 480 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Best place to buy new glass? 69Chev427 Restoration Corner 9 Apr 3rd, 15 10:17 PM
Help me decide to buy: Yay or Neigh.... 68Rusty What's it worth? 32 Jan 24th, 15 6:52 PM
Where to buy a 69 proportioning valve?? ToocoolZ28 Brakes, Suspension & Steering 2 Aug 7th, 14 9:40 PM
Help with trim on the trunk lid on a 67, and best place to buy Chevell 67malibutahoeturquoise Restoration Corner 2 May 15th, 14 8:07 PM
To buy or not to buy??? Dble07 Wagons & Four Doors 4 Apr 16th, 13 8:25 PM
