Mini tubbed = shorter axles? - Chevelle Tech
 4Likes
  • 1 Post By Steve69SS396
  • 3 Post By big gear head
post #1 of 7 (permalink) Old Mar 2nd, 19, 6:17 PM Thread Starter
Those that have mini tubbed their cars, did you go with a narrower rear end?
I've been thinking of swapping gears in my current 12 bolt, or buying a new Moser rear end. But I'd hate to buy stock sized 70-72 rear end to find it's too wide if I ever do the planned mini tub. I was thinking of having axles 1/2" shorter for a 1" narrower rear end to bring the wheels closer to the frame when I run wider tires.
Youtube Channel.
Instagram:
Twitter:
-SS454- is offline
post #2 of 7 (permalink) Old Mar 2nd, 19, 6:41 PM
Re: Mini tubbed = shorter axles?
I mini-tubbed my '69 Camaro years ago. Before doing that I put a 9" under it out of a '67 Mustang. The swap was real easy because the rear was 1.5" narrower than the stock rear. When I mini-tubbed it I went even narrower on the rear because I planned on running the same wheels. You might be able to swap wheels with more backspace and not touch the rear.
Before and after mini-tubbing. Before I ran 28X10" slicks, after I went to 29X12". Now it sits down over the wider tire better.
ID:	587820   Click image for larger version
ID:	587822   Click image for larger version
-SS454- likes this.
'69 Camaro - 429 SBC Dart Iron Eagle 9.325" block, Crower crank, Crower 6" Billet rods, Ross pistons (10:1), Total Seal S/S rings, AFR 245 heads, T&D steel rockers, Cloyes Timing Set, 4-7 swap solid roller 274/286 @ .050", .704" lift, Dart single plane, Dominator EFI, Stef's #1705R pan, F2 Procharger on E85
Steve69SS396 is offline
post #3 of 7 (permalink) Old Mar 2nd, 19, 6:59 PM
Freddie
The rear end width depends on the wheels that you are using, not the width of the tubs. You can run wheels as wide as you want with a stock width rear end as long as the wheel back spacing is right.
The '64 to '67 Chevelle rear ends are 1 inch narrower than the '68 to '72 rear ends. If you get a new rear end then you can have it built to the earlier width if you want a little less back space on the wheels. You can go a little narrower than that if you want, but if you go more than 1 1/2 inches narrower than the early rear end then you are going to be getting into trouble with the lower control arms brackets.
Clint44, Steve R and Kirk's67SS like this.
big gear head is online now
post #4 of 7 (permalink) Old Mar 2nd, 19, 8:17 PM Thread Starter
Right now I have 15x10 with 5.5" BS. I have 3 sets of wheels.
I would like to have the ability to run a Goodyear 8.00-15 Bluestreak road race tire, which is advertised at 13.2" wide. Rather than getting new wheels for that, I could run a narrower rear end to center the 15x10 in the wheelwell for when I run those tires. This would mean I'd need to run a 1/2" spacer during street and drag racing (if I keep the 295/55R15s). Many hate spacers, but with a 1/2-20x 3" ARP stud, I think it'd be okay.
Youtube Channel.
Instagram:
Twitter:
-SS454- is offline
post #5 of 7 (permalink) Old Mar 3rd, 19, 5:36 AM
Marcus
When I installed a 12 bolt from a 70 Chevelle in my 64 I had it narrowed around 1.5Ē/side(from 30 1/16Ē axle lenght to 28 1/2Ē) its possible to narrow little more before you get in to trouble with the control arm brackets but I had to ĒreverseĒ the shock mounts to clear the backing plates. I only did it so I could use wheels with more backspace since I like the look of deeper wheels.
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
57 3/4Ē wide 12 bolt: Eaton posi, Us gear 3.31, Toms KA 33 splines axles
Malibu ss 64 is online now
post #6 of 7 (permalink) Old Mar 4th, 19, 12:05 AM
Clint
A 15x10 wheel w/5.5" backspace (0 offset) will be located close to dead center in the wheelwell. Before I spent all that money to mini-tub it and narrow the rear, I would first try fitting a pair of those Blue Streaks. They might fit w/o all that extra work. However, if you have plans to fit at least a 12" width wheel and 335 tire, a mini-tub is required.
Clint Hooper
Sold
Clint44 is offline
post #7 of 7 (permalink) Old Mar 4th, 19, 10:11 AM Thread Starter
My 295s have rubbed with hard cornering. I had to bang in the inner wheelwell for better clearance. 295s are 12.2" wide, wouldn't be able to fit 13.2. This is all future planning, and I figure I may one day want to try some 18" track tires, in which case I'll shove as much rubber under the car as possible.
Youtube Channel.
Instagram:
Twitter:
-SS454- is offline
Axles for a 67 12 bolt Kopfjaeger Transmission & Driveline 3 Jan 14th, 18 1:19 AM
8.5 Inch 10 Bolt Axles... WakkoWarner Transmission & Driveline 7 Oct 9th, 16 7:48 PM
70 Chevelle 427 LSX 6sp magnum mini tubbed Pro10LVN Pro Touring 48 Jun 27th, 16 9:47 AM
74 vega wagon mini tubbed Jebchevelle What's it worth? 15 Apr 3rd, 16 11:13 PM
Axles for 1970 SS-396 Mark2Mac Restoration Corner 5 Dec 30th, 12 2:02 PM
