Best pan gasket for a T400? (yeah..seriously) - Chevelle Tech
 17Likes
post #1 of 51 (permalink) Old Feb 22nd, 19, 4:37 PM Thread Starter
Alan
So I've changed my pan gasket three times with different brands of cork gaskets, the last time I switched to a deep cast aluminum B&M pan and a Cometic cork gasket, and in 300 miles, its seaping, leaking again.
Anyone have a lead on a super duper pan gasket that WON'T leak? I only want to change it once more so...I'm not worried about cost..
Thanks in advance for any suggestions or tips of wizardry to stop a pan from leaking...
Rubber? Moroso Perm Align? duct tape?
1971 Corvette
VortecPro 496"
T400, Tight 10" converter
3.36 gears, 3700lb raceweight
[email protected], 1.51 60'
STOCK APPEARING
ShouldntBeHere is offline
post #2 of 51 (permalink) Old Feb 22nd, 19, 4:54 PM
Have you tried re snugging up the bolts?? Be careful not to over tighten but I have snugged mine back up a couple times and it helps !
Shbradford is offline
post #3 of 51 (permalink) Old Feb 22nd, 19, 4:57 PM Thread Starter
Alan
Re: Best pan gasket for a T400? (yeah..seriously)
Yeah, I did that after a couple hundred miles on every pan gasket I've had on it. Finally I gave up on the original steel pan, went to the B&M cast pan with a thick flange... The fluid seems to just seap right through the cork.
I'm thinking rubber gasket next time.
1971 Corvette
VortecPro 496"
STOCK APPEARING
post #4 of 51 (permalink) Old Feb 22nd, 19, 5:06 PM
Kerry
I have only tried the cellulose one (which seeped slightly), and a cork (which leaks far too much) with my B&M deep cast pan. I would think the Moroso 93103 would be best given it is designed like their valve cover gaskets (which seal perfectly with my GM cast valve covers) and the Fel Pro oil pan gasket of the same design.
ShouldntBeHere likes this.
pockets is offline
post #5 of 51 (permalink) Old Feb 22nd, 19, 5:12 PM
Mark
Something like this might work with your aluminum pan.
https://www.summitracing.com/parts/mor-93103
Dang it Kerry!
ZZ502 Short block
Holley Avenger MPFI
612HP/594TQ
MarkP is offline
post #6 of 51 (permalink) Old Feb 22nd, 19, 5:21 PM Thread Starter
Alan
Dang it Kerry!
Yeah that looks like a good one.... Maybe worth a try. Lemme read some reviews on it...
It seems like sealing a trans pan is black magic. I've never seen more conflicting opinions and methods on anything...
1971 Corvette
VortecPro 496"
STOCK APPEARING
post #7 of 51 (permalink) Old Feb 22nd, 19, 5:37 PM
I use the moroso one on my th350 with a cast pan. No leaks and I haven't touched it for almost 2 years now.
ShouldntBeHere and pockets like this.
82c10step is offline
post #8 of 51 (permalink) Old Feb 22nd, 19, 5:55 PM Thread Starter
Alan
I just ordered the Moroso 93103. Hoping for the best. Trying to hit the track next Friday and donít want to take any chances...no drip drips...
1971 Corvette
VortecPro 496"
STOCK APPEARING
post #9 of 51 (permalink) Old Feb 22nd, 19, 6:12 PM
Will
I donít have a definitive answer because I donít have near the experience that others have, but I have had success on my 6l90e, 4l80e and 4l60eís by using a torque wrench and tightening in stages in a pattern like a cylinder head. I havenít had any problems getting any to seal up, but maybe they offer a better gasket for these newer transmissions. I have done it twice in the last 6months on 6l90es with no leaks. If you are already doing this, disregard my comments
yelchevelle is offline
post #10 of 51 (permalink) Old Feb 22nd, 19, 6:24 PM
Kevin
I ended up putting Toyota gasket sealer on my 200-4R (making sure it doesn't get inside) with a cast pan, rubber gasket and no more leaks.
"If you're not living on the edge, you're taking up too much space" - Jim Whittaker
AFR Eliminator 195's
Inglese 50mm 8 stack injection
FAST XFI Street
SC&C Stage II Plus suspension
Hotchkis/Hellwig sway bars
Tremec TKO 600
Chevy67 is offline
post #11 of 51 (permalink) Old Feb 22nd, 19, 6:40 PM Thread Starter
Alan
Yeah for some reason, on the newer trannies, this doesn't seem to be a problem. I've had the pan off of my C7Z (8l90) and my wife's SS Camaro (8l90) and used the gm rubber gaskets and neither one seaps a drop.
On an RPM 4l60e, I had a cast pan on it with a cork gasket and it seaped all the time too....but not as bad as my T400 now.
Hopefully the moroso gasket will help. And yeah I always snug it up in a criss cross pattern and in stages. Never get it more then snug with a 3/8" ratchet. Guess I need to torque wrench it...
1971 Corvette
VortecPro 496"
STOCK APPEARING
post #12 of 51 (permalink) Old Feb 22nd, 19, 7:03 PM
Permatex High Tack works well on trans pan gaskets.
69 461" BBC 11.25:1 Compression
Orig Exhaust Manifolds
Straub (Clay Smith) Hyd Roller cam, 288/300 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is offline
post #13 of 51 (permalink) Old Feb 22nd, 19, 7:27 PM
https://www.lubelocker.com/product/llt-g400/
71350SS, ShouldntBeHere and rp930 like this.
Mike Lewis street 572
Cale Aronson
Black Magic clutches
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #14 of 51 (permalink) Old Feb 22nd, 19, 7:45 PM
George
I've used the cork gasket on my T350.......but I used that Indian Head shellac or whatever on it...also used the rubber with the same stuff, no leaks.
'71 Malibu
355 [email protected]
125 [email protected]
383 Mud Motor- [email protected]
100 shot [email protected]
Geo71 is offline
post #15 of 51 (permalink) Old Feb 22nd, 19, 8:49 PM
Cast aluminum pan with a steel core gasket.
badrad and ShouldntBeHere like this.
'69 Camaro - 429 SBC Dart Iron Eagle 9.325" block, Crower crank, Crower 6" Billet rods, Ross pistons (10:1), Total Seal S/S rings, AFR 245 heads, T&D steel rockers, Cloyes Timing Set, 4-7 swap solid roller 274/286 @ .050", .704" lift, Dart single plane, Dominator EFI, Stef's #1705R pan, F2 Procharger on E85
Steve69SS396 is offline
Oil pressure drop!! Joeyp Engine 32 Mar 16th, 17 9:33 PM
Permatex Ultra Black RTV vs oil pan gasket Paul J Engine 15 Sep 19th, 15 12:41 PM
Oil Pan Gasket Problem Trq Hungry Wombat Engine 5 Jun 24th, 13 4:15 PM
Can The Right Stuff by Permatex Be Used As An Oil Pan Gasket? blue_69_malibu Engine 14 May 10th, 13 10:49 PM
