LS with older transmission - Chevelle Tech
 3Likes
  • 1 Post By hessz24
  • 1 Post By JodysTransmissions
  • 1 Post By crashent
post #1 of 10 (permalink) Old Jan 29th, 19, 8:27 PM Thread Starter
kenneth
To use a Muncie / Borg Warner 4 speed with an LS series engine , what bellhousing ? Using a regular LS flywheel , not a “ thick “ flywheel . TIA
1965stlhrsrdr is offline
post #2 of 10 (permalink) Old Jan 31st, 19, 7:53 PM
hessz24 is offline
post #3 of 10 (permalink) Old Feb 3rd, 19, 1:56 PM
Andrew
Re: LS with older transmission
Look at my 70 GTO build. I used a Richmond 6 speed, but using a Muncie is exactly the same parts.
Andrew
Instagram @projectgattago
Please get in touch for Holley EFI tuning services.
andrewb70 is offline
post #4 of 10 (permalink) Old Feb 5th, 19, 11:06 PM
Jody
Originally Posted by 1965stlhrsrdr View Post
To use a Muncie / Borg Warner 4 speed with an LS series engine , what bellhousing ? Using a regular LS flywheel , not a thick flywheel . TIA
I use the QuickTime RM-6036 for this exact application; LS to Muncie/ST10 etc.
1965stlhrsrdr likes this.
Jody Haag
Most 4, 5, and 6 Speed Repairs, Parts, Service & Custom Installations
610-413-8015
JodysTransmissions is offline
post #5 of 10 (permalink) Old Feb 6th, 19, 7:41 AM
There is an article in the April 2019 issue of Hot Rod magazine and on Hot Rod Network on line on this topic.
USAF Retired (1968-1988)
David Bates is offline
post #6 of 10 (permalink) Old Feb 6th, 19, 11:33 AM
If you look close you might notice they used a truck bell housing with the large bearing retainer hole and didn't use the spacer to center the trans, and put the center line of the trans in line with the center of the crank...
BIG problems coming later on... Crash
crashent is offline
post #7 of 10 (permalink) Old Feb 6th, 19, 12:22 PM
Justin
So it the trans only being aligned by putting the bolts in? Instead of the bearing retainer fitting snuggly into the bellhousing? If so that’s pretty sketchy
JF74chevelle is online now
post #8 of 10 (permalink) Old Feb 6th, 19, 1:46 PM Thread Starter
kenneth
Wanting to stay away from the $700 Quick Time .
post #9 of 10 (permalink) Old Feb 6th, 19, 1:48 PM Thread Starter
kenneth
Bought the 621 replica , for the application , from Silver Sport Transmission . Thanks
post #10 of 10 (permalink) Old Feb 6th, 19, 4:48 PM
After reading your reply I actually looked at the article/photos and that fact is painfully obvious in the photo of the release bearing and stainless lines. That's a major faux pas on their part!
This Thread is more than 474 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
