Rear end identification - Chevelle Tech
 4Likes
  • 4 Post By big gear head
post #1 of 5 (permalink) Old Jan 20th, 19, 5:01 PM Thread Starter
Good after noon all I’m new to the site here. Having a real hard time trying to figure out if I have a 7.5 or 8.5 rear in my 1968 chevelle sport coupe I believe it’s the stock rear the numbers I found on the tube are csc70882i can’t really find anymore numbers but it looks like the coil spring perches were added on so I don’t understand any help or info or a process of elimination or dimensions to check would be so helpful thanks
ID:	583992   Click image for larger version
ID:	583994   Click image for larger version
Maddogmikeyb is offline
post #2 of 5 (permalink) Old Jan 20th, 19, 9:03 PM
Freddie
Re: Rear end identification
It's the 8.5, but it doesn't look like an A body rear end. I think someone has modified a later 8.5 and installed it in your car. The 8.5 was not produced until '71, so it can not be original to your car. If your car came with a 10 bolt it would have been the 8.2. The 7.5 was never used in these cars.
Please use periods and capital letters so that this is easier to read. I had to read this 3 times to figure out what you were saying.
big gear head is offline
post #3 of 5 (permalink) Old Jan 21st, 19, 1:57 AM
The position of the upper control arm ears look similar to a 73-77 A body rear end. I agree with Freddie, grammar is horrible and difficult to read.
dell72 is offline
post #4 of 5 (permalink) Old Jan 21st, 19, 1:01 PM Thread Starter
Thank you very much. Sorry for the improper grammar and punctuation. I will work on it. Thanks for the knowledge excited it’s a 8.5.
post #5 of 5 (permalink) Old Jan 21st, 19, 2:57 PM
Freddie
Where are you located?
This Thread is more than 395 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
