Here was part 1 after having no clutch from changing the flywheel. https://www.chevelles.com/forums/33-transmission-driveline/1070644-clutch-release-arm.html
I still have no clutch. I had thought perhaps the pressure plate was stuck to the flywheel but it's all so new and clean. I don't know how that could be.
This video shows the throw out bearing fully engaging the pressure plate. It almost looks like it's pushing it too far now.
https://www.flickr.com/gp/164440338@N03/eq9171
I'm at my wits end with this. I could pull it apart again but have no idea what I'd be looking for.
After I put it all back together I had a bad knocking sound. It turns out the dust cover was hitting on the crankshaft. I took it back apart to fix that. I also added another spacer to the adjustable throwout bearing.
