4L65E fittings - Chevelle Tech
post #1 of 4 (permalink) Old Jul 15th, 18, 9:26 AM Thread Starter
Michael
4L65E fittings
Anyone know what fittings are used for a tight fit for my 4L65 swap into my 64? Ive seen where it can be a tight fit and a BFh has to make some room, would rather not have to do that.
64 Chevelle
85 Monte Carlo SS
Mikes64 is offline
post #2 of 4 (permalink) Old Jul 15th, 18, 10:02 AM
Re: 4L65E fittings
The thread into the transmission is 1/4 inch STRAIGHT pipe. It has a sealing washer. Like this:
https://www.summitracing.com/parts/ear-940006erl
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #3 of 4 (permalink) Old Jul 16th, 18, 7:23 AM Thread Starter
Michael
Re: 4L65E fittings
I guess I can come off of those with a couple 90s to some kind of flexible lines to keep it tight?
64 Chevelle
85 Monte Carlo SS
Mikes64 is offline
post #4 of 4 (permalink) Old Jul 17th, 18, 12:43 AM
Pete
Re: 4L65E fittings
The top port is very close to the floor pan. I had AN6 fittings and lines ready to use, but they came out of the tran's too far, and no amount of "massaging" the floor pan would help. So I switched to stock lines for a 1999 Blazer.
PART# 624-100A and 624-101A ($15 each)
They snap in like stock, and hug the trans and the LS block. No problem with the headers.
I then cut and flared them right at the front of the motor and went with rubber line to the Trans cooler.
I cut a 2x2 square hole in the trans tunnel to get the top line to not hit the floor. But if the trans was out I could have probably dented up the floor to get it to fit.
__________________________________________
1970-1 Chevelle (307ci w/PG) Now LS 6.0 w/4l60E
Progress Pics.
LS Swap
BigOiBoy is offline
This Thread is more than 582 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
