200-4r swap prep - Page 2 - Chevelle Tech
 3Likes
post #16 of 28 (permalink) Old May 22nd, 18, 10:22 AM
Re: 200-4r swap prep
Originally Posted by Dansk View Post
I wonder what lockup really buys you in real world classic car driving. I could say cooler run temperatures and better fuel economy but if I think of how my chevelle is really used there is limited high speed highway use, it's mostly around town and trips to car shows so I think Steve might be right. I'd like to hear what others think. I already went the route of having it though. I guess if it is any sort of a hassle I could just stop powering it.
Both my Camaro and Monte are probably driven on the highway more than around town. Around town i dont bother with the lockup, thats why both cars have it on a toggle. on the highway, when the converter locks, the car just starts to roll down the highway, good thing the brakes work well. It really makes driving it 80 miles each way such a pleasure not having the old and tired engine screaming at you to do 75 mph. Trans will definitely run cooler locked up. We all know heat is the killer for an auto.
ChevelleFan70 likes this.
70montee is offline
post #17 of 28 (permalink) Old May 22nd, 18, 10:23 AM
Originally Posted by von View Post
I really wanted to do that when I built mine but couldn't find anywhere that sells the parts to convert or instructions on how to. I know you can't just plop a non-locking converter in and have the trans function correctly.
Note that I have never used this part, but talked to a few who have and they said it works. I had my 200-4r built for non-lockup from the get go.
https://www.summitracing.com/parts/trg-7-ccv
TransGo THM 700R4, 4L60: 7-CCV
lucifershammer is offline
post #18 of 28 (permalink) Old May 22nd, 18, 1:40 PM
von
Lifetime Founding Member
Von
Wish I'd have known about it 8 years ago.
von is offline
post #19 of 28 (permalink) Old May 22nd, 18, 5:09 PM
I like what a converter loc/up does. 4380 Lb. Chevelle Sta. Wgn. 468 Big Block Chevy (with Q-Jet) @- 73 MPH. 468 spins 1950 RPMs this = 20 MPG on the I-State. Yes I do like the lock-Up.
Robinls5 is offline
post #20 of 28 (permalink) Old May 22nd, 18, 7:41 PM
I still use LU but my conv. is about 3500 stall so it drops 300 + rpm cruising.
77 Monte
11.93 @ 112.7 & tuning
77 cruiser is offline
post #21 of 28 (permalink) Old May 23rd, 18, 7:24 AM Thread Starter
I'm going to get the Trans Go shift kit installed and make sure everything is good inside. I'm going to order the TCI Lock-up so it's ready to go on when the transmission gets installed in June. All of this talk about swaps, my PowerGlide must have over heard. It's performing so much better as it gets driven more. Not sure how much good behavior is going to save it though.
1966 Malibu 327 200-4r
brockmub is offline
post #22 of 28 (permalink) Old Jan 15th, 19, 3:18 PM Thread Starter
The PG proved pretty reliable over the course of the summer and left only a minor oil spot in my garage. Drove it around until late November when it went into storage. The 200-4R was rebuilt by my coworker and is now ready for installation. He noticed a lot of little things that needed to be corrected so it took a while but he's done a great job.
The Trans Go Shift kit and TCI Lock-up are installed. Next steps we need to figure out is how to put it all together again.
Some challenges we are running into currently. Keep your metric bolts from the donor vehicle's torque converter. (I grabbed almost everything else from the donor related to the trans except for the converter bolts). Thankfully we found some but I hadn't thought to grab them initially. Also the 200 mounts further back on the frame, new mounting holes for the cross member will need to be drilled. This Malibu is having some clearance issues with the exhaust so it need to be mounted with spacers. Soon I'll replace the exhaust, then remove the spacers.
We are also determining if the additional kits are needed to get it to shift properly and I'll post them here.
brockmub is offline
post #23 of 28 (permalink) Old Jan 15th, 19, 8:24 PM
Just curious, what rear end gear are you going to run? My car is very similar, i went with a 3.73 rear. Even with that the rpms are low at cruising speed.
Dansk is offline
post #24 of 28 (permalink) Old Jan 15th, 19, 10:31 PM Thread Starter
That seems to be a very popular combination in my research to pair 3.73 gears with the 200-4R. Currently there is a 10 bolt 3.08 in but I'm trying to see if I can't find a 12 bolt to rebuild without spending a ton of money. Not sure if that's possible.
brockmub is offline
post #25 of 28 (permalink) Old Jan 16th, 19, 6:11 AM
You don't really need a 12 bolt on a cruiser with the 327 and an automatic. The 10 bolt will be just fine. I built mine with a posi and put an aluminum girdle cover on, mostly just for looks, and it's been good to go. Some advice from this forum was that since the car would break traction easily anyway, the 10 bolt would hold up. If a 12 bolt dropped in my lap I'd take it but realistically, you will spend at least $1200 more to get one and build it vs the 10 bolt.
Dansk is offline
post #26 of 28 (permalink) Old Jan 17th, 19, 10:20 AM Thread Starter
Transmission and crossmember bolted up... here are the next steps.
The crossmember was rumored to mate up with at least one of the previous mounting holes. On this frame that is not the case. There is a considerable distance between where the crossmember wants to mount and where the existing holes are. Two new holes will need to be drilled on each side. The crossmember would also like to be mounted lower, but unfortunately the exhaust...
The exhaust was tucked up nicely out of the way of the PG and everything else. However, there are clearance issues with the crossmember. I wish it was in worse shape so I wouldn't feel bad about hacking it up.
The shifting bracket doesn't unbolt from the PG, some people have suggested removing it to place it on the 200-4R. That would require a lot of adjustment so I ordered the Shiftworks KK02 kit.
As stated earlier in this thread, the inspection cover doesn't fit because the starter is on the opposite side.
brockmub is offline
post #27 of 28 (permalink) Old Jan 18th, 19, 6:32 AM
Same for me, the cross member needed all new holes. Mine is also a 327 and the inspection cover from a Buick GN fit perfectly. The stock exhaust I have also had no issues. If you dont have a TV cable setup yet, the one from Bowtie Overdrives is really nice. It has a cam adjustment at the carb which allows a little fine tuning of the shift harshness.
Dansk is offline
post #28 of 28 (permalink) Old Jan 21st, 19, 9:48 PM Thread Starter
Transmission cooler mounted up, using a lot of the original lines along with some additional hose. May be difficult to see from the pictures. Line comes in to the radiator, out from the radiator to the trans cooler. Should keep the trans nice and happy.
Work on linkage tomorrow and start working on the lock up wiring more. Also more testing on the TV pressures needs to be done. Also looked at the dust cover, Pontiac and Olds have the starter on the drivers side. Since mine is from an '86 Olds 442, it's wrong. I'm considering 3D printing a plug for fun or going without a cover until Spring.
brockmub is offline
This Thread is more than 445 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
