904 st-10 nos - Chevelle Tech
 5Likes
post #1 of 17 (permalink) Old Sep 9th, 17, 11:19 PM Thread Starter
904 st-10 nos
I have a chance to buy a over the counter NOS ST-10 trans. This is the 904 midplate trans. 288 first gear y code trans. Nickel gearset. Brand new never used. 1500 bucks
Would this hold up to a 600 ft lb 496 BB? Street car with drag radials 350 rear ratio 9 inch ford. No track time.
Like to go back to stick and pull the 400 turbo. Should be a direct bolt in including driveshaft.
64 Chevelle 496
StevenS is online now
post #2 of 17 (permalink) Old Sep 10th, 17, 2:52 AM
Vince
Re: 904 st-10 nos
i think the 496 will break it
the torque rating is only 375-450#/ft
it would work good till you stress it too hard with traction
VinceS427bb is offline
post #3 of 17 (permalink) Old Sep 10th, 17, 10:08 AM
jerry
Re: 904 st-10 nos
When you say "no track time", does that mean you're launching at 3,4,or 5k rpm on the street. If so, you'll have issues with that trans. If you're pulling away hard off idle or high idle, then it'll be fine.
cheveslakr is offline
post #4 of 17 (permalink) Old Sep 10th, 17, 10:28 AM
Re: 904 st-10 nos
If it's for a street car without slicks it would prolly be fine. You'll likely hate the "Y" gearset though. The 1-2 gear spread is almost 40%. The "CC" is much better at 34%. At first glance I didn't think $1500 was much of a deal, but a quick look at Jeg's shows the new aluminum Richmond's @ $2150. Guess I haven't bought any trans' for a while. I bought my ST10 new for $440. If you're really interested in a four gear check with Jody. He can prolly set you up with one of his supercase whizz bang Muncie's.
StevenS likes this.
Gary Anderson is online now
post #5 of 17 (permalink) Old Sep 10th, 17, 10:30 AM
Doug
Re: 904 st-10 nos
Borg Warner Second Design ST
I have an AS9 T-10Y Powerbrute,I believe it is the same trans you are talking about.I had it in my street strip Elky briefly,when I was afraid my M-20 wouldn't hold up.Only ran it a short time,because I fell into a super deal on my G-Force 101A I couldn't turn down.
Would it hold up with drag radials,600tq on the street?Probably,if it wasn't abused with wheel-hop launches,or 5 grand clutch dumps.
Just don't put 12psi slicks on it,and launch it on a sticky dragstrip.
StevenS likes this.
70 SS 454 LS-5 M-22 Bornwith Drivetrain-Sold New Baldwin Chevrolet
72 SS 454 El Camino W Code-427 4spd.
60',1.46, [email protected] [email protected]
Elky at Cecil
Chevelle Resto Pics
DougA is offline
post #6 of 17 (permalink) Old Sep 10th, 17, 11:29 AM Thread Starter
Re: 904 st-10 nos
375 -450 ft pounds. Isnt this for the aluminum case ST10? This is a 904 nodular case and nickel gears. I was under the impression that this is the aftermarket St10 which is rated to 550 - 600 ft lbs not the gm version which is weaker. These were sold at speed shops back in 1975. I maybe wrong ofcourse.
64 Chevelle 496
post #7 of 17 (permalink) Old Sep 10th, 17, 12:01 PM
Vince
Re: 904 st-10 nos
https://www.chevelles.com/forums/152-...er-t-10-a.html
looks like the the torque rating is much higher than the 375-450lb/ft that i was recalling...
Aftermarket for GM
AS9-T10 "Power Brute" with iron case and nickel gears Borg-Warner also sold a version of this transmission through speed shops under the "Power Brute" name. It had a 904 nodular iron case and 9310 Nickel alloy gears. The gears can be identified by a small dimple drilled into the side of each gear. Most of these version were designed primarily for drag racing and had a very low first gear. The theory at the time was to use the low first gear to launch a car quickly.
StevenS likes this.
post #8 of 17 (permalink) Old Sep 10th, 17, 2:05 PM Thread Starter
Re: 904 st-10 nos
Thanks Vince I did a search and did read that thread. Hard to find any real answers on how strong the non GM ST10s really are. The one I am looking at is a 1975 NOS.
64 Chevelle 496
post #9 of 17 (permalink) Old Sep 10th, 17, 3:29 PM
You will be fine.
I am running a aluminum case with steel mid plate super t10 (2.64 first) on the street behind my 502. It has Micky Thompson drag radials with 10psi and a mcleod ceramic clutch.
4500rpm clutch dumps are not a problem.
Biggest thing is that with this much power on the street you really cant load it hard enough to brake it. Track time, well I do have a backup already
A lot of people will say they are good in full weight Chevelle a up to 11.5 quarter passes.
StevenS likes this.
1968 Beaumont
540 BBC + 15psi Boost via Single Garrett GTX
Stock looking, and fairly stock sounding
HP and ET not determined yet!
Boosted Beaumont Build:
GoFast Beaumont is offline
post #10 of 17 (permalink) Old Sep 10th, 17, 4:03 PM Thread Starter
Re: 904 st-10 nos
Well dont have cash for a tko and really do not want to cut my floor. So this looks to be a good option since its basically new. If I remember correctly since I have a turbo 400 this should go right in with driveshaft and yoke. Clutch pedals are still in car and I have the zbar, linkage, and fork. Will need a shifter, scattershield and clutch. I have new floor installed when frame off was done. So I should find the factory hump for trans tunnel. Fun Fun
64 Chevelle 496
post #11 of 17 (permalink) Old Sep 10th, 17, 4:11 PM Thread Starter
Re: 904 st-10 nos
Jerry mostly nail it from a roll. If I ever take to the track (well no mercy) so thats way I really dont go. LOL
64 Chevelle 496
post #12 of 17 (permalink) Old Sep 10th, 17, 4:14 PM Thread Starter
Re: 904 st-10 nos
Gary
I remember those days when they were 440.00 I really dont want a muncie with straight cut noisey gears. See what old age does to you.
64 Chevelle 496
post #13 of 17 (permalink) Old Sep 10th, 17, 5:27 PM
Re: 904 st-10 nos
FYI, Most Power Brute ST-10's did NOT have 9310
nickel gear sets, that was a special order...
I have rebuilt 20 or more, and have 10+ power brutes in stock...
Hope this helps... Crash
70GS455 likes this.
crashent is offline
post #14 of 17 (permalink) Old Sep 10th, 17, 6:22 PM Thread Starter
Re: 904 st-10 nos
Crash
The owner claims this is the nickel 9310 version. I need to find out how to prove that before money changes hands. This is NOS so maybe there is paper work.
Do you have any nickel units in stock?
64 Chevelle 496
post #15 of 17 (permalink) Old Sep 10th, 17, 7:40 PM
Re: 904 st-10 nos
Gary
Pretty sure the ST10's use the same gear tooth angle as the M22's. If you have anything other than stock exhaust you'd never hear it. Just had my 42 year old ST10 out for a cruise this afternoon, quiet as a church house mouse.
This Thread is more than 994 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
