Original evaporator ... replace or not? ... - Chevelle Tech
  • 1 Post By obsessedw/musclecars
post #1 of 8 (permalink) Old Aug 4th, 05, 12:58 PM Thread Starter
I'm replacing the compressor, TXV, drier, and hoses on my 70' Elky.... plus considering the evaporator, just because, ... it's 3 1/2 decades old. Anyone still running an original coil? Are these prone to leak, with age? What supplier carries good quality evaporators? Any to avoid? Thanks
brimac is offline
post #2 of 8 (permalink) Old Feb 5th, 17, 11:53 PM
Re: Original evaporator ... replace or not? ...
Damn, I sure could have used an answer to this question also. It would save some of us time and money to not have to replace a part just because it's old.
70 Chevelle
Becker is offline
post #3 of 8 (permalink) Old Feb 6th, 17, 1:18 AM
David
davewho1 is offline
post #4 of 8 (permalink) Old Feb 6th, 17, 2:44 AM
Originally Posted by davewho1 View Post
DUH ... Dumb ...
70 Chevelle
Becker is offline
post #5 of 8 (permalink) Old Feb 6th, 17, 3:08 AM
benny
Ive restored many of these ac units. When someone sends me their parts, I flush and pressure check the evaporator first. You want to pressure check it with nitrogen. Are you staying with r12 or going with 134a? If going to 134a you would want to recalibrate the poa valve as well. And a parallel flow condenser is also highly advised.
obsessedw/musclecars is offline
post #6 of 8 (permalink) Old Feb 6th, 17, 3:10 AM
benny
LOL, I just now seen the date .
davewho1 likes this.
post #7 of 8 (permalink) Old Feb 6th, 17, 5:38 AM
von
Lifetime Founding Member
Von
At the least you need to get the evaporator out of the car for a good cleaning. Over time they get clogged with dirt, leaves, etc. Also with it out you can do a pressure check with air by using a rubber cap and hose clamp on one end then a compressed air nozzle in in the other end sealed as best you can with scrap rubber or whatever. Put the evap under water, put about 30psi to it and watch for bubbles in the water. My 48 yr old evap is still good.
von is offline
post #8 of 8 (permalink) Old Feb 6th, 17, 3:09 PM
It's too bad it took 12 years to get positive answers to the OP's original question. I guess I could have started a new thread, but I didn't think it was necessary with this question already being asked.
Thank you to the two who responded in a positive manner on this subject, it was very helpful.
70 Chevelle
Becker is offline
This Thread is more than 1156 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
original dealer info blm Tag Team 1 Feb 23rd, 04 10:31 AM
Coil Spring Original Part #'s, help David72Elky Brakes, Suspension & Steering 3 Nov 8th, 03 7:55 AM
Should I get a new or recored original radiator? Shawn 2002 10 Jun 28th, 02 5:56 PM
Original '68 SB Radiator: Replace vs. Re-core...ASAP madaboutabba 2001 4 Jan 9th, 02 10:12 PM
'67 Chevelle radios... is this an original?? snydes 2001 2 Oct 7th, 01 8:26 AM
