Heat Issues - New to me 70 Chevelle - Page 9 - Chevelle Tech
 182Likes
post #121 of 409 (permalink) Old Jul 14th, 17, 7:20 PM
Spike
Re: Heat Issues - New to me 70 Chevelle
Originally Posted by Bart_Swisher View Post
image only quote (from USMC Spike):
Bart, what bracket do you use to go from a large power booster to the smaller booster?
I have a smaller booster but no bracket. The studs mount opposite and differently.
I've seen a local guy with the same setup, but he didn't have a clue, as he bought
his Chevelle finished.
USMC_Spike is offline
post #122 of 409 (permalink) Old Jul 14th, 17, 7:34 PM
Originally Posted by Kirk's67SS View Post
You could get Hard Lines from GrdUp
Chevelle Fuel Lines. 1962-1972 Chevelle Fuel Lines Parts.
or The Right Stuff I think
Like Road Roamer my car has the Braided Fuel Line from Mech Pump to Carb
and I put Water Pipe Insulation around it to keep it cooler
BEFORE
AFTER
Huhum....photobucket pics don't work anymore unless you pay them for the privilege to link your photos to sites like these.
'69 Malibu
Not2Fast is online now
post #123 of 409 (permalink) Old Jul 14th, 17, 9:19 PM
Bart
I used the 9" booster and master cylinder from Right Stuff Detailing. I ordered the whole 4 wheel disk brake kit. Everything bolted up perfectly. I didn't have to change anything.
Bart_Swisher is offline
post #124 of 409 (permalink) Old Jul 14th, 17, 9:53 PM
Bart
OK, finally got around to taking pictures of my fan and getting numbers. Mine is 9796134 19.5 " 1970 GTO fan. Here are the pics showing the clearance etc. Again this is with the Summit one piece 71 shroud. Hope this helps.
ID:	459434   Click image for larger version
ID:	459442   Click image for larger version
post #125 of 409 (permalink) Old Jul 15th, 17, 1:29 AM Thread Starter
Thanks for the pics! At this point, I guess I am going to just try the 18" 7 blade fan I bought with the 2747 fan clutch. I may just try it in the stock 70 shroud and see if it clears. If not, I'll put on the 71 shroud and hope the fan is big enough to pull the air through the radiator.
ghoticov is offline
post #126 of 409 (permalink) Old Jul 15th, 17, 12:54 PM Thread Starter
Ive read about people using foam tape to seal the shroud. Probably a dumb question but how do you seal around the shroud? Are they talking about the top and bottom? Using foam tape to take the shroud to the top plate so there are no gaps? Anyone have pics of this?
ghoticov is offline
post #127 of 409 (permalink) Old Jul 15th, 17, 1:22 PM
Hank
This is where I mounted my fuel filter. I still run the bronze filters in the carburetor too.
HKalin is online now
post #128 of 409 (permalink) Old Jul 15th, 17, 1:32 PM Thread Starter
Can't see it because its a photobucket pic.
ghoticov is offline
post #129 of 409 (permalink) Old Jul 15th, 17, 4:15 PM Thread Starter
So I feel a bit dumb. lol I got the fan in today.....
I went out and got some 5/16-18X3/4 Hex Flange Bolts. I read somewhere (and wrote it down) that I needed 5/16-18X5/8 flange bolts but my local shop didn't have 5/8", they only had 3/4". First, are these the bolts to connect the fan clutch to the fan? If so, what do I use to bolt the fan clutch to the water pump pulley?
Right now, my flex fan has a spacer and connects right to the pulley. From what I can tell, now its the fan clutch that will connect to the pulley so that means the bolts I have (that were used with the spacer and flex fan) won't work, they would be too long. Does anyone know what size bolts I need for this or is that what the bolts above are for? And if that's the case, what size bolts would I need to connect the fan to the fan clutch?
And last, I assume the numbers (and part # sticker) on the fan face the engine, not the radiator...correct? It seems the fan clutch fits on the fan better this way (the clutch has a little more clearance from the fan fins).
ghoticov is offline
post #130 of 409 (permalink) Old Jul 15th, 17, 8:07 PM
Jerry
I believe you will need fine thread...5/16"-24 bolts.
Here's a pic of my fan attached which is the same fan you have.
Kirk's67SS, Not2Fast and ghoticov like this.
Road Roamer is offline
post #131 of 409 (permalink) Old Jul 15th, 17, 10:56 PM
I pulled the shroud away from the radiator and then applied 3/8" foam (from Home Depot) all around the perimeter. Place back against radiator, all done. Before you buy the foam measure (or guesstimate) the gap between the shroud and radiator. Buy foam slightly thicker than your measurement so it will compress against radiator.
70 El Camino SS 396
68 GTO (Thanks Mom)
06 Silverado
07 SRX
OO52 is offline
post #132 of 409 (permalink) Old Jul 16th, 17, 1:37 AM Thread Starter
How long of a bolt? 3/4"???
So I assume the 5/16-18X3/4 are for attaching the fan blade to the fan clutch? Do you think it matters that I'm using 3/4" long instead of 5/8". I screwed them into the fan clutch and they seem to work.
ghoticov is offline
post #133 of 409 (permalink) Old Jul 16th, 17, 1:39 AM Thread Starter
Gotcha... and does it go all the way around the shroud? Top, bottom and sides? or Just top and bottom?
ghoticov is offline
post #134 of 409 (permalink) Old Jul 16th, 17, 11:34 AM
Greg.
Where ever there is a Gap between the Shroud and the Rad
ghoticov likes this.
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is online now
post #135 of 409 (permalink) Old Jul 16th, 17, 12:56 PM
I think I read you have heat issues at idle and at highway speeds. If this is correct the fan wont solve highway speed heat issues. Driving down the road at higher speeds you dont even need a fan. 60 mph air flows plenty thru a radiator to cool it if its efficient.
I use that same flex fan on my 496 and have no heat issues. If it was me I would look at the radiator and install a high flow water pump. IMO and your hot 100 degree temps in your area I would install a good double 1.25 row aluminum radiator.
p40 likes this.
64 Chevelle 496
StevenS is offline
This Thread is more than 889 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
