Letting the heat out. 67 Hood louvers with vents... - Chevelle Tech
 16Likes
post #1 of 40 (permalink) Old Jun 7th, 16, 8:11 PM Thread Starter
Paul
Wink Letting the heat out. 67 Hood louvers with vents...
There is a thread on a 66 with functional hood vents( https://www.chevelles.com/forums/32-h...ood-vents.html) and that got me thinking....
Why not let the heat out right in the middle of the hood... With my own 67 SS hood vents.
I didn't really want to start cutting up my nice shiny chrome louvers though.
A friend of mine has a 3D printer and is making some pretty cool stuff so I asked him if he could come up with some thing.
So now it's in the works...
These are more or less just a rough 3d printed louver for fitting and working out issues.
When there done they will be smoothed out and painted.
I'm not exactly sure how i'm going to cut vents but this is a start anyway.
454/T400/9" in a 67 Beaumont
Paul-ish is offline
post #2 of 40 (permalink) Old Jun 7th, 16, 8:58 PM
Greg.
Re: Letting the heat out. 67 Hood louvers with vents...
Paul I will be keeping a eye out for your work/fabing/writeup on this .
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is online now
post #3 of 40 (permalink) Old Jun 7th, 16, 9:33 PM
Subscribed.
67
70 (SOLD)
Alwhite00 is offline
post #4 of 40 (permalink) Old Jun 8th, 16, 12:33 AM
This is exciting. Where are you getting 3D printing done?
Youtube Channel.
Instagram:
Twitter:
-SS454- is offline
post #5 of 40 (permalink) Old Jun 8th, 16, 12:37 AM Thread Starter
Paul
My friend has one in his garage.
The first one he made fits pretty good. I'm exited...lol
Chop the middle out , Smooth it out and paint'er up nice.
Add some chrome mesh and voila!
Ahh if it were only that easy...
I already have experience working with 3D printed stuff, Shouldnt be to bad.
Paul-ish is offline
post #6 of 40 (permalink) Old Jun 8th, 16, 1:11 AM
would you use the 3D printed part, or would you use it to make a mold and then build it out of CF or fiberglass?
Youtube Channel.
Instagram:
Twitter:
-SS454- is offline
post #7 of 40 (permalink) Old Jun 8th, 16, 2:07 AM Thread Starter
Paul
They will just be 3d printed out of abs plastic. Should be fine for the heat and I can make them look awesome.
I have refinished some 3d printed stuff before with exellent results.
I'll post some examples is photobucket comes back on line...
Paul-ish is offline
post #8 of 40 (permalink) Old Jun 8th, 16, 6:29 AM
Boundary layer, those scoops are all mostly eye candy..
hydro462 is offline
post #9 of 40 (permalink) Old Jun 8th, 16, 10:31 AM
The post says "Why not let the heat out right in the middle of the hood... With my own 67 SS hood vents"
Maybe when the car is moving it won't work well due to air flow along the hood surface. Maybe they will work on the highway. Sitting in traffic they will act just like the chimney on you furnace. Will this "heat exhaust" function actually cool the motor water temp? I don't know. On the road, at speed, the air pressure under the hood from the grill / fan could override any air flow down the hood outer surface and provide a nice increase in air flow from the engine compartment. Its tricky to predict how this might or might not work .....especially given the differential in pressures involved at the radiator, above the hood and below the hood. I would not immediately rule it out as functioning well on the open road.
I am very sure it will work well on local streets when stuck in traffic and at stop lights. Most boundary layer air discussions that discount the effects of air scoops from the 60's are focused on the effectiveness of getting cold air from above the hood into the carb(s). As a tool for that purpose they were indeed not very effective. As far as letting heat out from beneath the hood...hot air wants to rise: holes in the hood will aide in that process. As far as the open road / highway cooling effects...only road testing (or wind tunnel testing) is going to determine how that turns out.
Don't sell this idea short for the purpose of increasing hot air flow out of the engine compartment.
BTW.....Love the idea of the scoops made by the printer.
Kirk's67SS likes this.
oman is offline
post #10 of 40 (permalink) Old Jun 8th, 16, 2:00 PM
A G.M. " A " body is designed to have " Outside Air " enter the engine bay through the grill & Lower bumper area. The " A " body engine bay is also designed to have the super heated air exit as per the G.M. design.
Have you ever noticed the G.M. engine bays they are very well sealed up, Why all the rubber seals, Splash guards, Rubber hood seals.
G.M. wants the super/Heated air to EXIT at the lower left & lower right exhaust manifolds.
Due to the fact the cast iron exhaust manifolds are the major heat generators.
The design is like your furnace, Duct work.... With all the ORG. factory, Seals & Shrouds,& Rubber items in the proper places, Chances are you will not have heating issues.
Good luck with your new adventure, An engine fluid leak, At a high speed with a open top hood could prove be interesting. Also with an open top hood at normal road speed you may lose a lot of underhood air pressure needed for cooling.
Good Luck
Robinls5 is offline
post #11 of 40 (permalink) Old Jun 8th, 16, 2:55 PM
I'm sure the issues (if any) will make themselves felt once that car is being driven. I commend the OP for trying this, if I saw it on a car at a show or cruise, I'd think it was seriously cool!
Kirk's67SS and rel3rd like this.
"SSuper Dave" Palmer
A.C.E.S. #1483 TC #32 Gold
SSuper Dave is offline
post #12 of 40 (permalink) Old Jun 8th, 16, 9:26 PM Thread Starter
Paul
Is this going to be the miracal cure for overheating 67 Chevelles?, Hell no....
GM had intended the hot air to exit the lower rear of the engine bay? Yes and on a stock set up this can work very well... I know this.
But my car is very far from stock, GM wasn't testing on a car that was lowerd 3 inches, had a 525 hp bigblock with headers, Ran fuel injection and electric fans.
This is just an experiment for me because I like to tinker with stuff and I can... It's going to cost me a huge whopping total of about $30...lol
and I will be able to track exactly what it does with data logging of my EFI.
If it doesn't work I can just reinstall the old chrome louvres and you will never know anything was ever changer. From the top view anyway.
Paul-ish is offline
post #13 of 40 (permalink) Old Jun 8th, 16, 9:35 PM Thread Starter
Paul
My test fit went pretty well last night, I'll need to massage a couple spots with my die grinder on the underside but that's no big deal.
My 3D printer friend came back with a couple designs for me. These took him a half hour to make. I have no idea how or what program he uses... Seems like magic to me.
This one is just wide open with a lip that I can attach wire mesh/screen to.
This one has two slits so I can fasten it on in the oem holes with speed nuts.
Underside of the second one... I'm pretty sure i'll go with the lower one.
Paul-ish is offline
post #14 of 40 (permalink) Old Jun 8th, 16, 10:46 PM
Bruce
Be prepared for engine exhaust smalls and various toxic gasses from the engine compartment to enter the passenger compartment through the "fresh air" vents. The under hood weather-stripping normally routes those smells down and under the car. You'll be venting them out through holes in the hood -- at least when you're stopped at a light, etc.
Our You Tube Vids:
NickeyChevelle is offline
post #15 of 40 (permalink) Old Jun 8th, 16, 11:07 PM
Are you cutting out the underside of the hood? I just looked at mine and even with the insert vented the hood structure is solid in that area.
67
70 (SOLD)
This Thread is more than 555 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
