67/67 Fan Shroud Size? - Chevelle Tech
post #1 of 5 (permalink) Old Jan 5th, 14, 3:58 PM Thread Starter
I've did a search on here, and no results. I have also looked on vendors sites, but no measurements are given.
So, can someone give me the fan diameter opening on a SB & BB ??
I need these measurements before deciding which shroud to buy.
Also, I need the depth measurements from the mounting flange face of the shroud, to the top fan opening for BB & SB. i.e. 3", 4" or ?
I'm working on fitting a factory OEM electric fan on the shroud.
No, I am not going for aftermarket.
I did this mod on my 70 GMC Truck and that shroud fan opening was about 19" & a depth of around 4"
Depending on the size of either the SB or BB will depend if this is going to work.
If it does, I will do a write up showing what factory OEM electric fan to use and how to wire it.
thanks....
1967er is offline
post #2 of 5 (permalink) Old Jan 5th, 14, 6:58 PM
Keith
Re: 67/67 Fan Shroud Size?
SB and BB both used a 17 1/8 fan with a clutch. With a good working rad, fan, fan clutch, and w/p there is no need for a electric fan
Maryland Chevelle Club #682
keithb is offline
post #3 of 5 (permalink) Old Jan 6th, 14, 10:24 AM Thread Starter
Yes I know, but I still need to know the size of the fan opening of the shroud and the depth.
1967er is offline
post #4 of 5 (permalink) Old Jan 6th, 14, 12:48 PM
Keith
my repro shroud has a oping of 20 inches and is 3 inches deep
keithb is offline
post #5 of 5 (permalink) Old Jan 6th, 14, 3:18 PM Thread Starter
That helps a lot....... thanks
1967er is offline
This Thread is more than 2053 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
