Electric fans/aluminum radiators/real lowdown - Chevelle Tech
 4Likes
post #1 of 185 (permalink) Old Jun 9th, 13, 8:13 PM Thread Starter
Matt
The following is Tom Dewitt's reply to my question about the actual effectiveness of electric fan combos and the fallacy that electric fans down't work with aluminum radiators. I believe his history and experience is far greater than some of us weekend mechanics. Thanks Tom.
Originally Posted by oktunes
Tom, we get so much mis-information on this site that it would sure be nice to get a straight, honest answer from someone who's reputation would be on the line. Can you tell us if the aluminum radiator/dual fans actually cool thses big hp motors.
The line continually repeated on this website is that electric fans cannot pull air thru aluminum radiators. Evidently some believe that electric fans just are not up to the job. What has been your real world experience? Do your systems work or are these guys right and these combos are a waste of money?
I'm glad you asked. I just wish you had started a thread in the Heating and Cooling section so others would find it. I have to say I was shocked to see so many negative theads regarding electric fans because we have had nothing but success with them. We have only used Spal brand fans, which are factory equipment on italian sports cars, and they tend to cost more than other fans.
My guess would be that the majority of the bad fan stories is the result of applying them wrong and/or mounting them wrong. When using electric fans you need to have at least 70% core coverage and a minimum of 2000 cfm. The fans should be "puller type" and mounted with about a 1/4" gap between the core and the fan. Mounting them directly to the core with pins or zipties is a real no-no. If the core face is close to a square shape, then one single round fans should do the trick. If the core surface is a retangle, like the 68 and up Chevelles, then two fans are required to give you the core coverage.
I often hear stories of junkyard fans, randomly extracted from some late model car, and then installed in the old classic. They have no idea what the cfm of these fans are and there is no data to find out. These fans are designed to pull through a single row aluminum core that is about 1" thick and they pull about 1500 cfm. One trick to judge an unknown fan is to look at the amp draw. I takes about 25-30 amps to get to 2000 CFM. I have seen wild claims about the performance of the MarkII fans being 4000-5000 cfm. The reality is they are only about 2600 cfm and they pull a huge (35 amp) power. I have a pdf test data to prove this in a Spal comparison.
Air flow is the heart of heat transfer. The more air flow, the higher the heat rejection. Every car made in the last 20 years uses an elctric fan because they provide the best solution to automotive cooling. In a car application, the ultimate choice is to have maximum air flow when at idle and crusiing, when free air flow is not available. Engine driven system are the opposite. You get the smallest amount of air flow when you need it the most.
Now, there is nothing wrong with the old engine driven fan system. It works quite well when applied correctly. That's why so many have reported success when changing everything back to stock. This requires everything to be working as designed and set up right. This includes the shroud, right fan blade and position, clutch function, and seals.
There are several reason you might want electric fans and I don't automatically recommend them to everyone. You might want electic fans for improved cooling or you might just like the looks of them better. It does free up a lot of space in the engine bay. You might be doing a complete restoration and the fans are cheaper than buying all the stock parts to complete the system. I have often "un-sold" the electic fans when talking with the customer about his/her motivation. It's very common for people to overshoot the goal because they haven't experienced an aluminum radiator upgrade alone.
I don't know if that answers your question or convinces any non-believers but I can tell you this. I have NEVER had anyone return a rad/fan combination because it didn't work.
Street Rod Pix
34 Ford Sedan
65 Chevelle SS
Chevelle album
oktunes is offline
post #2 of 185 (permalink) Old Jun 9th, 13, 9:46 PM
Jason
Re: Electric fans/aluminum radiators/real lowdown
Good info...Thanks !
_________________________
'70 Chevelle
Current build:
Blownchevelle68 is offline
post #3 of 185 (permalink) Old Jun 9th, 13, 10:19 PM
Well if you want the real lowdown how about rearing testimony after testimony from your fellow team chevelle members in thier own words about thier experiences with elec fans having thier motors running 220-230 deg then per my rec removing the elec fans & applying my rec upgrades to gm clutch fan setup and getting 20 deg temp reduction on avg and sometimes 35-40 deg while in most cases retaining the same rad where elec fans had motor running 220deg.
I go by consistant results and thats what my rec setup delivers big time,consistant results time after time with many diff setups and perf lvls of bbc & sbc street perf motors.
This testament below shows his motor was running up to 230deg with elec fans and the 220deg with a flex fan. Then his motor temp was reduced by 40+ deg to 185-190deg tops in 85 deg temps with a 772 clutch fan and HD hayden 2747 fan clutch along with other suggestion i made too .
Thats a solid 35 - 40+ deg reduction in engine temp depending on if compairing to elec or flex fan setup which is a significant temp reduction post following nmy rec setup.
Scott,
I have been busy these couple of weeks after I did the upgrade, so I havent had a chance to
take her out again on a warm day.
I do plan on bringing her to work on friday, it is suppose to be in the low 80's on friday. So I will test her out then.
Just for anyone following this thread, I am giving you a little run down of what I been doing.
I been battling the hot temps on my Chevelle for a few years now. I had the flex-a-lite electric fans with a Mr. Gasket HP 160 t-stat. On warm days, she will get up in the 210-220 while cruising, on stop and go traffic there would be times she would hit the 230-240 mark in traffic. When this would happen I would just pull over and let her cool a bit. The I dumped the electric fans, and went with a 6 blade flex fan I had laying around, and thru on the stock 70 shroud. Temps got a little better, but would still hit the 210-220 mark on stop and go traffic.
A few weeks ago, I just pretty much had it, I just couldnt get good cool running temps on her that I would honestly not even drive her around in late spring, summer or fall. Only winter and early spring.
Well after posting my problem on here, Scott suggested a few things. Which I tried and so far I can say it has been succesfull.
1st I dumped the 6 blade flex fan, went with the stock 7 blade 772 fan, I also purchased the Hayden 2747 HD clutch, but kept the Mr Gasket 160 t-stat. I also switched from the 70 shroud to a 71 shroud (which the 71 covers the whole radiator, which the 70 does not). Temps got better, took her out on an 80+ temp day and in stop and go traffic. Temps where about 185-190 on 85+ outside temp with stop and go traffic.
I was very pleased with this. though now I changed the Mr. Gasket 160 t-stat and went with a standard autozone 160 t-stat Scott rec, I also drilled 2 extra holes in it.
Now this friday, I will take her out again, on 80+ outside temps and in stop an go traffic. now i will see what she will do with the standard autozone t-stat. Which i think it will do better than the Mr. Gasked HP one. After I installed the standard 160* t-stat i did take her out on a quick spin, and she never hit the 165 mark. but then again, it wasnt hot that day, it was in the mid 70's.
I hope all this info will help any fellow TC member with the similar problem I had.
Once I take her out on a hot day, I will report my findings.
Thanks Scott for all the help, and thanks everyone else that had thier .02 in it
Followup from the original poster for his above post when he tested the autozone duralst 15356 160 stat vs a hi flow mr gasket 160 deg stat.
I did take the Chevelle out on friday to work, and hit stop and go traffic on the way home, though outside temps werent as warm as I expected. Outside temps where high 70's, maybe like around 78-80 outside, BUT the good news was that even on stop and go traffic for a good 45 min stretch, she never hit 185. She was steady for the whole time in traffic at around 180, climbed to 185 when traffic started to pick up, but then she dropped to about 175-180 all the way home.
Thanks again for the great advice. I would definately say the standard autozone 160 t-stat beat out the Mr. Gasket HP 160 t-stat.
FINAL FOLLOWUP UPDATE:
Jul 5th, 11, 10:32 AM mad70ss Tech Team Join Date: Sep 2006 Location: Corona, CA Posts: 685
Re: Help on 70 BB overheating issues....**UPDATE**
Ok, here is an update on my Chevelle....
Took her out this past friday, brought her in to work. After work, on the way home, outside temps were in the 90's. Hit about a good 30-40 min of stop and go traffic. In 90 deg heat she got up as high as 190. Did not go higher than 190. Driving down the freeway with no traffic, she was doing 175-180.
WOW!! What a difference, before with the elec and or flex fan, she would be doing 210 easy and forget about being stuck in traffic.
I am very pleased with the new set up (7 Blade fan, clutch, 71 shroud and 160 autozone t-stat)....
thanks again Scott.....Now I can get to enjoy her on the summer __________________ _____________________________________ Ralphy Corona, CA "MAD70SS" 1970 Chevelle SS http://i103.photobucket.com/albums/m...kers064-vi.jpg 1996 Chevy Silverado Z71 1996 Impala SS (SOLD)
In summary this case from the above testimony showed his motor went from running up to 230 deg in traffic with elec fans and up to 220deg in traffic with a flex fan to running 175-180 deg on avg with my rec cooling system/motor tune setup.
Swheaton
Here's another example (pasted below) of going from a dual elec fan seup that was running as hot as 220 in traffic to a gm 772 fan/2747 hayden HD clutch fan/and stock type fan shroud reduced temps by approx 40 deg.
With an AC Condenser on my Chevelle and the trans cooler pressed up against the radiator the (12" dual puller Flexalite) dual electric fans I had just wasn't enough air flow at idle and low speed. Temps crept to 205 and kept rising in traffic to 220 on a 90 degree day.
So replaced the dual electric fan setup with a '71-'72 28" stock type 2 piece fan shroud, installed the gm 772 fan i already had, and a HD Hayden Fan Clutch (2747 ).
Was hoping I didn't have a bad radiator.
It was about 85 degrees yesterday, took the chevelle for a ride and tried to heat her up. Highest the motor saw in 85+ deg temp temp was 179 at cruise & when sitting in traffic it actually went down to the high 160's.
I would call it a 40 degree drop in idling temperature.
I do have a brand new Dual Fan setup in the box, but that is where that will sit.
ANOTHER EXAMPLE OF STOCK COOLING SYSTEM OUTPERFORMING AN AFTERMARKET AL RAD & ELEC FAN SEUP.
Feb 3rd, 12, 1:06 AM jm209modesto josh Join Date: Feb 2012 Location: modesto ca Posts: 3
over heating
THIS GUY WENT FROM A GM CLUTCH FAN COOLING SYSTEM THAT WAS COOLING JUST FINE TO AN AL RAD WITH ELEC FAN ,SEE THE RESULT IN HIS OWN WORDS PASTED BELOW.
Hi,i have a 67 chevelle 468ci engine i recently upgraded from a stock radiator,mech fan,mech w-pump to an aluminum also electric fan and now my car now runs hot. it doesnt get hot right away after driving for about 30-45 minutes it starts creeping up. it never got hot when i had mechanical water pump mechanical fan and a stock radiator..
HERE'S ANOTHER TEAM CHEVELLE SUCCESS STORY
ORIGINAL POST:
Took the car out today for a cruise. It seemed to be running a bit warm. It was about 86 degrees today, but the motor was running about 220. In the winter months it get up to about 210 and stays there. I noticed this last summer, and at times it would creep over 220 when at a stop light. I am running stock 4 core radiator with 50/50 antifreeze, and a 180 thermostat. Is there a better coolant mixture that may help with this? Living in Colorado the summers get a bit warm.
ORIGINAL POSTERS RESPONCE POST FOLLOWING MY INSTRUCTIONS:
Today, 12:03 AM MikeSS Lifetime Premium Member Join Date: Jan 2005 Location: Aurora, CO Posts: 229
Re: Car running a bit warm
I just finished up the mods to the car to correct the heat issues. I had initially been running about 210 degrees just driving around town.Sitting at a light, or in stop and go traffic, the temp would rise to 220ish. This was all with an incorrect 4 core rad and a 180 thermostat.
Scott Wheaton made a few recommendations, and I put them into place.
Here is what I did.
-Replaced the fan clutch, with a Hayden HD 2747. That mod alone dropped the temp to just under the 210 mark. -Replaced the radiator with a stock style 4 core (manual trans) -Installed a 160 degree thermostat -Replaced the old coolant with a 30% coolant, and a 70% distilled water mixture
Drove the car and the temp while cruising is about 176 deg. At a stop light, sitting for about 4 min, it crept up to about 185 deg. Overall this reduced the operating temp about 20-25 deg total.
Thanks for all the help Scott. __________________ MikeSS 70 SS TC Member #5479
Here's a couple examples!
I have a 71 Chevelle with a 496 built pretty tough and having trouble keeping cool. Went from 4 core radiator with single electric fan to a 2 core 1 inch tube aluminum radiator with dual 14 inch fans and when running on the highway on hot day running around 215 to 218.I had a 50/50 mix of water and antifreeze, but water out of a hose with a 180 thermostat. I have 4:11 in rear end and running about 2500 rpms at 55 to 60 mph. If I run faster than 2500 I will creep up to 220 and thats when I pull over to cool off.
SWHEATON posted many threads about how to cool these BB down. I wasn't on board because aluminum rad and dual fans come on that should do it without problems right NOT!
Well many posted how well it worked doing what SWHEATON suggested.
I decided to drink the Koolaid. It worked better than I expected. Here is what I did:
I kept the aluminum radiator and changed the mix to the 70/30 distilled water and straight antifreeze. Changed the thermostat to the autozone 160 and drilled the 2 holes. I ran the car this way with no change. Decided to go all the way. Pulled the electric fans and shroud and replaced with a 772 7 blade fan with the hayden 2747 clutch and orginal shroud.
Here is what happened: went for a drive in 90 to 95 degree weather and to my suprise I ran about 190 to 195 average on the highway at 2500 rpms. Took it up to 3000 rpms and stayed about the same. Ran up to 4000 to 4500 for couple of min ran about 185. I did creep up to about 197 for brief time but never went over 200. Got into town and ran about 185. Plan to go on a drive on a hotter day above 95 deg to see what happened but so far
SWHEATON I am a believer now Thanks for helping with cooling my BB down. JP
Another followup in extreem temp on this same motor/car! _
Well here is my update on a hot 98 day and 2nd trip after changing everything Scott suggested.
Today I went to a car show and it got up to 98 degrees today. On my way to the car show I ran average of 185 on highway doing 3000 rpms and when I got off the highway and pulled up to register I was 178. On my way home at the hottest part of the day I averaged 190.
This car used to run as high as 220 deg at 3k rpm cruise speed in similar temps but now avg
185 deg (35 deg cooler!) in same cond!
I have to give credit again to Scott because I have been fighting this cooling problem for over a year and was afraid to drive my car too far of fear of overheating and when I did drive I had to take back roads to keep my rpms down so that I wouldn't overheat. This sucked because you spend so much on these cars and its a bummer to have problems like this that you have to question to go somewhere with overheating in that back of your mind.
Thanks to Scott ready to drive and go anywhere!
_________________
Of all the things I have lost, my mind is the thing I miss the most!
jpextreme View Public Profile Send a private message to jpextreme Find all posts by jpextreme Add jpextreme to Your Contacts
#2 Jul 10th, 12, 10:29 AM 1971ss454Elco Tech Team Marc Join Date: Nov 2008 Location: california Posts: 969
Re: Overheating! SWHEATON Thanks for the help!
Scott helped me as well on our 71 SS 454 which used to run 225-230 degrees.
We now run 175-180 degrees on 100 degree day weather here in cali right now WITH A/C on no less.
Stock appearing LS5 with A/C, TH400 and 4:11 rear.
Alumitech replacement rad, stock shroud, HD clutch w/stock type fan.
Timing correct, carb tuned, foam tape used to seal shroad to radiator and radiator to support. All new hoses from pacecarJeff.
Marc S
ANOTHER TESTIMONIAL !
My '70 started running hot (210 and climbing) with a big block conversion...usually on hotter days, for sure in traffic. I went with Scott's (SWHEATON) advise: '71 Fan shroud - full radiator coverage A-Zone 160 thermostat HD fan clutch Summit HI-Flo Pump. Now, In 95 degree heat it tops out at 190 degrees MAX!...cruises at 170-175 all day.
ANOTHER ELEC FAN RUNNING HOT SETUP TO A TWEAKED MY WAY GM CLUTCH FAN SEUP SUCCESS STORY!
Bellow is the testimonial from a t/c memeber:
I like threads that have some type of closure to them, so here is the update.
After pulling the thermostat, I was driving around in 90+ weather and thought I had my temp issue fixed, then on a drive of stop and go in in 90+ degrees outside, it started to get hot.
So, I followed Scotts suggestions and purchased the 2747 Hayden fan clutch, and it bolted right on my short shaft water pump no problem. I added a radiator spacer in my car to put the radiator where it would be with a big block, essentially moving it a bit farther away from the fan, so it would be situated in the shroud perfectly. Since I wasn't going for stock, I found and installed a shroud from a 68 impala, which covers the entire core of my radiator. I also found a 7 blade thermal clutch fan at a junk yard that would fir in the shroud... I believe it is an 18" fan. I threw it all together, put the 160 degree thermostat back in and just got back from an hour long spirited drive in 93 degree weather.
Temps didn't even hit 190. They moved from about 183-186. As stated earlier, my temp sensor is in my intake manifold as the correct 461 heads from 65 don't have provisions for the sensor, but with nothing else changed, I just decreased my overall temp from my dual electric fan setup that would climb to 225+ in traffic, to maxing at 186 in the same conditions.
Thank you so much Scott for the help with this, and I hope this can help someone down the road.
Long story short, is it possible to make dual electric fans cool a SBC or BBC? Probably, but you will spend MUCH more money doing it. MY stuff was middle of the line and my SBC was mild and the $400 shroud/electric fan setup i was running couldn't hold a candle to the cooling of my $3 7 blade GM clutch fan fan with $50 fan clutch, and stock shroud (cost $40). I wouldn't have been a believer, but this concludes my case study.
Thanks!
My/Scott's responce :
WOW,thats a solid 35-40 deg reduction in temps over elec fan setup showing once again the tweaked gm clutch fan setyup i rec blows the avg dual elec fan setup away.
HERES TESTAMONY OF A T/C MEMBER GOING FROM A 6 BLADE NON STOCK CLUTCH FAN TO A 71 & NEWER GM CLUTCH FAN IN A 71 & NEWER FAN SHROUD SETUP HE ALREADY HAD ON HIS 69 CHEVELLE THAT COVERS COMPLETE RAD VS STOCK FOR 69 CHEVELLE SHROUD THAT ONLY COVERS 75-80% OF SHROUD ALONG WITH ALSO DOING MY SUGGESTED MODS
TO GM'S CLUTCH FAN SETUP TO REDUCE TEMPS MORE THEN STOCK GM CLUTCH FAN SETUP CAN DO .
NOTE:THIS CAR STARTED OUT RUNNING UP TO 195 @ CRUISE AND 220-230 WITH AC ON ESP WHEN AT IDLE FOR ANY LENGTH OF TIME IN TRAFFIC.
Well I just wanted to give an update on the fan issue. I finally located a GM 19 inch clutch fan off a 72 chevelle that was a factory ac car. It made a noticable difference in how much better it cools epsecially when at a stop vs the flat 6 blade I was using. It has the curved blades just like the 772 my buddy has on his big block vs the flat 6 blade non GM clutch fan I was using.
My setup that was running too hot was a 3 row aluminum radiator, 71 shroud ,non GM flatter 6 blade cooling fan,std duty fan clutch,180 stat,HD water pump that was running up to 195deg at cruise and 220-230 with AC on especially when sitting in traffic idling .
Then i added a 19 inch GM curved blade clutch fan in place of the flatter 6 blade non gm fan, added a hayden 2747 HD thermostatic fan clutch in place of the std duty fan clutch, added an autozone 160 stat with one relief hole drilled in place of 180 stat.
Anyhow, it went from reading 220-230 deg to now around 200 to 205 when testing it at a dead stop (sitting idling) for over 15 minutes with the ac running. (Thats a 25-30 deg temp drop idling with AC on!)
I would say I'm now doing 180deg when cruising (15 deg temp drop at cruise) and 195 after stop n go driving (30+ deg temp drop in traffic) vs the 195 deg at cruise and 220-230 deg in traffic with AC it used to run before adding the upgrade parts SWheaton suggested.
I definitely have the best setup now for cooling compared to flex fan and dual electric fans I have used in the past.
Thanks to all who helped with advice and tips!
================================================== === __________________ SCOTT 1969 CHEVELLE SS396/4SPD/M20/12BOLT/3:31'S ORIGINAL #'S MATCH/OWNED SINCE 1978. 1977 KAWASAKI KZ1000 (ORIGINAL OWNER) 1976 KAWASAKI KZ900 2006 YAMAHA 1700 ROADSTAR SILVERADO ================================================== =====
May 29th, 13, 8:54 PM
70 nialator
Darren Join Date: Mar 2004
Low dollar, BIG cooling
Just thought I’d share some of my experiences and pics all in one place with part numbers and a little how to……. I’d also like to thank everyone here that helped me along the way. Before: 3 hole top plate, copper core radiator.. with electric fans taken from an LT1 Camaro. Temps exceeded 220 often. After: 4 hole top plate, Aluminum radiator and the things below…. I couldn’t get it to 190 no matter how hard I flogged it, 102 outside temp. Parts list: • 4 Hole chrome top plate Ebay = 20.00 • 19 inch XT1 -7 blade fan - U pull it = 10.00 • Hayden 2747 HD clutch = 49.99 • Murray 433322 -29 in wide, 18 inch tall Aluminum radiator (specs on their website are jacked up, trust me it drops right in) I paid = 140.00, Listed at 159.00 right now. • Shroud 1971 BB (one piece) from Summit OPG-00T218R = 59.95 • Upper hose Gates 21204 15.00 • Lower hose 21324 lower 12.00
* 160 stat Total 307.00, rounding up. I gained a brand new free flowing aluminum radiator & car that I can’t get to run over 190 with it being 102 outside.
SCOTT
SWHEATON is offline
post #4 of 185 (permalink) Old Jun 9th, 13, 10:27 PM
heres my rec setup that would not fit in my above post.
Its the same cooling system setup i run with my mild street perf 396 now 402 bbc in my 69 chevelle SS396 that consistantly runs nice & cool in hot temps is as follows:
(Thjois same setup can cool pretty stout 496-540 bbc street perf motors too)
* STOCK HARRISON 4 ROW HD COOLING RAD RESTORED/RECORED WITH A HI EFFICIENCY 4 ROW CORE 3-4 YRS AGO. (A QUALITY DEWITT HI PERF AL RAD SHOULD WORK WELL TOO)/THOSE RADS COOL BETTER THEN STD 2-3 ROW OLD SCHOOL RAD.
* MIX COOLANT 30% AINTIFREEZE/70% DISTILLED WATER FOR A LITTLE BETTER HEAT TRANSFER (VS 50/50 MIX) WHILE RETAINING THE ANTI CORROSION & ANTI FREEZING BENEFITS FROM THE ANTIFREEZE ITSELF. I ADD A BOTTLE OF ANTI RUST / WATER PUMP LUBE TO COOLING SYSTEM TOO.
* STOCK TYPE GM 7 BLADE 772 CLUTCH FAN USED FOR AC/HP COOLING APPS THAT MOVES A LOT OF AIR THRU RAD CORE WITH PROPER FAN CLUTCH.
* HAYDEN HD (NOT STD DUTY!) 2747 THERMOSTATIC FAN CLUTCH THAT COOLS BETTER THEN STD DUTY FAN CLUTCH FOR 1969 & NEWER LONG BBC W-PUMP IN A CHEVELLE.
* USE A STOCK STOCK FOR AC OR HD COOLING OPT GM FAN SHROUD FOR SBC OR BBC AS REQUIRED.
* SEALED ALL GAPS INBETWEEN RAD SHROUD AND RAD CORE WITH ADHEASIVE BACKED BLK FOAM INSULATION USED IN AC APPS(CAN HARDLY SEE IT) TO ENSURE ALL AIR MOVED BY FAN IS PULLED THRU THE RAD CORE FOR MAX COOLING AND NOT AIR PULLED FROM EASIER PATH LIKE LRG GAP INBETWEEN SHROUD AND RAD CORE.
* MILODON CAST IRON STOCK LOOKING FOR STOCK APP HI FLOW LONG BBC W-PUMP WITH BETTER PUMPING IMPELER FOR BETTER COOLANT FLOW VS STOCK LOW COST PUMP WITH STAMPED STEEL COOKIE CUTTER IMPELLER.
* AUTOZONE 15356 STAT WITH BYPASS HOLE DRILLED THAT CONSISTANTLY MAINTAINES
A STABILIZED COOLING SYSTEM TEMP AT APPROX 10 DEG COOLER THEN A 180 DEG STAT DOES IN SUMMER TEMPS .
* ENSURED BASE TIMING IS ADVANCED ENOUGH BEING 18 DEG WITH A MILD AFTERMARKET PERF CAM I'M RUNNING + 10-12 DEG MAX FROM VAC ADV HOOKED TO FULL INT VACUUM ALL THE TIME.
* ENSURE IDLE , CRUISE , AND EVEN " WOT " (THOUGH NOT @ WOT MUCH!) FUEL CALIBRATION ISNT TOO LEAN INCREASING TEMP TOO.
* ENSURE THE MOTORS GETTING THE OCTANE IT NEEDS TOO BECAUSE TOO LOW OF OCTANE FUEL BEING RUN CAN INC TEMP A BIT TOO AND CAUSE RUN/DIESELING POST SHUTDOWN TOO. LEAD SUPREME 130 /A REAL LEAD OCTANE BOOSTER SOLD FROM " WILD BILL'S CORVETTES " WEBSITE CAN HELP OUT THERE IF NEED BE. I RUN IT IN MY BBC.
* ENSURE YOUR NOT RUNNING TOO HOT OF A HEATRANGE SPARKPLUGS TOO,I AM RUNNING 1 step cooler AC R43XLS's even though stock app calls for a 1 heat range hotter R44XLS plug. The cooler 43's have worked great for approx 8k miles so i will stick with them.
* ENSURE DUST SHIELDS ON UPPER A-ARMS/HOOD INSUALTION /COWEL TO HOOD SEALS ARE ALL PRESENT TO ENSURE THERES PROPER AIRFLOW UNDER HOOD WHEN AT CRUISE TO EXAHUST UNDER HOOD HEAT MORE EFFICIENTLY.
With the above setup my 396 now 402 mild cam'd bbc in 90+ deg heat runs 175-178 deg @ cruise & 180-185 in traffic with temp sender in head by exhaust port that typically runs 10-15 deg hotter then intake temps show on a warm summer day.
Before i did my tweaks (sealed airgap between shroud & rad core/installed HD hayden 2747 thermal fan clutch/installed autozone 15356 hi flow stat w-drilled bypass/installed Milodon hi flow cast iron stock rep pump/30% anti frz-70% dist water coolant mix for better heat transfer) to GM stock clutch fan cooling system setup in 85-90 frg outside temps my motor ran 20-25 deg hotter at cruise and 30-35 deg hotter in traffic then the temps i stated directly above post doing my rec tweaks to gm's clutch fan setup.
And in cooler 70-80 deg temps it runs approx 5 deg cooler accross board vs when in 90deg temps with a basically stock type cooling system thats setup with my rec tweaks/mods which is key .
I get the same great cooling results time after not matter what app my rec cooling system is applied to shows it worsks consistantly/reliably without any pricey aftermarket rad's or aftermarket elec fans for a mild to even fairly hot street perf bbc or sbc.
My rec tweaked clutch fan setup cooling system also works well with ahigh quality Aliumitech/Dewitt design aftermarket AL rad for chevelles too.
It flat out works as thier own words 1st hand testimonials from our fellow t/c members showed time after time no matter what perf lvl app (sbc or bbc) my rec tweakd gm clutch fan cooling system was applied too.
I guess you could say its shown to be a very versital /reliable/efficient cooling system setup thats works very well with many apps & many diff perf lvl's weather it be a bbc or sbc chevelle app.
Scott __________________ SCOTT 1969 CHEVELLE SS396/4SPD/M20/12BOLT/3:31'S ORIGINAL #'S MATCH/OWNED SINCE 1978. 1977 KAWASAKI KZ1000 (ORIGINAL OWNER) 1976 KAWASAKI KZ900 2006 YAMAHA 1700 ROADSTAR SILVERADO ================================================== ================
SCOTT
SWHEATON is offline
post #5 of 185 (permalink) Old Jun 9th, 13, 10:28 PM
Frankie
When I bought my car, it came with 2 Hayden 13" puller fans. I bought an Alumitech radiator, fabbed a shroud out of sheet aluminum and installed the fans. I also use the adjustable Hayden controller that allows the fans to cut on at 170. My sensor is in the intake so I am aware the head temps are +- 10 degrees hotter.
I do not have a/c. I do have my transmission plumbed into the radiator. No additional tranny cooler.
The car will run all day at 170-180 while on the hwy. Will creep up to 200 while in town with repeated stops in traffic. That is when it's 90+ degrees ambient. It is hot here in LA.
ID:	89746   Click image for larger version
Frankie
'69 Malibu
Best 60' - 1.34
Best et - 10.03
Best mph - 129.90
Dakenzie1 is offline
post #6 of 185 (permalink) Old Jun 9th, 13, 10:43 PM
So you had to modify/tweak new cooling system with elec fans to get it to cool to approx 200 deg intake temp that = approx 210-215 deg head temp on a hot 90 deg day.
Thats just not that good enough for time/effort/$$$$ spent IMHO when my rec modded clutch fan setup has proven time after time in many diff apps & perf lvls of sbc/bbc street perf motors it can consistantly cool to approx 180-185 deg in head temp (intake temp would be approx 170-175deg + - few deg vs your intake temp of 200+ with elec fans) in same 90 deg outside temp .
Thats approx 30-35 deg cooler on avg and i had a few that got 35-40 deg temp reduction going from elec fans to my rec setup while retaining same radiator what was running hot /220-230 deg with elec fans.
Not thats the real lowdown IMHO with testimonies to back it up too!!!/LOL!!!!
I CHALLANGE ANYONE TO SHOW ME MULT TESTIMONIES/TIME AFTER TIME OF FOR EXAMPLE MY REC CLUTCH FAN SETUP RUNNING TOO HOT IN 220-230 DEG RANGE ON A HOT DAY THEN GOING TO ELEC FANS WITH SAME RAD & REDUCING THIER MOTOR TEMP 30-40 DEG?
That i'd like to see because from my 42yrs+ 1st hand exp wrenching these motors /cars it just isnt going to happen time after time like the testimonies i posted for you guys from your owm fellow t/c members in thier own words stating the clutch fan setups i rec blew awya the elc fans every time they tried my rec setup !!!/LOL!!!!!
SCOTT
SWHEATON is offline
post #7 of 185 (permalink) Old Jun 9th, 13, 11:01 PM
Frankie
Scott, I am able to pull to the starting line at 160 and turn off my electric fans for a pass. And I do like the clean install of the fans.
But I do wonder, how much hp do i actually save by being able to turn off the fans as opposed to the setup you speak of?
Even though I have the electric setup, I am totally neutral and want the best cooling I can get. But 1/4 mile times are VERY important to me as well.
Is there factual data on the power loss?
Frankie
'69 Malibu
Best 60' - 1.34
Best et - 10.03
Best mph - 129.90
post #8 of 185 (permalink) Old Jun 9th, 13, 11:41 PM
Bo
Scott. You would be better off just saying something like the following, instead of reporting the same info over and over, ad nauseum.
"Electric fans can work. However, I see great results with stock type set ups. PM me for more info."
You look really defensive and nobody really knows why.
If it cools it cools!
burrodebo is offline
post #9 of 185 (permalink) Old Jun 9th, 13, 11:43 PM Thread Starter
Matt
The question discussed above is whether electric fans can pull air thru aluminum radiators and whether those properly engineered systems cooled as they should. There were no questions about stock cooling systems. Mr Dewitt gave a very nice answer to the original question.
Street Rod Pix
34 Ford Sedan
65 Chevelle SS
Chevelle album
oktunes is offline
post #10 of 185 (permalink) Old Jun 10th, 13, 1:00 AM
Greg.
Yes the right Efans & a right Aluminum Rad will cool down a old BBC
Last year at the track coolant temps were going over 200*
with a 160* & without a thermo stat and a 1" tubedx2 alum BeCool Rad/ 16" Fan, NO Shroud
when doing back to back runs on a hot day at the track.
I installed a New HP 1.25" Tubed Alum Rad & Dual Spal 11" Fans with a Shroud that I purchased from Don at Alumitech Reproductions
First time at track for TNT on a hot 30+ day with no thermo stat & the new cooling system
when doing back to back runs the coolant temps never got over 180*
made a total of 8 runs for the day .
I drive my car to the track, about 20 mins in city driving and 20 mins on the hwy
then change to track tires & back to streets when I drive back home
not once did the old girl's temp get above 190*
Thanks to Don's/Alumitech great cooling system .
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.561
1/8 = 7.411 et / 90.18 mph
1/4 = ??.??? et / ??? mph
Kirk's67SS is offline
post #11 of 185 (permalink) Old Jun 10th, 13, 11:18 AM
Thank you! It does get old seeing the same testimonials over and over. I don't think anyone would dispute the fact these cars cooled fine when they left the show room. Scott's recommendations work because it brings the system back to they way it should be and eliminates a poorly designed, backyard engineered system. It doesn't need to overwhelm every discussion on cooling.
I understand Scott's passion, because when you know something works you want to help others. I do the same thing with aluminum radiators and fans and it is frustrating when people play the "vendor bias" card. Testimonials are a nice pat on the back but they don't influence anyones decision.
I don't beleive in "cookie cutter" solutions because everyones motor is now unique. They have been bored, modified cams, heads, ignition, and fuel systems and/or some combination of these. The heat produced from the engine may not be the same as it was when it left the show room and what happens when the bone stock cooling system doesn't work? That is when aluminum radiators can help. If the radiator alone doesn't do the trick, then more air flow will bump it up some more. Cooling threads should focus on the OP application, what (exactly) they have tried, temperatures, and what that person ultimately wants.
Tom DeWitt is offline
post #12 of 185 (permalink) Old Jun 10th, 13, 11:22 AM
OK,here we go again,your temp never went over 190 deg on drive hone ,i bet that was intake temp which = approx 200 and in some cases 205 deg in head temp in watrme outside summer temp which is where gm monitored temp in old gen sbc/bbc motors form approx 69 & up.
200-205 deg isnt unacceptable but its not great when the cheaper clutch fan setup can get the 200-205 intake temp down to 180-185 deg in same hot cond using your same rad.
The motors like 180 + - few deg much better then running hotter at approx 200-205 deg.
But none the less your al rad & elec fans setup is doing well enough as is that wont cause any problems and or issues either so happy motoring.
SCOTT
SWHEATON is offline
post #13 of 185 (permalink) Old Jun 10th, 13, 11:37 AM
Vince
I just find it interesting that folks need an alum rad/elec fan for their "HP" engine when my crusty ~30-40y/o 3 row rad and clutch fan are keeping my 502's 600+hp nice and cool. Could only imagine what a new clean 3 row rad would do for me!
*69 SS 502 EFI /224* HR/9.8:1/T56/3.90 11.5/124mph
*11 C6, 6.2, 6spd
*96 Stang 6.0 turbo 10.5/135mph
*2011 Mustang GT premium
*61" Scag Kohler 22hp 7mph
69-CHVL is offline
post #14 of 185 (permalink) Old Jun 10th, 13, 12:22 PM
If you actually produce 600 hp for about a minute what happens to the temperature?
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #15 of 185 (permalink) Old Jun 10th, 13, 12:52 PM
Vince
Once again ankle-biter onovakind strikes again.
I wouldn't know what happens after one minute of WOT...my guess is the temp would climb. I'm more worried about real-world applications like sitting in traffic for 15-20 minutes, 1/4 race once in a while, extended highway usage. I dont particpate in theory, what-if's, and "gotcha" stuff like yourself.
*11 C6, 6.2, 6spd
69-CHVL is offline
This Thread is more than 1146 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
