Radiator - Chevelle Tech
post #1 of 11 (permalink) Old May 28th, 08, 4:09 PM Thread Starter
Marcus
Radiator
Just finished the installation of my 489 dynoed to 567 hp in my 64 chevelle. Went with a alumitech rad but since I wanted a crossflow radiator I ordered a Camaro BB 67-69 rad, like the look of a crossflow better and since there never was any BB chevelles in 64 and it was what I wanted I built it the way I wanted. It was a very nice piece and almost a direct fit had to trim the support a little and the bracket on the radiator for the batterytray and the support to frame mounts theres limited room for washer jar and alternator regulator if you are going to run powersteering but since I removed both the washer jar and runs an internally regulated alternator there was plenty of room. But the best part it seems to cool my new engine without a problem I´m running dual spals but the termostat switch hasent turned them on yet, but it´s still not real summer here in Sweden think it was around 65 degrees last weekend this weekend it´s going to be 85 degrees but I´m sure it won´t have any troubles cooling the engine the spals really move air when they starts to running have them hooked both thru the termostat switch and a on/off switch so I can force them to run. It´s a short waterpump setup. Thanks Don!
Marcus
Heres some pictures of when I pre mounted it and did the triming
Heres clearence when engine is in.
Pictures of how it looks when everything is hooked up.
This is the car from the outside.
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is online now
post #2 of 11 (permalink) Old May 28th, 08, 8:26 PM
Re: Radiator
That should scare some Volvos.............
Dave Bradley
d1_bradley is offline
post #3 of 11 (permalink) Old May 28th, 08, 10:00 PM
Mark
Re: Radiator
Nice!
Mark
1970 SS396
Lewis Racing Engines (
) 489:
634 HP @ 6000rpm
627 Lb-ft @ 4,000rpm
Gear Vendors Overdrive
Moser 12 Bolt
Radiator
Pypes Exhaust
Xtreme70SS396 is offline
post #4 of 11 (permalink) Old May 28th, 08, 10:09 PM
Re: Radiator
Interesting concept ...most cross flow conversions use a smaller core and no room for the twin spall set up .. tight between the frame rails but shes in there .
Well now i know if somebody wants to go that route it will fit .. thanks for the in put and pics .
go get them Volvos !!!
Don
ALUMITECH REPRODUCTIONS is offline
post #5 of 11 (permalink) Old May 28th, 08, 10:40 PM
leo
Re: Radiator
Good Job, you won't be able to keep rear tires on that ride.
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #6 of 11 (permalink) Old May 28th, 08, 11:01 PM
Re: Radiator
Marcus. If I may ask, where did you install the thermostatic switch to cycle the fans on and off on the engine?
Looks great.
Chris.
When the Boogeyman goes to bed, he checks the closet for Chuck Norris.
If it aint broke, just give me a minute.
Chris R is offline
post #7 of 11 (permalink) Old May 29th, 08, 1:32 AM Thread Starter
Marcus
Re: Radiator
Chris mounted it on the intake since I have an airgap intake theres two waterbosses in the rear of the intake do not know if it΄s the ultimate place, but it made the wiring more invisible.
Marcus
post #8 of 11 (permalink) Old Jun 21st, 08, 10:09 PM
sealy
Re: Radiator
Sweet ride.
Thank you very much for posting this. I need to replace the radiator on my '64 300 on the cheap and the '69 Camaro radiator is at least $50 cheaper and it's a 3 core and not a 2 core, at least with the OEM replacement sites. I actually have a '69 radiator in the car now and didn't know it until I measured it, found this post and then looked for an oem raidator and the specs are spot on. Thanks again man you saved me!
csealy.31 is offline
post #9 of 11 (permalink) Old Jun 27th, 08, 1:28 PM
Re: Radiator
If I may ask, which radiator hoses are you using? I went down to my local NAPA and they couldn't really help me, since my 66 had a center outlet for the upper hose. They offered to let me buy them all, figure out which one fits and bring the rest back- but I dont want to go through all that hassle.
Thanks!!
steves1967 is offline
post #10 of 11 (permalink) Old Jun 27th, 08, 1:59 PM Thread Starter
Marcus
Re: Radiator
The top one is Camaro 69 BB and the lower one Camaro BB 68 had to cut both to fit proper.
Marcus
post #11 of 11 (permalink) Old Jun 28th, 08, 1:38 AM
Re: Radiator
Thanks alot!!!
This Thread is more than 4232 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
