Best Method to Burp Cooling System - Chevelle Tech
 6Likes
  • 1 Post By 77 cruiser
  • 2 Post By Malibu ss 64
  • 2 Post By LeoP
  • 1 Post By BillyGman
post #1 of 11 (permalink) Old Jul 4th, 20, 12:49 PM Thread Starter
I'm firing up my new 454 motor for the first time and want to make sure ALL the air is out of the cooling system, especially the block. Any tried and true methods? The car is a '71 w/ AC.
Paperman54 is offline
post #2 of 11 (permalink) Old Jul 4th, 20, 1:23 PM
Re: Best Method to Burp Cooling System
1/8 inch hole or 2 drilled in thermostat.
Saltherring likes this.
77 Monte
11.93 @ 112.7 & tuning
77 cruiser is online now
post #3 of 11 (permalink) Old Jul 4th, 20, 1:24 PM
Marcus
Fill it with the heater hose removed from the intake or the thermostat housing and thermostat removed and you will have most if not all air out of the system.
BillyGman and Hotwire like this.
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is offline
post #4 of 11 (permalink) Old Jul 4th, 20, 4:06 PM
I don't worry about it during breakin unless the temp gauge goes whacky with wild swings in temp. Once the breakin is done, I monitor the temp gauge, if its not going nuts all is good. If it is then I just stuff a water hose into the waterneck after the thermostat opens and force the air out. If the temp gauge is rock steady there is no air in the system.
oldcutlass is offline
post #5 of 11 (permalink) Old Jul 4th, 20, 10:33 PM
leo
I simply run the engine til it gets up to temp with the radiator cap off. Do you have a reservoir on the system and a proper recovery cap??
LS7 and MidLife72 like this.
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #6 of 11 (permalink) Old Jul 4th, 20, 10:48 PM
You can't idle for a long period of time before breakin. The object is to get the rpms up right away.
post #7 of 11 (permalink) Old Jul 4th, 20, 11:35 PM
This may sound a little crude, but what I've done in the past is to fill the system up to to the radiator cap opening and/or the thermostat opening like Marcus said, and then raise the front end of the car 18" to 2 feet up in the air with a floor jack, and then top it off again with more coolant. Then after bringing it to operating temperature and running it for awhile, I let it cool down for a good 4 hours, and then raise the front end up in the air and top off the radiator again, and it's good to go. This ensures that your radiator neck is the highest point of the system. Or if you happen to have a driveway that's on a hill, you can just do the same with it parked there.
Malibu ss 64 likes this.
BillyGman is offline
post #8 of 11 (permalink) Old Jul 5th, 20, 9:45 AM
Don
I have a small Kioti tractor with a small 3cyl. deisel that I use for snow removal that I installed a block heater in for easier starts during the winter (Gets pretty cold in Upper Mi.) I knew it would be a long process to get the air out of the cooling system with the slow warm up of the deisel but the dealer that I got the unit from let me borrow a vacuum tool for refilling the system. I was not familiar with these but if I was still working at the Chevy store(retired) I'd definetely have one. I've always used the thermostat removal method in the past but this method works the fastest and easiest as far as I'm concerned,all you need is compressed air and your coolant mixture and when your done the only place you'll be adding coolant wil be topping off the recovery tank if you have one.
If your not familiar with this tool use the Google machine and check it out.
Don B is offline
post #9 of 11 (permalink) Old Jul 5th, 20, 1:04 PM
Cam
Cameron Milne
Good tip!
Know-How Notes: Using a Radiator Vacuum Tool ~
"The more you know,
TC Gold #120
Cam is online now
post #10 of 11 (permalink) Old Jul 5th, 20, 10:00 PM
leo
My system still works even during initial break-in!!
Leo Paugh
A.C.E.S.#3731
LeoP is offline
post #11 of 11 (permalink) Old Jul 5th, 20, 10:03 PM
I drill a 1/8” hole in the T-stat
67
70 (SOLD)
Alwhite00 is online now
