Fan Clutch and Fan - Chevelle Tech
 4Likes
  • 1 Post By sz0k30
  • 1 Post By Robinls5
  • 2 Post By branchdj
post #1 of 7 (permalink) Old May 23rd, 20, 9:38 PM Thread Starter
Dennis
Fan Clutch and Fan
Looking to replace my after market flex fan with more of the period correct look using a clutch fan for my 70 454 with AC 3 row radiator.. Its a convertible so I never use the AC .. Reading previous posts ,, Just want to confirm purchasing a 772 7 blade Fan from GM restoration parts with the Hayden 2747 Theramal fan clutch from Rock Auto seems the way to go.. Just want to confirm before I make the purchase
Thanks in advance
branchdj is offline
post #2 of 7 (permalink) Old May 23rd, 20, 11:28 PM
Re: Fan Clutch and Fan
This is a MAJOR " IF " ?? If your 1970-SS 454 came with factory C-60, The Rad. would be a 4 row Harrison. Along with the C-60 Pkg. AKA " VO-1 " cooling.
You have the large opening in the core support,-- Factory fan shroud-- Eaton fan clutch--394772 fan blade.
IF, your 1970 SS 454 is a 4 speed, The Rad. tanks will be stamped- " XJ " & " IF ". Also, If you 454 is a four speed, You will not have an idle screw on your 7040205 Q-Jet, You will have a Decel unit in place ( Its about the size of a sewing thimble). 70, A/C equipped Chevelles/El Caminos/Sprints all had, VO-1 cooling.
Robinls5 is offline
post #3 of 7 (permalink) Old May 24th, 20, 9:36 AM
Roman
Not disagreeing with Robinls5 at all, but if being exactly part number correct for your application is not an issue, then YES, 772 fan & Hayden 2747 clutch are absolutely the way to go.
boyd66k20 likes this.
sz0k30 is offline
post #4 of 7 (permalink) Old May 24th, 20, 3:35 PM Thread Starter
Dennis
Looks like I have the short water pump .. Measure about 5.75 ? Would the Hayden 2747 clutch still work or does that not matter ?
branchdj is offline
post #5 of 7 (permalink) Old May 24th, 20, 6:30 PM
Just a suggestion, I would try to get everything ( parts & Pieces) in the area of a stock 1970. Then as you make progress and spend money.......... It will all go together, And you will have not have future issues.
68-13427 likes this.
Robinls5 is offline
post #6 of 7 (permalink) Old May 24th, 20, 8:19 PM
Greg.
So if you have a Plastic/Nylon Shroud ( a must ) on the car now that covers the whole Rad Core
then you will want the New Fan/Clutch to be 1/2 IN and 1/2 OUT of the Opening
by getting the right length of Spacer for it
GrdUp https://www.ss396.com/ #s INL-15092 / INL-15091 / INL-15090
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is online now
post #7 of 7 (permalink) Old May 24th, 20, 10:03 PM Thread Starter
Dennis
Thanks.. I initial measure was incorrect.. I do have the long water pump.. So I should be good.. Sorry for the mix up .. Thanks again
LeoP and Kirk's67SS like this.
branchdj is offline
