Redish-Brown Sludge In Coolant System + White-Blue Crystals! - Chevelle Tech
 3Likes
post #1 of 18 (permalink) Old Apr 2nd, 20, 8:05 PM Thread Starter
This is what it looked like when I took of the upper radiator hose and removed the thermostat. I put in a new radiator, just wondering what else I need to do here? Do I need to flush the block out as well? Or will I need to start tearing it apart to clean it?
Thanks.
black64 is offline
post #2 of 18 (permalink) Old Apr 2nd, 20, 8:23 PM
Hank
Re: Redish-Brown Sludge In Coolant System + White-Blue Crystals!
Never seen anything like that before. I'm thinking maybe that stuff could be something that was added to the cooling system to stop leaks but that's just a guess. I would remove the block drain plugs and flush the motor out first with just plane water. I would then run a cooling system flush in the car and then flush it again with water. On the hoses running to the heater core I would flush it out with water both ways. I did this with the heater core in my car and was surprised how much the water changed in color flushing one way and then the other.
HKalin is offline
post #3 of 18 (permalink) Old Apr 2nd, 20, 9:46 PM
Greg.
In addition to what Hank said
I would use a Scope to check the Engine Block Coolant Passages if possible
I would find some kind of Cleaning Detergent that would eat up/clean out the Block Coolant Passages and Heater core
Then Recheck the Engine Block again with the Scope
If it was mine I would tear down the Engine and have the Coolant Passages thoroughly cleaned/Acid dipped
and if possible the same for the Heater Core, if not then Replace it with a new one
kmakar likes this.
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #4 of 18 (permalink) Old Apr 2nd, 20, 10:11 PM
When was the last time you had the engine running?
Have you ever seen it run?
LKN BCK is offline
post #5 of 18 (permalink) Old Apr 2nd, 20, 10:40 PM Thread Starter
I only ran it a couple times for about 5 minutes in the last 4 years...before that I don't have any history on it
black64 is offline
post #6 of 18 (permalink) Old Apr 2nd, 20, 10:43 PM Thread Starter
Thank you. I'm trying to look up some videos or write-ups that can guide me through this. I've also heard of people flushing the block with a garden hose. Any videos or resources you can recommend?
black64 is offline
post #7 of 18 (permalink) Old Apr 2nd, 20, 10:55 PM
Greg.
Forgot to mention the Rad Core would also need to Cleaned or Flushed out
I would just buy a New Rad
You can buy a Flush Kit that you Splice into one of your Heater Hoses that has a T that you Hook up the water Hose to
there should be Instructions with the Kit on which Heater Hose to Splice into
I just think it is NOT going to be enough to clean that stuff out of the engine Water Passages
unless you can find some kind of Cleaning Agent that will work at eating the Stuff down into Flush-able small material
Did you do a Search of " Flushing out a Engine "
NOTE you only need to Flush Out the Water/Coolant Passages that keep the Engine running Coll
DO NOT Flush out the Engine Oil and it's Passages for Lubing the Engine
Born 283 / PG / A51
60' = 1.664
60' = 1.547
post #8 of 18 (permalink) Old Apr 2nd, 20, 11:01 PM Thread Starter
I just think it is going to be enough to clean that stuff out of the engine Water Passages
Yep I have a new rad and flushed the heater core
Just to be clear you DONT think a flush will take care of it?
black64 is offline
post #9 of 18 (permalink) Old Apr 2nd, 20, 11:08 PM
Greg.
Added/Amended my above Post so please reread it
Maybe the Brown Sludge with the Right Chemical Deteragent
but I would be worried about that other Crystel Stuff
being in Nooks and Cranys that would not be easy to Flush out IMHO
Born 283 / PG / A51
60' = 1.664
60' = 1.547
post #10 of 18 (permalink) Old Apr 3rd, 20, 1:08 AM
Al
Does it look as though the crystallization is in the engine or heads/manifold? Maybe the coating or metal of the thermostat housing is all that developed that white stuff. You can do the block flush with chemicals and flush back and forth with a garden hose and see what comes out of the block. Then install a coolant hose filter in the upper radiator hose and check it regularly until satisfied, If it's a number matching engine and you don't want to risk damaging the block, I would do a complete tear down hot tank and rebuild.
I've seen the brown sludge before. From Nalcool and anti-leak clay bars the dealers were throwing in the 96 lt1's. But never that scale of crystallization.
DUTCH MAX HEADWORK is offline
post #11 of 18 (permalink) Old Apr 3rd, 20, 2:24 AM
mike
I agree with Al, that housing material seems to be the culprit, it's contaminated on the outer side as well. Replace housing and flush w/ cleaner.
slowmo55ss is online now
post #12 of 18 (permalink) Old Apr 3rd, 20, 8:31 AM
That engine was likely sitting dormant for a long time
before you got.
Kirk's67SS likes this.
LKN BCK is offline
post #13 of 18 (permalink) Old Apr 3rd, 20, 8:33 AM
Looks like electrolysis of the thermostat housing.
67ss4spd is offline
post #14 of 18 (permalink) Old Apr 3rd, 20, 10:17 AM
Yeah, pot metal housing, I'd pull the lower hose, maybe pull the water pump, if it looked clear (as in not blocked) then I'd flush and forget all about it. If I found that crap in the water pump or anywhere else, I'd be concerned. How solid is it? Does it crumble to the touch, look like it could break off and be floating around clogging heater core?
Pioneer4x4 is offline
post #15 of 18 (permalink) Old Apr 3rd, 20, 2:38 PM Thread Starter
It crumbles pretty easily and seems to dissolve into small pieces when in liquid. Just above the thermostat is the only place I have found it so far.
black64 is offline
