Leaking coolant - Chevelle Tech
 17Likes
  • 4 Post By marcrose
  • 1 Post By HKalin
  • 2 Post By blm
  • 2 Post By Kirk's67SS
  • 2 Post By DUTCH MAX HEADWORK
  • 3 Post By hessz24
  • 3 Post By oldcutlass
post #1 of 8 (permalink) Old Mar 27th, 20, 7:12 AM Thread Starter
Leaking coolant
Everytime I take my car out, the next morning I see coolant in garage floor. It doesn’t leak while driving or idling that I see, only when off and sitting? I think it’s coming from overflow hose on radiator. Should I be concerned? Just add a overflow bottle? Wasn’t sure if something major would make this leak. Thanks.
hessz24 is online now
post #2 of 8 (permalink) Old Mar 27th, 20, 9:16 AM
autumngold
Re: Leaking coolant
My 70 ss 454 doesnt have an overflow bottle from factory.You have to leave the radiator an expansion zone or it will overflow everytime.(3-4 inches low)
LeoP, HKalin, boyd66k20 and 1 others like this.
1970 ls-5 numbers matching
marcrose is offline
post #3 of 8 (permalink) Old Mar 27th, 20, 10:13 AM
Hank
Re: Leaking coolant
Take and tighten up all your hose clamps it could be seeping out there.
Kirk's67SS likes this.
HKalin is online now
post #4 of 8 (permalink) Old Mar 27th, 20, 2:16 PM
blm
Re: Leaking coolant
So have you been adding to the radiator after each time it overflows? If so it will keep overflowing. A few inches below the neck is the max fill level.
If you have not been adding coolant/water then its leaking or possibly a bad cap.
LeoP and Kirk's67SS like this.
blm is offline
post #5 of 8 (permalink) Old Mar 27th, 20, 2:44 PM
Greg.
Re: Leaking coolant
Hard to tell as we do not know if it is a Chevelle Question and what year !
When you turn off/sut down the Engine after a drive it will heat up more until it starts to cool down
so when it heats more than when the car was running the Coolant is likely expaining and pushing out at the Rad Cap
see Post # 4 and 3
Adding a Overflow Bottle to the Overflow Tube means no more Coolant on the Garage Floor
but that does not address why it is flowing out, see Post # 4
LeoP and DUTCH MAX HEADWORK like this.
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is online now
post #6 of 8 (permalink) Old Mar 27th, 20, 2:53 PM
Al
Re: Leaking coolant
Put a closed system recovery tank and radiator cap. Welcome to modern technology and innovation.
DUTCH MAX HEADWORK is offline
post #7 of 8 (permalink) Old Mar 27th, 20, 6:34 PM Thread Starter
It’s a 70 Chevelle 350. My fault, I fill the radiator too high. It’s definitely coming from overflow hose. Thank you everyone for straightening my dumbass out. Now onto fixing the leaky power steering gearbox.
LeoP, davewho1 and Kirk's67SS like this.
post #8 of 8 (permalink) Old Mar 27th, 20, 10:21 PM
Re: Leaking coolant
If you look on the engine side of the radiator below the filler neck you will see a fill line. Usually just over the trans cooling tube.
LeoP, davewho1 and boyd66k20 like this.
oldcutlass is offline
