772 Fan - Chevelle Tech
  • 1 Post By berg1954
post #1 of 4 (permalink) Old Mar 26th, 20, 5:34 PM Thread Starter
772 Fan
I am looking for a good source for a 772 fan. I am using a Hayden 2747 clutch fan. I have read some posts on here where some suppliers 772 fans aren't compatible with the Hayes 2747 clutch. I don't need one that looks 100% correct I just want one that works.
I see one on Jegs for $100 but it has the part number 691-3947772 that someone on here had a problem with as far as the bolt diameter not matching the 2747 clutch.
My shroud opening measures 19.25" and I believe the 772 measures 18" so that should be ok.
Thanks for any suggestions.
1970 SS396 Chevelle
468 ci, TH 400, 3:73 posi
SS468 is offline
post #2 of 4 (permalink) Old Mar 26th, 20, 8:56 PM
Mark
Re: 772 Fan
Hi Chris,
I am one that had the problem with the miss matched fan a couple of years ago. The first fan that did not fit correctly was from Jegs. I did contact them about the problem which they may have corrected by now.
Another member of this forum steered me to a DR Classic ebay site that had the fan that fit. Here is the link
from that old thread
https://www.ebay.com/itm/Camaro-Chev...f1abfd&vxp=mtr
I purchased one directly from DR Classic.
Hope this helps.
Mark
Not2Fast likes this.
Mark
66 SS
berg1954 is offline
post #3 of 4 (permalink) Old Mar 27th, 20, 8:34 AM Thread Starter
Re: 772 Fan
Thanks very much Mark. I just ordered it from DR Classic.
1970 SS396 Chevelle
SS468 is offline
post #4 of 4 (permalink) Old Mar 27th, 20, 9:04 AM
autumngold
Re: 772 Fan
Ebay has multiple 772 fans oem ,date coded if you need one.
1970 ls-5 numbers matching
marcrose is offline
