Pressure switch necessary on a/c? - Page 2 - Chevelle Tech
 11Likes
post #16 of 21 (permalink) Old Feb 9th, 20, 11:53 AM
Re: Pressure switch necessary on a/c?
1972 Chevelle and most other Chevys of that year.
72 A6 compressor had the superheat switch mounted on the backside and the thermal limiter switch was on the fender.
Oh, it was 72 then, I was thinking 74
post #17 of 21 (permalink) Old Feb 9th, 20, 1:13 PM Thread Starter
Brandon
I traced the compressor wire on my 71 and it runs to the ambient temp sensor on the evaporations box. I'll just tap the pressure switch in those wires.
Ive got everything ordered to replace everything on the a/c system and reuse the existing evap box. With seeing some debris and crud in all of the lines I don't want to skimp on something and have to do it over again. And the previous owner already replaced the heater core, blower motor, and complete car wiring harness so I should be pretty good.
bjl95mustang is offline
post #18 of 21 (permalink) Old Feb 10th, 20, 5:20 PM
Originally Posted by swampy 6x6 View Post
HI
Blow out plugs
compressor and receiver driers can have them
Wouldn't that be sort of a designed-in epa violation? Or maybe not back when these were made...
'71 chevelle, 468, TH400, 12 bolt posi w/3.08's, drinks a lot of 87 octane.
v8440 is offline
post #19 of 21 (permalink) Old Feb 10th, 20, 5:48 PM
HI
Those inbuilt safety plugs only operate when the situation of system catastrophic failure occurs . Controlled explosion of system eg in the event of an accident .
If the EPA was that concerned ,, the operation of system high pressures would be specified . The high side pressures are by far responsible for the majority of leaks in most vehicles .
swampy 6x6 is online now
post #20 of 21 (permalink) Old Feb 10th, 20, 8:45 PM
hi
In various GM cars with an orifice tube and accumulator , the super heat switch is a pressure switch senses ultra low pressures when the evaporator is full of cold low pressure liquid and sending excess liquid back to the compressor . The design is a safety aspect for the compressor . If the system is working properly the safety switch should not be used .
In the 90`s even some GM cars were retrofitted with such devices .
Biggest issue with those is some factory accumulator / POA / orifice type aircons were designed really badly by GM ..
Although not every model .
A thermal switch is an overheating compressor disconnect and /or operates a warning light/ac light flashes . GM pls many other brands use this idea
OOPS, I thought this was about 64-72 Chevelle A/C systems.
post #21 of 21 (permalink) Old Feb 10th, 20, 10:59 PM
HI
Most factory Gm are now not running the exact factory spec
refrigerant change to start with.
upgraded R134a compressor , H/D condenser, R134a evap core ,thermostat used a lot .Poa valve not always used .
accumulator instead of r/drier .
In the auto a/c industry upgrades occur often not just Chevelles . Older GM systems do not perform as well as more modern independent designs by some specialists eg Nippon Denso who supply to the auto industry .
Now if u upgrade properly any poor performing older GM a/c can be improved . Keep in mind R134a is low performing refrigerant compared to R12 . That's why upgrades are needed to compensate in the first place .
Qualified Mechanic with years of a/c specialist experience and the appropriate licensing
If it has had wheels Ive fixed or help fix the A/c . Trains /trucks /buses/small planes /cars .
If it come in the shop I`m not refusing to work on it .
LeoP likes this.
