Accessory Fan - Chevelle Tech
 13Likes
post #1 of 26 (permalink) Old Dec 14th, 19, 2:28 AM Thread Starter
Accessory Fan
There’s a good thread that gives a lot tips for proper cooling, like fan clutch and shroud and other things but it doesn’t mention anything about an accessory fan when engine is idle, when stuck in traffic.
Would it be a good idea to put this fan in front of my radiator that I can turn on when in traffic?
https://rover.ebay.com/rover/0/0/0?m...2F264506525254
jelco is offline
post #2 of 26 (permalink) Old Dec 14th, 19, 7:02 AM
Re: Accessory Fan
No it would block air flow through the radiator and cause more heat by working the engine harder to make the electric to run it.. Those things are good for moving air inside the cab for heat or ac but that's it..
Kirk's67SS likes this.
hydro462 is offline
post #3 of 26 (permalink) Old Dec 14th, 19, 8:37 AM
Re: Accessory Fan
I run a fan very similar to that over the top of my 4L60E transmission fluid cooler but that's about all its good for.
shovelrick likes this.
B52bombardier1 is online now
post #4 of 26 (permalink) Old Dec 14th, 19, 10:52 AM
Greg.
Re: Accessory Fan
What Jeff said
The worst thing you can do is to put something that will Restrict the Air Flow in Front of the Rad
The only DownFall of the Mechancial Fan is the slower the Engine RPMs the less the M Fan pulls Air thru the Rad
This is where Efans work better as they are at their Highest Pulling of Air all the Time
hydro462 likes this.
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is online now
post #5 of 26 (permalink) Old Dec 14th, 19, 12:16 PM
Re: Accessory Fan
The 454 Suburban I did have before the 5.7 one I have now had an electric fan in front of the radiator that came on when needed.
post #6 of 26 (permalink) Old Dec 14th, 19, 5:40 PM Thread Starter
What do you do when your car is idling in bumper to bumper traffic? Rely on electric fans?
jelco is offline
post #7 of 26 (permalink) Old Dec 15th, 19, 7:59 AM
Re: Accessory Fan
Ever feel how much air a clutch fan moves at idle when fully engaged? To me it feels like a lot more then one of those electric fans at full speed. Remember, I am talking about a properly functioning clutch fan with the bi metal correctly adjusted.. I would venture to say most of them are NOT correctly adjusted. I had to teach myself how to adjust them since there are no directions that I could find..
These fans are so cool, the way they work, the way they look, how efficient they operate. I can't get over that people would want those ugly electric things with all that wiring all over the place.. I guess I'm just an old head from the Duntov 30/30 era. I love how we did things back in the sixties and seventies before all this ugly, complicated tech came in and took the fun away from these cars..
hydro462 is offline
post #8 of 26 (permalink) Old Dec 15th, 19, 10:26 AM
Greg.
Re: Accessory Fan
Yes as that is all I have on my car
No room for a Mech Fan either
And have have never had a Blowout/overflow of Coolant
Dependent on the day's Temp the Temp Gauge reads from 160* to 190*
71350SS and shovelrick like this.
Born 283 / PG / A51
60' = 1.664
60' = 1.547
post #9 of 26 (permalink) Old Dec 15th, 19, 11:22 AM
Greg
I am thinking about removing the stock fan and clutch from my 396 1966, it has never really kept it from the verge of overheating in stop and go traffic. At least the electric fan will always be consistent with his much air they are moving.
Kirk's67SS and shovelrick like this.
Life is too short for caring about every bodies else's stuff
Grock-co is online now
post #10 of 26 (permalink) Old Dec 15th, 19, 3:32 PM
Re: Accessory Fan
I run my two Cold Case electric fans completely separate from each other. They each have their own power, ground, relay, temperature probe and adjustable thermostat for complete redundancy and safety. This is Four Seasons part number 35879 but I use two of them.
Regardless of engine temperature, the relay even kicks the passenger side fan on instantly when the AC compressor clutch engages. This is needed to control AC compressor head pressures.
post #11 of 26 (permalink) Old Dec 15th, 19, 4:27 PM Thread Starter
Hydro462, how do you adjust them? I think vintage air has one I almost bought. Do you have a 7 blade fan and fan shroud? Any idea what fan shroud a 64 uses? It probably depends on the radiator you have. I think the original radiator was square, mine is clearly not.
I also need to add a temperature gauge.
And tachometer. Might has well replace the dash but they’re $700!
jelco is offline
post #12 of 26 (permalink) Old Dec 15th, 19, 4:34 PM
Greg.
Re: Accessory Fan
I have one Efan on a Temp Sender at the Thermostat Housing in the Intake set at 160*
and the 2nd Efan on a Toggle Switch under the Dash which I usually only have to turn on when in City Traffic
or the Temp Gauge reads 190*
They both have their own Relays & Power from the Battery Red + Post
You can get the Wiring/Temp Sender from SPAL like I did
If you have a Stock DF Rad with a Core that = 16" Hi x 23.5" Wide then this is the SPAL Dual 11" Efans you need
and which I also have
https://www.spalusa.com/products/fan...2ffans%2f11%2f
If you need a Rad then Dewitts sells the one like I have in my 67
and you will have to get them to attach Brackets to it so you can attach the Efans/Shroud kit
OR just buy the complete setup from them.
I have the Manual one # 1149002M and run a small Separate Trans Cooler
https://www.dewitts.com/collections/...minum-radiator
JEGs or other places sell them cheaper
DO NOT use the Temp Prob for in the Rad
Born 283 / PG / A51
60' = 1.664
60' = 1.547
post #13 of 26 (permalink) Old Dec 15th, 19, 7:02 PM
Greg
I was thinking why even use a thermostat switch I was just going to wire the relays to the ignition, car running the fans are on simple no extra stuff to go wrong.
post #14 of 26 (permalink) Old Dec 15th, 19, 9:23 PM
Re: Accessory Fan
No good--believe it or not an engine can run too cool for it's own good.It's not that common nowadays but years ago you would see lots of cars with cardboard blocking their grills during the winter.
Not counting drag engines a street cars engine will not run good at too cool of a temp.Some people have used a switched fan and that can work if you watch it's temps all the time.The problem with that style is people tend to forget to hit the switch.The best coolant fans use a coolant switch that is in one of the cylinder head ports and comes on automatically when the engine reaches a set temperature.Doing it this way at most highway driving speeds the fans are just along for the ride.
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #15 of 26 (permalink) Old Dec 15th, 19, 9:58 PM
Beth
Re: Accessory Fan
You have received a lot of incorrect information.
Chevy produced a lot of high performance big blocks that stayed cool with a shroud, fan and thermal clutch.
Nothing special needed.
The thermal clutch fan locks up and turns the 6 to 7 blade fan one-to-one at idle. It will flow a lot of air and with a correct shroud the engine will stay cool.
The clutch starts to slip at higher speeds when the car is moving and no longer needs help to move air through the radiator.
Stock parts work.
The only reason modern cars went with electric fans was front drive cars have the engine turned sideways.
The engine can't drive a fan when it isn't facing the radiator !
nashville beth is offline
