Cold Case radiator, rust spots? - Chevelle Tech
 13Likes
  • 1 Post By bikeron
  • 4 Post By yanniziomas
  • 1 Post By Molly's 70
  • 1 Post By eric_cspan
  • 3 Post By 72soft-top
  • 1 Post By BillK
  • 1 Post By Ccass
  • 1 Post By yanniziomas
post #1 of 15 (permalink) Old Dec 8th, 19, 6:10 PM Thread Starter
The radiator is 1.5 yrs old. Wonder why I get these spots (rust?) on all 4 corners, core leaking or just grime from engine bay?
I run distilled water with Red Line water weater, no antifreeze.
Changing engines, would like to make sure the radiator is in good shape before it goes back in.
Thanks for any advise.
ID:	610264   Click image for larger version
ID:	610266   Click image for larger version
ID:	610268   Click image for larger version
yanniziomas is offline
post #2 of 15 (permalink) Old Dec 8th, 19, 6:48 PM
Ron
Re: Cold Case radiator, rust spots?
Have you pressure tested the radiator? Looks like aluminum so I would not expect rust..
Ccass likes this.
My car is here:
bikeron is offline
post #3 of 15 (permalink) Old Dec 8th, 19, 6:51 PM
Vince
Sure looks like corrosion...but on an aluminum radiator
Must be contaminates in the aluminum.
*2011 Mustang GT premium
*61" Scag Kohler 22hp 7mph
69-CHVL is offline
post #4 of 15 (permalink) Old Dec 8th, 19, 9:06 PM Thread Starter
It is aluminum, that’s why this is strange. I can think of what else can it be really. I haven’t pressure tested it, it’s outside of the car, I should probably find a shop to do that.
post #5 of 15 (permalink) Old Dec 8th, 19, 9:20 PM
Vince
did you spill any of the water wetter??
ask the manufacturer what this could be...
it does look strange though..
VinceS427bb is online now
post #6 of 15 (permalink) Old Dec 8th, 19, 9:35 PM Thread Starter
I did not, and if I did it’d be on the cap/driver side, strange thing is all 4 corners have that corrosion which confuses me. Been trying to clean it w/Simple Green, scrub it a bit and it’s not coming off so it’s not surface rust, really strange.
I’ll contact Cold Case next week to see what’s up.
post #7 of 15 (permalink) Old Dec 9th, 19, 4:58 PM Thread Starter
I spoke w/Cold Case, sent the pictures and they will replace the radiator.
That’s great that they stand by their product considering the minimal miles it has on it 👍
post #8 of 15 (permalink) Old Dec 9th, 19, 5:01 PM
That's excellent customer service!
68-13427 likes this.
If you lend someone $20, and never see that person again, it was probably worth it.
Molly's 70 is online now
post #9 of 15 (permalink) Old Dec 9th, 19, 5:38 PM
I'm just curious to see the inside.
How does the inside down the filler tube look?
Where do you live?
Water and water wetter won't protect it like adding a little coolant will. I'd try a green 50/50 mix on your replacement.
RAIDER SS likes this.
eric_cspan is offline
post #10 of 15 (permalink) Old Dec 9th, 19, 7:22 PM
Glad it will be replaced under warranty. Things like this always influence my future purchases
72soft-top is offline
post #11 of 15 (permalink) Old Dec 10th, 19, 8:49 AM
Mr Bill
Thatís great that they stand by their product considering the minimal miles it has on it 👍
Did they give any indication as to why it was doing it ? Like the others said if it is aluminum it shouldn't be "rusting" unless it is leaking and the entire cooling system is rusty.
Is this a street car or a race car ? If its on the street I would certainly be running some type of coolant.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
post #12 of 15 (permalink) Old Dec 10th, 19, 11:29 AM
I have been using a Cold Case radiator for a few years now and I have no sign of corrosion however I use antifreeze. Your pics almost look like its discolored from the flux used in solder and possibly not cleaned after assembly. Although most damage is caused by not using distilled water, which you are, water alone does not provide any protection. Here is a decent article on the subject with some possible causes.
https://appliedspeed.com/blogs/tech/...d-create-leaks
Billdini is offline
post #13 of 15 (permalink) Old Dec 10th, 19, 1:43 PM
Send a message via AIM to Ccass
I just saw this topic. I was going to say to do a pressure test on it. Sure looks like a tiny weep hole.
Before you install the new radiator, I'd flush the motor. Sure looks like you have some junk going on in the motor if that radiator is in fact weeping.
bikeron likes this.
Fool around, get hurt, don't come crying to me.
Founder
Pypes Performance Exhaust
Cold Case Performance Radiators
Ccass is offline
post #14 of 15 (permalink) Old Dec 10th, 19, 2:53 PM Thread Starter
Thanks everyone.
The whole cooling system was flushed when I installed this radiator new, and also new water pump at the time.
I’m putting a new crate engine in the car over the winter, so the replacement radiator will go in at the same time with a clean block/engine.
I will also flush the heater core and lines before all this goes back in.
I do use distilled water, the radiator is leaking somewhere, but it happens. Important thing is that the manufacturer is taking care of the issue, and I know that’s what is important to many of us. the radiator has been great in keeping the car cool 👍
Kirk's67SS likes this.
post #15 of 15 (permalink) Old Dec 10th, 19, 4:10 PM
kevin
Really like mine in the '68. Good to see they are standing behind it...
the heckler is offline
