Heater/AC control troubleshoot - Chevelle Tech
  • 1 Post By Dean
post #1 of 6 (permalink) Old Nov 16th, 19, 11:04 PM Thread Starter
My blower motor does not work (brand new). I am not certain my Heater/AC control unit in dash is good. Is there anyway to check to make sure it is functional? 1970
Ryan T is offline
post #2 of 6 (permalink) Old Nov 17th, 19, 10:19 AM
Re: Heater/AC control troubleshoot
There are 5 parts to the function of that system.
1. Blower motor.
2. Blower switch
3. Blower relay
4. Blower resistor
5. Wiring
If you have a test light and a shunt of wire you can pretty well troubleshoot the fault. If you have an ohmeter it would be even better for testing some parts.
The first thing I would do is check to make sure the electrical circuit has energy. Check for broken or disconnected wires. Check fuses under the dash and under the hood.
Next check to see the motor itself works by jumping a wire directly from the battery to the blower motor.
If both good, it could be as simple as replacing the relay or resistor. If you know the wiring diagram you can test those out rather than replacing.
The fan switches can fail but since they are mechanical they seem to be more durable than the resistors and relays which are electro mechanical.
We really need to know what you are capable of doing and what tools you have to proceed.
I donít like being manipulated!
Alan F is offline
post #3 of 6 (permalink) Old Nov 17th, 19, 4:11 PM Thread Starter
I have a test lamp and multimeter. I have wiring diagrams just not real electrical savvy. Thanks in advance for your help.
Ryan T is offline
post #4 of 6 (permalink) Old Mar 25th, 20, 9:21 AM Thread Starter
Sorry still working on this issue. Iíve tried to run a jumper...see below i posted on Facebook but not getting any responses.
Secondly the ground to the blower motor is good but if i put a jumper to try and power it the jumper sparks like crazy and the fusible link glows red. Instead of jumping from battery to blower i am jumping the red wire and purple wire in the pigtail thatís connects to relay. Now let me ask this also. If my heater box resistor is bad would that cause this to spark? But yesterday i tried same thing but went from battery to blower motor and it sparked a lot so i immediately stopped. Really struggling here. Lol
Ryan T is offline
post #5 of 6 (permalink) Old Mar 25th, 20, 10:54 AM
IF any of the resister wires are grounding out, yes it will spark.
Try disconnecting the resister wires and jumper 12 volts directly to the motor lead.
LeoP likes this.
post #6 of 6 (permalink) Old Mar 25th, 20, 1:40 PM Thread Starter
Are you speaking of the blower motor resistor on the heater box? Disconnect that and the jumper straight to battery?
Ryan T is offline
