What is this? - Chevelle Tech
 3Likes
  • 3 Post By modern malibu
post #1 of 8 (permalink) Old Oct 20th, 19, 9:00 PM Thread Starter
What is this?
So I am replacing the heater core in the car. It’s been 10years with no heat so I am think I’ll hook it back up. But what the heck is this thing in the heater box? There are 3 wires and a plug for it.
Man those old brass heater cores are sure heavy compared to the aluminum one I got.
ID:	606022   Click image for larger version
1968 Beaumont
502 big block
HP and ET not determined yet!
GoFast Beaumont is offline
post #2 of 8 (permalink) Old Oct 20th, 19, 9:17 PM
Mark
Re: What is this?
Blower motor resistor used to vary the speed output of the motor.
LeoP, 68-13427 and Hotwire like this.
modern malibu is offline
post #3 of 8 (permalink) Old Oct 20th, 19, 9:17 PM
Re: What is this?
Bower motor resister?
Pioneer4x4 is offline
post #4 of 8 (permalink) Old Oct 20th, 19, 11:06 PM Thread Starter
Re: What is this?
so this would go inline for the single orange wire that goes to the blower motor.
These resistors, are they known for failure?
1968 Beaumont
502 big block
post #5 of 8 (permalink) Old Oct 21st, 19, 12:06 AM
leo
Re: What is this?
Yes, failure is a possibility, it's old!!
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #6 of 8 (permalink) Old Oct 21st, 19, 1:00 AM
Jon N.
Re: What is this?
The orange wire feeds out of it. It connects to the fan speed switch to work as a resistor that gives you different the speeds. Minor difference in semantics, but in the end, it does control what comes out to feed the orange wire.
Jon N.
dyno jonn is online now
post #7 of 8 (permalink) Old Oct 21st, 19, 12:14 PM
Send a message via AIM to Ccass
Re: What is this?
pretty sure they are available in reproduction for under $20
Fool around, get hurt, don't come crying to me.
Founder
Pypes Performance Exhaust
Cold Case Performance Radiators
Ccass is offline
post #8 of 8 (permalink) Old Oct 21st, 19, 2:28 PM
Re: What is this?
Definitely replace it, it's much harder when installed. The resistors are wire wound resistive coils. They heat up when current runs through them, reason they're mounted to the air box, it keeps air blowing over them to keep them from burning up.
Not sure if your box is the same as mine, my 64 has a narrow opening, I got a cheaper resistor, it was wide, touched metal and would short out blowing the fuse. Had to order the expensive setup that fit correctly.
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
