Alternative heating? - Chevelle Tech
 14Likes
post #1 of 29 (permalink) Old Oct 11th, 19, 8:09 PM Thread Starter
I removed the hoses to my heater core long ago, so I haven't been running heat for ages now. I am thinking of removing the entire heating duct assembly under the dash, but I am wondering if there is a way of doing some sort of electric heater that I could install during the cold months or if I ever road trip the car.
Doable or am I thinking out of my a$$?
Youtube Channel.
Instagram:
Twitter:
-SS454- is offline
post #2 of 29 (permalink) Old Oct 11th, 19, 8:50 PM
Re: Alternative heating?
There are electric heaters that plug into cigarette lighter sockets for cars, we used to see them at the various car parts catalogue stores like J.C. Whitney. Check E-Bay, google it.
Dave Ray is offline
post #3 of 29 (permalink) Old Oct 11th, 19, 8:51 PM
It would take a lot of amps at 12 volts to equal very many watts of heating. And you would need a hole lotta' watts in Canada!!
B52bombardier1 is offline
post #4 of 29 (permalink) Old Oct 11th, 19, 10:38 PM
Get one of those gasoline heaters like dad had and people use to put in Volkswagons.
https://www.ebay.com/i/262075604075?...EaAhomEALw_wcB
post #5 of 29 (permalink) Old Oct 11th, 19, 11:00 PM Thread Starter
Oddly enough I went to a cruise in tonight and a guy with a 69 Chevelle had a cab heater haha. It was horribly bulky and apparently dangerous so I'd pass on that one.
@B52bombardier1 my concern is the wattage as well. Typical space heaters are up to 1500 watts. I doubt i'd even need 1000 watts for the confined space of a car, really just my feet honestly.... but I'd assume that's stick quite a lot of power,.
Youtube Channel.
Instagram:
Twitter:
-SS454- is offline
post #6 of 29 (permalink) Old Oct 11th, 19, 11:23 PM
leo
My question is; what would you do for defrost on a rainy day and to defrost the windows on a cold, frosty morning??
71350SS, blm and Kirk's67SS like this.
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #7 of 29 (permalink) Old Oct 11th, 19, 11:50 PM
Jon
Adding a second heating solution when you have one already designed for the car seems silly IMHO. Stock heat is great. I would put it back in if you want to drive the car in the cold.
1972 Chevelle SS 454 "W" code
JChilders is offline
post #8 of 29 (permalink) Old Oct 12th, 19, 12:14 AM Thread Starter
I don't really drive the car in the rain, only had some mild fog up once. If it's so cold the windows are frosted, then I'm not driving it anyways. It's more of a if I go on a road trip kind of idea. Outside of the beginning of the year or the end of the year, it gets too hot in the car.
Youtube Channel.
Instagram:
Twitter:
-SS454- is offline
post #9 of 29 (permalink) Old Oct 12th, 19, 12:16 AM Thread Starter
I figure there might be 20 lbs I could shed. I've driven without heat for years now, since 95% of the time I don't need it. But once in a while, it would be nice.
Youtube Channel.
Instagram:
Twitter:
-SS454- is offline
post #10 of 29 (permalink) Old Oct 12th, 19, 12:30 AM
Rame
I'm starting to see options for aftermarket electric heat here and there. Nothing looks really good though. I'm guessing it's probably just a cheap clone of the instant heat option offered in new luxury cars. Perhaps an option would be to get an inverter and run a really small space heater and/or an electric blanket?
sampoerna415 is offline
post #11 of 29 (permalink) Old Oct 12th, 19, 1:23 AM Thread Starter
I have found a few camper 12V heaters that might work, if I can find one the right size. Some even have duct output ports, which would be ideal so I could run the ducts towards the feet, and/or to the windshield.
Youtube Channel.
Instagram:
Twitter:
-SS454- is offline
post #12 of 29 (permalink) Old Oct 13th, 19, 3:53 PM
With more electric cars being made, maybe looking at how they do their heat/defrost functions. Most likely they would be using a much higher voltage than what you can supply.
-SS454- likes this.
JWagner is offline
post #13 of 29 (permalink) Old Oct 14th, 19, 8:03 AM
Just run a piece of slant fin tubing along the dash and connect it to two hoses. Put a ball valve somewhere handy and your set... Or pick up a trans cooler and run hot water through it with a small fan on it.. Summit sells units all ready to go fan and all..
I made a steel vent and ran it across the passenger side exhaust manifold and into the cab of my el camino. Something like the old VWs had, works well...
https://www.supplyhouse.com/Slant-Fi...CABEgIorfD_BwE
hydro462 is offline
post #14 of 29 (permalink) Old Oct 17th, 19, 5:42 PM
fireplace?
BB68 is offline
post #15 of 29 (permalink) Old Oct 17th, 19, 5:43 PM
this will be like your wife's hair dryer on low setting
BB68 is offline
