Heating and cooling - Chevelle Tech
 13Likes
  • 3 Post By oldcutlass
  • 4 Post By hjdca
  • 1 Post By JWagner
  • 2 Post By jimbo13
  • 1 Post By Not2Fast
  • 1 Post By v8440
  • 1 Post By oldcutlass
post #1 of 14 (permalink) Old Sep 20th, 19, 9:08 AM Thread Starter
Heating and cooling
Hi, I have a 70 Chevelle with 454. A mechanical 19 inch 6 blade flex fan. A 4 core brass radiator which has been
rodded out and is in good condition. A 160 stat. New water pump and hoses. A add on a/c system.
I live in South Fl. It runs hot at idle and in traffic 220 to230. Out on I 95 at 60 mph it runs about 190 .
I would like to try the large 7 blade fan with fan clutch. And a aluminum radiator.
Where can I get fan and clutch ?
And recommendations for a aluminum radiator. Pros and cons.
I read about drilled thermostat . Can someone explain that. I have run car w/o thermostat and no difference in temps.
Thank you
jimbo13 is offline
post #2 of 14 (permalink) Old Sep 20th, 19, 9:25 AM
Re: Heating and cooling
You need to read up on how a thermostat works and what its function is. It has nothing to do with your issue. You may be on the right track with the fan, clutch, and radiator. You also need to look at your ign timing and a/f mixture settings, as well as the air flow through the radiator at idle.
jimbo13, LeoP and Kirk's67SS like this.
oldcutlass is offline
post #3 of 14 (permalink) Old Sep 20th, 19, 9:47 AM
Harry
Thank you
The good fan is a 772 Chevy original air cond. fan.. You can find good used ones on ebay. Just paint it black when you get it. You can also buy by a reproduction one, they still make them. Some say the older ones are better. I have an original one that I repainted. Make sure it has curved tips. For the clutch fan, get a Hayden 2747, this is the perfect length for our cars and performs like the original GM clutch fan. You also need a reproduction shroud. That's it ! It is a piece of cake to install and if your radiator is good, you should never have cooling problems again -- even with the air cond. running in 104 degree heat. This what I run with a griffin radiator and my engine will not go past my thermostat temperature opening even in LA heat with the air cond. on. in traffic. Here is a pic of the spacing with the fan and shroud in stalled with a Griffin aluminum raditiator on my Chevelle. Shoot for this spacing. It is a proven solution. Good Luck.
Harry
hjdca is offline
post #4 of 14 (permalink) Old Sep 20th, 19, 10:03 AM
My question is: Is your cooling system in your 70 a VO-1 or a copy of the VO-1? Why I am asking . I have a (ordered by me ) a 70 LS-5//M-22 with factory A/C.
My driver is a fake SS-468, 70 Nomad Wgn. with the VO-1 cooling and FACTORY A/C. My one owner has never overheated in the 49 years I have owned it. My driver with a 468 and a 700R has never overheated.
On a very hot day my driver with the 468 and the A/C operating will get up to 205-210 sitting in bumper to bumper traffic.
It runs at 185/ 190 on the highway with the A/C operating. Normal driving town/ highway it runs always around 170--185/190.
Also on the core support, LOOK between the Rad. tanks and the core support, You will see a GAP about 5/8"-3/4" wide. When the car is static or moving slow, This large GAP will allow the SUPER HEATED air in the engine bay to be DRAWN through this GAP and back into the Rad. This will cause the water temps to go up. I filled this GAP with some foam tape with a sticky back side from LOWES.
For a stock cooling system to be effective, It MUST have ALL the factory items in place. Both of my 70s have every tidbit in place as it left the factory and I have no issues with my stock 454 or the 468.
All of the factory item work together in concert, With factory items missing ,,, YES you will have cooling issues.
Robinls5 is online now
post #5 of 14 (permalink) Old Sep 20th, 19, 2:52 PM
Thank you
Runs hot at highway speed. New water pump, 160* thermostat, serviced old radiator that you say is in "good" condition. Let's assume that the water pump and thermostat are functioning as designed. Add-on AC, so the system has been modified from original GM design by a condenser in front of the radiator? Factory shroud in place and functioning correctly? Any impediments to the air flow through radiator and out of the engine bay, besides the AC condenser ?
I'd buy a new OE replacement radiator. They're cheap. You say "rodded out" and in good condition. I'd say likely not in good condition.
JJ'65 is offline
post #6 of 14 (permalink) Old Sep 20th, 19, 7:19 PM
It sounds like an air flow deficiency at idle. so improving the fan is a good idea. Lose the flex fan. Those things are trouble.
Do you have a fan shroud?
Kirk's67SS likes this.
JWagner is offline
post #7 of 14 (permalink) Old Sep 20th, 19, 9:17 PM Thread Starter
Thanks guys. I ordered the GM 772 fan blade and the suggested fan clutch today. I'll try this before changing radiator.
I'll space fan as shown in above picture as mine is tucked inside shroud presently. The condenser is only obstruction in front of radiator.
The shroud is a 71 model duplicate and it does cover the radiator core. I'll look for a gap between support and radiator when i stick the rad back in. My thought is not to make too many changes at once.
The ignition timing is in specs through out its curve.
I'll let you all know how it goes after road test.
Thanks again
Kirk's67SS and Ccass like this.
jimbo13 is offline
post #8 of 14 (permalink) Old Sep 20th, 19, 9:28 PM
Al
Thanks again
If you are running a 71-72 HD cooling fan shroud you should be running a 19 inch fan Part Number: 3989095. The 18 inch is not as efficient in the 71-72 shroud that was designed for a 19 inch fan.
DUTCH MAX HEADWORK is offline
post #9 of 14 (permalink) Old Sep 20th, 19, 9:31 PM
If the above doesn't work, and get rid of that 160 stat and drop in a 180, ditch that 4 row rad for a 2 row with some fat tubes in it. Oh yeah, more water than coolant is the way to go unless you live in a cold climate and run the car in the winter.
'69 Malibu
Not2Fast is offline
post #10 of 14 (permalink) Old Sep 21st, 19, 12:39 AM
Greg.
It runs 190* on the Hwy so that is okay
If he relocates the better Mech Fan at 1/2 In and 1/2 Out of the Shroud Opening
that should help too, as shown in Post # 3
And I agree with "Not To Fast " comment that a 4 Row Rad plus the A/C Condenser in front of it could be impeding the Air Flow
and thus a Alum Rad with only 2 Rows would be better for the Air Flow
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is online now
post #11 of 14 (permalink) Old Sep 21st, 19, 10:24 AM
I wasn't sure exactly what style radiator my '71 has, and this thread just prompted me to go outside and take a look. I knew it was aluminum, but I hadn't looked closely at the inside through the cap. Sure enough, it has 2 wide rows, which is the general direction the oem's have gone in with today's increasingly cramped engine bays. I CANNOT GET THIS CAR TO OVERHEAT. No doubt the rest of the system works well for it to be this way, but consider this another vote for a modern design with 2 wide rows.
'71 chevelle, 468, TH400, 12 bolt posi w/3.08's, drinks a lot of 87 octane.
v8440 is offline
post #12 of 14 (permalink) Old Sep 23rd, 19, 4:04 PM
The 19.5" 7-blade fan came on other cars, like big Pontiac, olds, etc of the 70s. A wrecking yard or eBay may be a good place to look
70GS455 is offline
post #13 of 14 (permalink) Old Sep 23rd, 19, 5:24 PM
If you haven't already, consider using this thermostat...https://www.flowkoolerwaterpumps.com...ree-thermostat
spoffie1962 is offline
post #14 of 14 (permalink) Old Sep 23rd, 19, 5:36 PM
This is not a thermostat problem its an airflow problem at idle.
