Kick down cable help - Chevelle Tech
post #1 of 3 (permalink) Old Aug 5th, 19, 1:03 PM Thread Starter
So I converted my 66 283cid from a 4 speed to a auto TH350. I have everything mounted except the kick down cable to the carb which is a Rochester 4GC. Can anyone help with where the bracket goes, where the cable hooks up and if I need to adjust it how? Thanks for any help
WOODY367 is offline
post #2 of 3 (permalink) Old Aug 6th, 19, 11:26 PM Thread Starter
Re: Kick down cable help
Anyone? Maybe a photo to help how it is set up?
WOODY367 is offline
post #3 of 3 (permalink) Old Aug 7th, 19, 12:20 AM
mike
I'm fairly sure the cable comes up the driver side rear of carb., and either fits over a pin w/clip, or slides over an arm at the lower throttle arm, opposite the throttle attaching point. The throttle should pull the downshift cable forward when accelerating and should be fully extended at wot.
slowmo55ss is offline
