2, 3, 4 row radiator? - Page 3 - Chevelle Tech
 10Likes
post #31 of 33 (permalink) Old Aug 1st, 19, 10:23 PM Thread Starter
Ken
How many rows in your current radiator?
Does your a/c stay cool all the way down to idle and hold cool at prolonged idle?
This would be your Matson set up for your car. https://the-fan-man.com/product/64-6...igsmall-block/
I'm sure this is what my mechanic is recommending. Current radiator appears to be stock. Engine is a ZZ4 350 c.i.d. 355 hp, with Fi-Tech fuel injection. A/C is Vintage air and fan (with shroud) was upgraded to 6 blade clutch fan when A/C was installed.
Recently with stop and go around town driving, extensive idling in heavy traffic temp reached a bit over 220*. I didn't like that so that's why I'm looking into improving my cooling system. When I noticed the temp I turned off the A/C. It was cool at idle.
darksky is offline
post #32 of 33 (permalink) Old Aug 2nd, 19, 5:23 PM
Al
Re: 2, 3, 4 row radiator?
I really need to know how many rows your current radiator has to be able to recommend a replacement. Pull your radiator cap off and count the rows of tubes. It should be 2, 3 or 4.
You can definitely use a little added capacity in your cooling system.
DUTCH MAX HEADWORK is offline
post #33 of 33 (permalink) Old Aug 2nd, 19, 5:36 PM Thread Starter
Ken
Four (4) rows in current radiator. And, CORRECTION: fan is a 5 blade (not 6 blade) clutch fan.
67 Chevelle Malibu, ZZ4 350 crate engine, TH350, FiTech EFI, Vintage Air, Dakota HDX dash, FlowMaster exhaust,
17" Rally style wheels, Redline tires
darksky is offline
