Heater control cables - Chevelle Tech
post #1 of 12 (permalink) Old Jun 26th, 19, 8:38 PM Thread Starter
Terry
I am at the point of installing my heater box and controls on my 68'. My original cables are broken at the plastic tabs, and i was wondering who sells the best quality replacements. Thanks, Terry
68-13427 is offline
post #2 of 12 (permalink) Old Jun 27th, 19, 8:50 PM Thread Starter
Terry
Re: Heater control cables
bump
68-13427 is offline
post #3 of 12 (permalink) Old Jun 28th, 19, 10:19 PM Thread Starter
Terry
Nobody has replaced their heater control cables? Terry
68-13427 is offline
post #4 of 12 (permalink) Old Jun 29th, 19, 2:44 AM
Levon
Never used this place but maybe they can help you?????????????
The Part Guy - Chevelle, El Camino, Malibu & Monte Carlo Heater & A/C Controls & Parts
or here??
https://www.bobschevelleparts.com/ca...able&year=2662
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is offline
post #5 of 12 (permalink) Old Jun 29th, 19, 4:42 PM
I have everything out of a 69 including cables and clips and the heater core. Would that work ina 68? If you need them let me know.
SPRSPT69 is offline
post #6 of 12 (permalink) Old Jun 30th, 19, 1:24 PM Thread Starter
Terry
SPRSPT69, Thank you for the offer. I'm not certain the '69 cables will work in the '68, some catalogs are year specific, and some are'68-'72. I wanted to use new cables because i have already tried using 2 different sets of used cables, and the plastic mounting tab are so brittle from age they just break off, and the new cables iv'e seen have metal mounting tabs. Terry
68-13427 is offline
post #7 of 12 (permalink) Old Sep 19th, 19, 9:12 AM
Did you get your cables replaced yet? Just acquired a 68 el camino and having issues with the heater controls... looking at replacing the unit and cables..
Heetseeker is offline
post #8 of 12 (permalink) Old Sep 19th, 19, 8:39 PM Thread Starter
Terry
Steve, I have not yet purchased new cables, decided to continue assembly without a heater for now. Terry
68-13427 is offline
post #9 of 12 (permalink) Old Sep 19th, 19, 11:22 PM
I used these https://www.ebay.com/itm/202024158160
Ebay: EZ-Slider Cable Set, 1968 - 1972 Chevelle El Camino w/o A/C (3Pcs) [26-3571]
'69 Malibu
Not2Fast is online now
post #10 of 12 (permalink) Old Sep 20th, 19, 12:51 AM
I used reproduction heater cables on my 65 Skylark and they were less than great. The lever movement is very stiff and I fear the control levers may break. I have been trying to locate some good OEM cables to replaces the aftermarket parts.
dell72 is offline
post #11 of 12 (permalink) Old Sep 20th, 19, 8:51 AM
Lew
I got some reproduction I think from OPGI, Year One or Ausleys and they worked fine. Make sure all your other stuff works I had to get my control panel moving better on mine. You think it is a cable issue and it is something else. On my 1965 getting the level/cable angle right was very important in getting it to move freely.
Lew540 is online now
post #12 of 12 (permalink) Old Nov 18th, 19, 1:21 AM
Purchased new cables today at OPGI.
Heater/AC Control Cables, 1968 Chevelle/El Camino, 3pc
Part# CH26786 $70
That should take care of part of my issue, and ordered a control head from thepartsguy shortly after.
Took the el camino out for a run today, and the heater core let go. Well, it is 40 years old! Looks like i'll have my shop project for the winter set up for me.
