Aluminum fan shroud - Chevelle Tech
 11Likes
post #1 of 18 (permalink) Old Jun 13th, 19, 9:56 PM Thread Starter
Aluminum fan shroud
My fan shroud is all cracked and broken.
I want a nice aluminum shroud but I haven't really found one. My car isn't original so I feel no need to buy a factory replacement.
Anyone have something they like that they used?
Binford is offline
post #2 of 18 (permalink) Old Jun 14th, 19, 8:23 AM
Re: Aluminum fan shroud
We make one if you buy our combo kit
Ask around locally. Someone local should be able to bend some metal and make one for you though.
LeoP likes this.
eric_cspan is offline
post #3 of 18 (permalink) Old Jun 14th, 19, 12:09 PM
Marcus
Summit has adjustable alu shrouds.
https://www.summitracing.com/search/...an-shroud-kits
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is offline
post #4 of 18 (permalink) Old Jun 14th, 19, 1:21 PM
Send a message via AIM to Ccass
Aluminum shrouds are normally made for electric fans. They are very low profile and not suited well for mechanical fans. You could fabricate one by going to a local heating and AC place. However, by the time you are done, you probably will spend more money than a plastic reproduction costs.
Kirk's67SS likes this.
Fool around, get hurt, don't come crying to me.
Founder
Pypes Performance Exhaust
Cold Case Performance Radiators
Ccass is offline
post #5 of 18 (permalink) Old Jun 14th, 19, 2:30 PM
Marcus
The summit shrouds are for mech fans.
Ccass likes this.
post #6 of 18 (permalink) Old Jun 14th, 19, 3:25 PM
Greg.
Not a fan of Metal Shrouds as they tend to absorb and maintain Heat in a place you want to move Heat from
A good Repo Plastic/Fibre Shroud that covers/fits the whole of the Rad's Core and is Cone shaped is what you want
plus the Mech Fan Blades should be 1/2 In and 1/2 Out of the Shrouds Hole Opening
if you have a Clutch on it, it should be about a 1" to 1.5" from the Rad Core so it senses it's Temp
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is online now
post #7 of 18 (permalink) Old Jun 14th, 19, 3:43 PM Thread Starter
Damn it, I hadn't really thought of the heat sink affect. I guess I'll just buy a replacement black plastic one.
Where's the grumpy face smiley?
427L88 and Kirk's67SS like this.
Binford is offline
post #8 of 18 (permalink) Old Jun 14th, 19, 4:11 PM
You know? I rushed and never even clicked on the link. Now that I look, those are not bad.
The one thing I'd be cautious about is to make sure it fills the rad width and height wise. Otherwise for an extra $30, you can have a direct fit OEM style shroud.
Founder
Ccass is offline
post #9 of 18 (permalink) Old Jun 14th, 19, 7:10 PM
The whole inside of the engine compartment is mostly metal including the fan blades right behind the clutch, do you honestly think this is a problem.
That is a pretty decent looking shroud and cheap enough to try.
dell72 likes this.
oldcutlass is offline
post #10 of 18 (permalink) Old Jun 14th, 19, 8:25 PM Thread Starter
https://www.jegs.com/i/Allstar+Perfo...EaAnBeEALw_wcB
I was actually looking at this one. I looked at the summit ones too.
I wouldn't need to mess around with a HVAC shop or any of that junk. I have more then enough tools and knowledge/skill to build my own. It's a simply a matter of time. I have no time and I am currently up to my knees in work on this car and I need a quick fix. I don't like the plastic ones and I was hoping that you hardcore chevelle guys had some specialty source that didn't yield on my quick Google search.
While the heat sink might not be a huge deal I happen to like that kind of out of the box thinking about things. When you look at the history of shrouds manufacturers started using plastic pretty quickly when alot of other parts where still being made from steel. (In the 50-60s) something to think about.
Anyway since there really wasn't a honey hole reply. And I'm a slammed for time. I'm trying to drive this car yet this summer, I'll just buy a replacement for 80 bucks and call it good.
Maybe I can mess around with building my own down the road, if I'm still interested in it.
Thanks for the replys.
Binford.
LeoP likes this.
Binford is offline
post #11 of 18 (permalink) Old Jun 15th, 19, 10:17 AM
I tried one of the ones from summit, didn’t work out all that well. They are a flat box with no contour. Some welding required to make it function properly.
Air doesn’t want to flow through it. What you end up with is air being pulled through just where the fan is, any other area is like a dead zone. I like the allstar design, looks like it would work better.
SSJohn is online now
post #12 of 18 (permalink) Old Jun 15th, 19, 12:59 PM
Greg.
YES
Have you ever put your hand on or touched a Metal Shroud VS a Plastic/Fibre Shroud
Why are all the New cars/Trucks Shrouds Plastic/Fibre
and it is not because they are lighter than thin Alum Metal
Cheaper is not always better and if it does not work
then you end up having to buy something you should have bought in the First place
When the Metal Fan Blade is pulling the Air over it's self it does not get Hot
unlike the Metal Shroud
Born 283 / PG / A51
60' = 1.664
60' = 1.547
post #13 of 18 (permalink) Old Jun 15th, 19, 1:57 PM
Greg.
Depending on the year of your Chevelle and the size of the Rad
the Plastic/Fibre Shrouds from GrdUp are in the same Ball Park for cost as the Metal Allstar one
https://www.ss396.com/mm5/merchant.m...ry=Fan+Shrouds
Just make sure you buy the Shroud that covers the Whole Rad core
Binford likes this.
Born 283 / PG / A51
60' = 1.664
60' = 1.547
post #14 of 18 (permalink) Old Jun 16th, 19, 9:19 PM Thread Starter
67. And summit carries one. And only 100 bucks for free shipping.
Binford is offline
post #15 of 18 (permalink) Old Aug 25th, 19, 11:34 PM Thread Starter
http://www.superchevy.com/features/6...rolet-chevelle
Found this older article. This is want I want for my radiator. If I could find such a thing. Not sure this wasn't home made.
Binford is offline
