72 SS Dash swap. Dash vents different sizes?? - Chevelle Tech
post #1 of 9 (permalink) Old Jun 7th, 19, 2:52 PM Thread Starter
So I restored a 72 Monte Carlo dash to replace my sweep dash. In the middle of swap and the dash vents are different sizes? The existing sweep dash vents are 3 1/4” diameter, but the MC dash vents are 3 3/4”? In addition the MC vent angles toward the side of the car and the existing one was straight. Am I missing something here? Obviously my existing duct work won’t fit the larger diameter vents.
ID:	595270   Click image for larger version
ID:	595274   Click image for larger version
72soft-top is offline
post #2 of 9 (permalink) Old Jun 7th, 19, 8:03 PM
Re: 72 SS Dash swap. Dash vents different sizes??
Those are non A/C vents in that dash.
RealRed70 is offline
post #3 of 9 (permalink) Old Jun 7th, 19, 10:43 PM Thread Starter
Well shucks. The MC non AC vents are fully restored with new chrome vents installed. I think I will just transition the duct mismatch with some silicone adapters.
post #4 of 9 (permalink) Old Jun 7th, 19, 11:15 PM
Levon
Brian, do you have A/C?
The transition pipe on the drivers side is unique for a round bezel dash. The pass side is the same for sweep/round dash if I recall correctly.
Dan has more expertise in this than I and he may be able to suggest the best outcome/direction to go.
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is offline
post #5 of 9 (permalink) Old Jun 7th, 19, 11:36 PM Thread Starter
I do have AC. For the AC ducts, both sides are 3 1/4” round dash vents. For the MC non-AC vents I have, both sides are 3 3/4” round, but the drivers side has a flat on the bottom. I think I can make it work using a 3 3/4” x 3 1/4” reducing elbow on the pass side. I will use a 3 3/4 coupling on the drivers side.
post #6 of 9 (permalink) Old Jun 8th, 19, 10:18 AM
If you have the A/C vents from the sweep dash, why don't you buy another set of the louvers and restore those. You can easily sell the non A/C vents you have restored now. Monte Carlo and Chevelle vent are all the same, along with Elcamino and Wagon for the 70-72 model years. If what you are trying to do does notwork out for you, I do have the correct duct for the SS/ Monte style dash.
post #7 of 9 (permalink) Old Jun 8th, 19, 7:05 PM Thread Starter
So I bit the bullet and replaced the chrome from the non-AC MC vents to the correct smaller duct AC vents.
post #8 of 9 (permalink) Old Jun 8th, 19, 11:23 PM
Levon
Red face Re: 72 SS Dash swap. Dash vents different sizes??
Brian, how did the bullet taste?
Sorry I just couldn't resist.
Glad you have it sorted out.
Levon Hovagimian
Team Chevelle #279
LevonH is offline
post #9 of 9 (permalink) Old Jun 9th, 19, 9:04 AM Thread Starter
Originally Posted by LevonH View Post
Brian, how did the bullet taste? [IMG class=inlineimg]/forums/images/Chevelles_2016/smilies/tango_face_devil.png[/IMG]
Glad you have it sorted out. [IMG class=inlineimg]/forums/images/Chevelles_2016/smilies/tango_face_smile.png[/IMG]
Just one of those things. Getting near the finish line and had to redo the vents. All good now. A new day for progress.
