Thoughts on Cold Case Radiator - Chevelle Tech
 13Likes
  • 3 Post By BRN2RUN
  • 4 Post By V1rotate
  • 4 Post By Malibu ss 64
  • 2 Post By Kirk's67SS
post #1 of 4 (permalink) Old May 27th, 19, 6:43 PM Thread Starter
I thought I would comment on the radiator that I recently purchased . I was making a swap from 307 to 454 in my 69 Chevelle so the stock radiator wasn't going to cut it. I did a lot of research and wound up buying a Cold Case unit. The staff was VERY helpful and being a Team Chevelle member I got a good discount .
The packaging was excellent and it at first glance it easy to see the quality of this unit . Everything FIT LIKE A GLOVE !
My engine is a mild 461 and so far the engine hasn't gotten above 170 degrees, I am very pleased and would recommend this product to anyone .
Ccass, Kirk's67SS and eric_cspan like this.
BRN2RUN is offline
post #2 of 4 (permalink) Old May 27th, 19, 7:22 PM
Re: Thoughts on Cold Case Radiator
I installed a Cold Case in my 70, it's a big block with A/C. The quality and fitment of the radiator is great and the coolant temp never gets above 180.
I would also recommend this product.
Ccass, BRN2RUN, Kirk's67SS and 1 others like this.
V1rotate is offline
post #3 of 4 (permalink) Old May 28th, 19, 3:54 AM
Marcus
Great info!
Cold case seems like a good vendor. If I was in the market for a radiator I would most likely buy on from them.
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is offline
post #4 of 4 (permalink) Old Jun 5th, 19, 9:42 AM
Greg.
Count me in to
If and when I need a New Alum Rad I will buy from Cold Case
My current Alumitech Rad is still working great and is only 7 years old / bought in May 2012 from Don
BRN2RUN and eric_cspan like this.
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.561
1/8 = 7.411 et / 90.18 mph
1/4 = ??.??? et / ??? mph
Kirk's67SS is offline
