Vintage Air vs Old Air Products - Page 2 - Chevelle Tech
 5Likes
post #16 of 27 (permalink) Old May 24th, 19, 8:53 AM
Installed Vintage air car had no ac or heat 67 was a learning experience but works great it was installed in PR which was needed, also bought crimping tool to extend my hose under and up to driver side, plus their support is excellent
Bradco is offline
post #17 of 27 (permalink) Old May 24th, 19, 5:56 PM
rkd
Ron
Re: Vintage Air vs Old Air Products
Put a Classic Auto Air system in the 66. Directions were good, it fit, it works and they were good on the phone for the few questions I had.
Had my local guy make up the hoses and charge it. Woking great after two years.
Recommend the electronic control module vice trying to use the original Chevelle stuff.
rkd is offline
post #18 of 27 (permalink) Old May 30th, 19, 1:22 AM
Ken
I had Vintage Air installed in my 67 Chevelle a year and a half ago. Works great, cold A/C, hot heat. The only downside is the fan noise at since the entire unit is inside the car under the dash. The new glove box supplied is now just that, big enough for only a pair of gloves.
darksky is offline
post #19 of 27 (permalink) Old May 30th, 19, 6:14 AM
Guy
Originally Posted by 658Chevy View Post
I know this for sure about Vintage Air, and it's probably the same for other brands, but an after market system won't have a provision to introduce outside air -- it just recirculates inside air. That creates a potential for severe fogging of the windshield. Whatever you do, do not turn on the defrost while driving. Under the right conditions, it will completely fog over the windshield and blind you. I found that out while driving on a winding mountain road. It can be very dangerous.
As for the lack of outside air and fogging windows, I called Vintage Air and asked what the fix was. They said, "Roll down the window". At first I was furious as I just spent a lot of time on money on their system, but it does work. If I'm driving and the windows start to fog over, I just crack the driver's window. It only takes a small amount of air to balance it out.
I installed a heat/defrost Vintage Air unit in my '86 Monte SS and discovered the same issue.
Imagine my surprise after thinking how well this works then after 5 or 10 minutes the inside of the windshield fogged up.
I also contacted Vintage Air and they told me much the same as they told you,roll the window down.
Now that I know what to do I don't mind,and it's way better than the factory setup was.
Guy
'86 Monte SS,
513 Stroker,
AFR CNC'd 315 heads,
Isky .904 EZX Roll lifters,
9 inch rearend,
TC Member # 4921
GuysMonteSS is offline
post #20 of 27 (permalink) Old May 30th, 19, 8:35 AM
I'm going to do a Classic system on my 70 El Camino. I agree with all that has been mentioned about Classic thus far.
Additionally, I'm told that only Classic has a repairable evaporator assembly. The others are apparently sealed units and would be destroyed trying to take them apart. Hopefully I won't ever have to repair it but it's nice to know I won't have a boat anchor if it fails.
B52bombardier1 is offline
post #21 of 27 (permalink) Old May 30th, 19, 7:56 PM
In the 90's here today. Drove out to Philip's house to have him buy me lunch. Took my Chevelle. Sure was nice to have my Vintage Air working to keep me comfortable for the 90 mile round trip............thanks for lunch, Philip!
66 Malibu
busterwivell is offline
post #22 of 27 (permalink) Old May 30th, 19, 9:36 PM
Aeroquip makes great reduced barrier hose and the EZ Clip system that requires no crimping tool. Works GREAT! The reduced size hose routes and bends well without kinks. I want to find out how well the Restomod Air systems work if anyone has a comment.
traveler is offline
post #23 of 27 (permalink) Old May 30th, 19, 10:17 PM
That doesn't make sense, air-conditioning dehumidifies and outside air brings in humidity.
post #24 of 27 (permalink) Old May 30th, 19, 10:27 PM
I'm not certain, but I believe the principle is that we, as drivers/passengers, add humidity to air that is constantly recycled in the cab. Fresh air generally has less humidity than our bodies provide (breath, insensible loss, body warmth, etc). The effect is even worse if your clothes are wet. Try it in a car that has the option to introduce fresh air and turn that feature off. It'll have the same result.
von likes this.
658Chevy is offline
post #25 of 27 (permalink) Old May 30th, 19, 11:01 PM
that's it
post #26 of 27 (permalink) Old Jun 1st, 19, 11:11 AM
Les
I don't have experience with other after-market brands but, I recently installed VA in my 65 El Camino and, I'm favorably impressed with how well it works and, with VA's customer service. I haven't had an opportunity to test the defroster yet but, I'll be curious to see if I get same fogging issue. I haven't installed their glove box yet but - from test fitting - I can see it may be a challenge to make it fit.
Les
65 El Camino (LS2 Project)
83 El Camino (DD)
04 Corvette Convertible
14 Cruze
Skylarkul is online now
post #27 of 27 (permalink) Old Jun 1st, 19, 12:08 PM
Getting my new VA install charged Monday. My process has been mixed. Install generally went okay, but I think I've been dealing with a faulty ECU. VA had me send them the ECU and control panel and said they were good and sent me a second new wiring harness. After install of the second harness, the system exhibited the same bad behavior, so I could pretty much rule out wiring errors as both times I followed instructions/diagrams to the T. After the system randomly started working again they agreed to send a backup ECU. They've generally been responsive and helpful, though it did at times feel like they were quick to blame wiring, when it felt pretty clear to me, by the nature of the problem I was experiencing, it had to be internal circuitry failures. That said, I imagine most of the errors they do see day to day are from install issues.
Also, it seems like this market is ripe for someone who can develop a kit like VA or Classic Auto Air, but have it be engine side and able to bring in fresh air.
sir_apoc is offline
vintage air sknappy Heating & Cooling 7 Jul 19th, 16 11:04 PM
Sale of the Week - Vintage Air and Serpentine kit specials MCB Sponsors 4 Feb 3rd, 16 12:26 PM
non factory air conversion with vintage air sknappy Heating & Cooling 9 Feb 26th, 15 8:51 PM
Today's Special: VINTAGE AIR Products! MCB Sponsors 4 Dec 22nd, 14 6:53 PM
Vintage Air in 66 myrusty66 Heating & Cooling 24 May 20th, 13 2:19 AM
