Optimal engine temp sbc - Chevelle Tech
post #1 of 2 (permalink) Old May 17th, 19, 10:46 AM Thread Starter
Hey guys I have a 67 with a 400 engine in it. It heats up to 210 degrees. I was wondering if this is too warm. Also, if it is too warm do you have any advice on cooling it? Thanks
Drewmaci is offline
post #2 of 2 (permalink) Old May 17th, 19, 12:40 PM
Re: Optimal engine temp sbc
What thermostat is installed? Is that 210 at idle or cruising?
oldcutlass is offline
What weight oil do u use? lucky3 Performance 68 Jan 14th, 15 5:26 AM
Cooling issues Boneshaker8 Heating & Cooling 19 Nov 1st, 14 11:55 PM
GM 290 HP 350 SBC Crate Engine & AC R45TS 70-SS454 Engine 0 Oct 21st, 14 5:46 PM
327 running hot. runner Engine 20 Sep 30th, 14 9:26 AM
Engine Temp w/ A/C kernal Heating & Cooling 12 Sep 7th, 14 8:36 PM
