Radiator overflow reservoir - Chevelle Tech
post #1 of 11 (permalink) Old Apr 17th, 19, 8:06 PM Thread Starter
Anybody ever seen one like this, or know where I can find one? The front side is grooved and slides down over a metal bracket. Mine has worked for a couple years, but now it leaks. Thanks
Notes is offline
post #2 of 11 (permalink) Old Apr 17th, 19, 8:52 PM
Terry
Re: Radiator overflow reservoir
You can probably find one at your local auto wrecker. Terry
68-13427 is offline
post #3 of 11 (permalink) Old Apr 17th, 19, 9:38 PM
blm
Check out my pos t #6 in this thread. Got the lid off big Olds or Buick at a junkyard. Also post #10 has pics of same.
https://www.chevelles.com/forums/32-...flow-tank.html
blm is online now
post #4 of 11 (permalink) Old Apr 18th, 19, 10:25 AM
What is the purpose of the overflow unit? Is it for racing to meet tech specs?
Robinls5 is offline
post #5 of 11 (permalink) Old Apr 18th, 19, 12:27 PM Thread Starter
Bob, it was on the car when I bought it a few years ago. It worked - filled up when hot and level came back down again when engine cooled. It just started leaking. The metal bracket that it fits in looks stock, but I'm not sure what stock really was. Simplest fix is to find a replacement that doesn't leak, but I'm open to suggestions. Thanks
Notes is offline
post #6 of 11 (permalink) Old Apr 19th, 19, 9:41 AM
Todd
The one for a 76 Camaro works and looks good
tday815518 is offline
post #7 of 11 (permalink) Old Apr 19th, 19, 5:12 PM
I use a second windshield washer fluid for my overflow. Works good and looks good under the hood.
*Harley - 06 Street Bob
*Peach State Chevelle Member
*Retired June 1, 2014****
OLDED is offline
post #8 of 11 (permalink) Old Apr 19th, 19, 5:13 PM
Cool Re: Radiator overflow reservoir
Stock? Year, make, and model? I see a piece of plain old mild steel angle iron in your picture. Not likely stock. Time to get over to the junkyard and do a little shade tree auto engineering.
JJ'65 is offline
post #9 of 11 (permalink) Old Apr 20th, 19, 4:26 PM
autumngold
I second the camaro one ,1976-1981 works and fits perfect
1970 ls-5 numbers matching
marcrose is offline
post #10 of 11 (permalink) Old Apr 21st, 19, 11:38 AM
Mick
82-87 Camaro GM Part #s Tank 14070997 Tank Cap 15630112 Rad Cap 10409635
mick
70 chevelle
Frame off restoration
402 4 speed 3.55 posi
mick402 is offline
post #11 of 11 (permalink) Old Apr 21st, 19, 2:13 PM
Todd
That's the one, works great on my chevelle
68 SBC W/ remote reservoir pump dell72 Brakes, Suspension & Steering 0 Mar 26th, 19 12:07 PM
66 BBC power steering reservoir hose esko ss Brakes, Suspension & Steering 6 Feb 21st, 19 5:38 AM
What bolts mount the windshield washer reservoir? Bruce71convt Restoration Corner 1 Oct 26th, 15 8:06 PM
Where to mount washer fluid reservoir ? tucson67ss Restoration Corner 13 Jul 16th, 15 12:07 AM
Correct Power Steering Hose for 67 Big Block with external reservoir? mbondoni Engine 1 Mar 23rd, 13 4:43 PM
