72 Heater core replacement - Chevelle Tech
 2Likes
  • 1 Post By Dean
  • 1 Post By NickeyChevelle
post #1 of 10 (permalink) Old Apr 6th, 19, 3:02 PM Thread Starter
Hello I'm new to the forum,
I have a 1972 Chevelle with a bad heater core. Are there any threads with advice or instructions on how to take on this project. Photos would help. Thanks
Killer1972 is offline
post #2 of 10 (permalink) Old Apr 6th, 19, 3:28 PM
Re: 72 Heater core replacement
https://www.google.com/search?source...30.PKvwE4dUIZU
post #3 of 10 (permalink) Old Apr 6th, 19, 8:01 PM
Bruce
This site's search function is your friend.
chevelle-427 likes this.
Our You Tube Vids:
NickeyChevelle is offline
post #4 of 10 (permalink) Old Apr 6th, 19, 8:12 PM
Al
Not really, it pretty much sucks. You are better off doing a google search that brings you right back here. Maybe it's just me, but I have little luck finding stuff on this site using their search function.
DUTCH MAX HEADWORK is offline
post #5 of 10 (permalink) Old Apr 6th, 19, 10:56 PM
A no air car is pretty easy. A car with A/C is much harder.
oldcutlass is online now
post #6 of 10 (permalink) Old Apr 6th, 19, 11:33 PM
I just pulled mine out of my ‘68. Basically the same. Unbolt right inner fender so you can drop it enough to get your arm in there. Remove glove box. Disconnect control cables from the heater box. Remove all of the nuts & screws from the engine compartment side. The whole contraption drops down onto the passenger floor. You’ll see how the core is held by a clip with two screws on one side. Replace & reverse for assembly. If you’re good, you can knock it out in about four hours.
any4xx is offline
post #7 of 10 (permalink) Old Apr 6th, 19, 11:34 PM
Eek! You’re right. I was assuming a heat-only car.
any4xx is offline
post #8 of 10 (permalink) Old Apr 6th, 19, 11:35 PM
Bruce
Yes, I agree with you, I was thinking more along the lines of the OP signing up for this site solely to ask a question that's been covered plenty of times, and if he would have just taken the time to search (as you say on Google) he'd save us from having to spend time re-answering questions that we've already answered already before. I can't type and doing so is a hassle that I'm too old to endure.
Since he's posted twice, I assume he's here to mooch off Dean and not to contribute! Oops, that's not PC is it. Sorry.
Our You Tube Vids:
post #9 of 10 (permalink) Old Apr 7th, 19, 8:37 AM
Don't use aluminum. I'm not sure they even make the Chevelle heater core in aluminum anyhow but if they do don't use it. One nice thing about aluminum is when it springs a leak that aluminum hole patch up powder works real good with the aluminum core...
I used an aftermarket aluminum heater core in my 69 el Caminos home made heater system and it springs up a leak every spring lol.. Hey! spring! LOL!!
hydro462 is offline
post #10 of 10 (permalink) Old Apr 7th, 19, 10:00 AM
Buy a GM service manual. If you are inclined to go more advance get a GM Overhaul manual. There is even a Fisher Body Service manual. All with specific info for the given model year. Lots of information for the entire car. Lifetime references. I still have all of mine.
zookpr is offline
This Thread is more than 366 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Heater core replacement hessz24 Heating & Cooling 14 May 7th, 19 10:38 PM
Replacement heater core, copper or aluminum BanditRX Heating & Cooling 5 Dec 15th, 18 6:51 PM
69 non A/C heater core replacement robpp Heating & Cooling 8 Nov 12th, 16 10:20 AM
72 Chevelle Heater Core Question BobOly Heating & Cooling 7 Dec 22nd, 12 9:43 AM
72 Chevelle Heater Core BobOly Heating & Cooling 2 Dec 18th, 12 1:15 AM
