leaks embarrassment - Chevelle Tech
 19Likes
post #1 of 17 (permalink) Old Nov 7th, 18, 10:39 PM Thread Starter
leaks embarrassment
see the embarrassment there? just looking for opinions. got new gaskets coming for the water pump, thermostat housing.
ss65skylark is offline
post #2 of 17 (permalink) Old Nov 7th, 18, 11:23 PM
Al
Re: leaks embarrassment
It's not leaking from the manifold? Sounds like you got it covered.
Order a can of paint, some masking tape, acquire the old ladies newspaper from across the street, clean her up/ mask it up. give it a pretty coat of paint before you slap on the water pump.
DUTCH MAX HEADWORK is offline
post #3 of 17 (permalink) Old Nov 8th, 18, 9:29 AM
Hey to me, it looks like an engine that runs. Not one that sits under a spotlight and mirror.
If painting, get the matching spray paint and spray it into a cup, then brush it on, much less masking on and around bumpy engine parts.
HKalin likes this.
Pioneer4x4 is offline
post #4 of 17 (permalink) Old Nov 8th, 18, 11:59 AM Thread Starter
[QUOTE=DUTCH MAX HEADWORK;10970734]It's not leaking from the manifold? Sounds like you got it covered.
It probably is. A lot of my problems stem from building this as an invincible know it all young man. Like usinh the fel-pro manifold gaskets instead of edelbrock cos I knew more than the engineers.
So I am now, 16 yrs later, going back and trying to correct these issues.
The paint brush idea is a good one, and I do still have the paint (wonde if it is still any good??)
post #5 of 17 (permalink) Old Nov 8th, 18, 10:02 PM
Terry
The Fel-Pro gaskets are some of the best on the market. It looks like the end seal is bad at the intake. Did you use the rubber gasket there or use silicone? Terry
Steve R and LeoP like this.
68-13427 is offline
post #6 of 17 (permalink) Old Nov 9th, 18, 12:02 AM Thread Starter
Terry, I can't remember. It was ages ago. But I agree, it does look bad there.
If you read the edelbrock manifold instructions though, it specifically says only to use edelbrock gaskets. I don't think it's a marketing thing either.
I do use FP for everything else.
post #7 of 17 (permalink) Old Nov 9th, 18, 1:00 AM
Steamy
Wink Re: leaks embarrassment
My embarrassing leaks usually show up as a damp spot in the crotch of my jeans.
BillL
My Showroom
Ark68SS is offline
post #8 of 17 (permalink) Old Nov 9th, 18, 8:03 AM
Did you put sealant on the intake bolts that go in to the water passages? Looks like those are wicking up?
427L88 likes this.
People dont like to have to think in high resolution. Jordan Peterson. Thats why we are forced in to so many binary choices.
Alan F is offline
post #9 of 17 (permalink) Old Nov 9th, 18, 8:07 AM
Using an old tripower intake, the end rails and passages are prone. As Alan said, use sealer on those two front intake bolts. I have to use RTV for the end rails. It has to really setup before i drop the casting on and tq it down. Otherwise, it will weep, as I've discovered, esp the rear.
post #10 of 17 (permalink) Old Nov 10th, 18, 3:38 PM Thread Starter
Originally Posted by Ark68SS View Post
My embarrassing leaks usually show up as a damp spot in the crotch of my jeans. <img src="https://www.chevelles.com/forums/images/smilies/redface.gif" border="0" alt="" title="Embarrassment" class="inlineimg" />
BillL
Thanks Bill &#x1f632;
post #11 of 17 (permalink) Old Dec 7th, 18, 11:28 AM Thread Starter
Finished
post #12 of 17 (permalink) Old Dec 7th, 18, 12:48 PM
"Right Stuff" will get her done.
Slick87gn is offline
post #13 of 17 (permalink) Old Dec 8th, 18, 2:32 AM Thread Starter
Is that detail spray? I do have a few more odds and ends to go to
post #14 of 17 (permalink) Old Dec 8th, 18, 2:56 AM
Al
Looking good, need to restore that alt bracket with matte black or semi-gloss black. Then clean up the wiring shenanigans around the battery.
If you paint the bracket, you need to clean the paint from the mounting surfaces so you'll have a good ground. One way to do this is clean the bracket, get a bolt and washer the size you will use to mount the bracket and put it in the bracket holes before you paint. They will act like masking without having to do any masking. You won't have to clean off paint and risk damaging your awesome new paint job.
Get us a picture of that battery/wiring and explain what you have hooked up and we'll work on a cleanup plan for you....if you like.
post #15 of 17 (permalink) Old Dec 8th, 18, 7:15 PM Thread Starter
I was going there next. I need to run a new battery cable first. There is a new headlight relay connected directly to the battery. That's all that is there now.
The negative is new and grounded properly to the bracket clean metal.
